ISO/TC 119 STANDARDS
ISO 3252:1999 Powder metallurgy -- Vocabulary
ISO 5755:2012 Sintered metal materials -- Specifications
ISO 22068:2012 Sintered-metal injection-moulded materials -- Specifications
Sampling and testing methods for powders (including powders for hardmetals)
ISO 3923-1:2008 Metallic powders -- Determination of apparent density -- Part 1: Funnel method
ISO 3923-2:1981 Metallic powders -- Determination of apparent density -- Part 2: Scott volumeter method
ISO 3927:2011 Metallic powders* excluding powders for hardmetals -- Determination of compressibility in uniaxial compression
ISO 3953:2011 Metallic powders -- Determination of tap density
ISO 3954:2007 Powders for powder metallurgical purposes -- Sampling
ISO 3995:1985 Metallic powders -- Determination of green strength by transverse rupture of rectangular compacts
ISO 4490:2014 Metallic powders -- Determination of flow rate by means of a calibrated funnel (Hall flowmeter)
ISO 4491-1:1989 Metallic powders -- Determination of oxygen content by reduction methods -- Part 1: General guidelines
ISO 4491-2:1997 Metallic powders -- Determination of oxygen content by reduction methods -- Part 2: Loss of mass on hydrogen reduction (hydrogen loss)
ISO 4491-3:1997 Metallic powders -- Determination of oxygen content by reduction methods -- Part 3: Hydrogen-reducible oxygen
ISO 4491-4:2013 Metallic powders -- Determination of oxygen content by reduction methods -- Part 4: Total oxygen by reduction-extraction
ISO 4492:2013 Metallic powders* excluding powders for hardmetals -- Determination of dimensional changes associated with compacting and sintering
ISO 4496:2017 Metallic powders -- Determination of acid-insoluble content in iron* copper* tin and bronze powders
ISO 4497:1983 Metallic powders -- Determination of particle size by dry sieving
ISO 10070:1991 Metallic powders -- Determination of envelope-specific surface area from measurements of the permeability to air of a powder bed under steady-state flow conditions
ISO 13517:2013 Metallic powders -- Determination of flowrate by means of a calibrated funnel (Gustavsson flowmeter)
ISO 13944:2012 Lubricated metal-powder mixes -- Determination of lubricant content -- Soxhlet extraction method
ISO 13947:2011 Metallic powders -- Test method for the determination of non-metallic inclusions in metal powders using a powder-forged specimen
ISO 14168:2011 Metallic powders* excluding hardmetals -- Method for testing copper-base infiltrating powders
ISO 18549-1:2009 Metallic powders -- Determination of apparent density and flow rate at elevated temperatures -- Part 1: Determination of apparent density at elevated temperatures
ISO 18549-2:2009 Metallic powders -- Determination of apparent density and flow rate at elevated temperatures -- Part 2: Determination of flow rate at elevated temperature
Sampling and testing methods for sintered metal materials (excluding hardmetals)
ISO 2738:1999 Sintered metal materials* excluding hardmetals -- Permeable sintered metal materials -- Determination of density* oil content and open porosity
ISO 2739:2012 Sintered metal bushings -- Determination of radial crushing strength
ISO 2740:2009 Sintered metal materials* excluding hardmetals -- Tensile test pieces
ISO 3312:1987 Sintered metal materials and hardmetals -- Determination of Young modulus
ISO 3325:1996 Sintered metal materials* excluding hardmetals -- Determination of transverse rupture strength
ISO 3325:1996/Amd 1:2001 Precision statement
ISO 3369:2006 Impermeable sintered metal materials and hardmetals -- Determination of density
ISO 3928:2016 Sintered metal materials* excluding hardmetals -- Fatigue test pieces
ISO 4003:1977 Permeable sintered metal materials -- Determination of bubble test pore size
ISO 4022:1987 Permeable sintered metal materials -- Determination of fluid permeability
ISO 4498:2010 Sintered metal materials* excluding hardmetals -- Determination of apparent hardness and microhardness
ISO 4507:2000 Sintered ferrous materials* carburized or carbonitrided -- Determination and verification of case-hardening depth by a micro-hardness test
ISO 5754:1978 Sintered metal materials* excluding hardmetals -- Unnotched impact test piece
ISO 7625:2012 Sintered metal materials* excluding hardmetals -- Preparation of samples for chemical analysis for determination of carbon content
ISO 14317:2015 Sintered metal materials excluding hardmetals -- Determination of compressive yield strength
ISO 23519:2010 Sintered metal materials* excluding hardmetals -- Measurement of surface roughness
ISO 28279:2010 Sintered metal materials -- Determination of the level of cleanliness of powder-metallurgy parts
Sampling and testing methods for hardmetals
ISO 3327:2009 Hardmetals -- Determination of transverse rupture strength
ISO 3738-1:1982 Hardmetals -- Rockwell hardness test (scale A) -- Part 1: Test method
ISO 3738-2:1988 Hardmetals -- Rockwell hardness test (scale A) -- Part 2: Preparation and calibration of standard test blocks
ISO 3878:1983 Hardmetals -- Vickers hardness test
ISO 3907:2009 Hardmetals -- Determination of total carbon -- Gravimetric method
ISO 3908:2009 Hardmetals -- Determination of insoluble (free) carbon -- Gravimetric method
ISO 3909:1976 Hardmetals -- Determination of cobalt -- Potentiometric method
ISO 4489:1978 Sintered hardmetals -- Sampling and testing
ISO 4499-1:2008 Hardmetals -- Metallographic determination of microstructure -- Part 1: Photomicrographs and description
ISO 4499-2:2008 Hardmetals -- Metallographic determination of microstructure -- Part 2: Measurement of WC grain size
ISO 4499-3:2016 Hardmetals -- Metallographic determination of microstructure -- Part 3: Measurement of microstructural features in Ti (C* N) and WC/cubic carbide based hardmetals
ISO 4499-4:2016 Hardmetals -- Metallographic determination of microstructure -- Part 4: Characterisation of porosity* carbon defects and eta-phase content
ISO 4501:1978 Hardmetals -- Determination of titanium -- Photometric peroxide method
ISO 4503:1978 Hardmetals -- Determination of contents of metallic elements by X-ray fluorescence -- Fusion method
ISO 4506:1979 Hardmetals -- Compression test
ISO 4883:1978 Hardmetals -- Determination of contents of metallic elements by X-ray fluorescence -- Solution method
ISO 4884:1978 Hardmetals -- Sampling and testing of powders using sintered test pieces
ISO 7627-1:1983 Hardmetals -- Chemical analysis by flame atomic absorption spectrometry -- Part 1: General requirements
ISO 7627-2:1983 Hardmetals -- Chemical analysis by flame atomic absorption spectrometry -- Part 2: Determination of calcium* potassium* magnesium and sodium in contents from 0*001 to 0*02 % (m/m)
ISO 7627-3:1983 Hardmetals -- Chemical analysis by flame atomic absorption spectrometry -- Part 3: Determination of cobalt* iron* manganese and nickel in contents from 0*01 to 0*5 % (m/m)
ISO 7627-4:1983 Hardmetals -- Chemical analysis by flame atomic absorption spectrometry -- Part 4: Determination of molybdenum* titanium and vanadium in contents from 0*01 to 0*5 %
ISO 7627-5:1983 Hardmetals -- Chemical analysis by flame atomic absorption spectrometry -- Part 5: Determination of cobalt* iron* manganese* molybdenum* nickel* titanium and vanadium in contents from 0*5 to 2 % (m/m)
ISO 7627-6:1985 Hardmetals -- Chemical analysis by flame atomic absorption spectrometry -- Part 6: Determination of chromium in contents from 0*01 to 2 % (m/m)
ISO 11873:2005 Hardmetals -- Determination of sulfur and carbon contents in cobalt metal powders -- Infrared detection method
ISO 11873:2005/Cor 1:2008 Hardmetals -- Determination of sulfur and carbon contents in cobalt metal powders -- Infrared detection method
ISO 11876:2010 Hardmetals -- Determination of calcium* copper* iron* potassium* magnesium* manganese* sodium* nickel and zinc in cobalt metal powders -- Flame atomic absorption spectrometric method
ISO 11877:2008 Hardmetals -- Determination of silicon in cobalt metal powders -- Photometric method
ISO 17352:2008 Hardmetals -- Determination of silicon in cobalt metal powders using graphite-furnace atomic absorption
ISO 26482:2010 Hardmetals -- Determination of lead and cadmium content
ISO 28079:2009 Hardmetals -- Palmqvist toughness test
ISO 28080:2011 Hardmetals -- Abrasion tests for hardmetals
only 1 missing is:
