CYPE programs have a wide range of national and international codes available which are applied to carry out the analysis* design and check of reinforced concrete* rolled steel* welded steel* cold-formed steel* composite* aluminium and timber structures for gravitational* wind* seismic and snow loads.
CYPE's building services programs contain design codes which are used to analyse and design building services (water supply* waste water* air conditioning* solar capture for hot sanitary water* lightning protection* lighting* gas* electricity and telecommunication installations)* and to check thermal and acoustic insulation* the building's energy certification and fire safety.
CYPECAD - program that carries out the analysis and design of reinforced concrete and steel structures* subject to horizontal and vertical loads* for homes* buildings and civil work projects. Its use guarantees maximum analysis reliability and optimum drawing design. The geometry of the structure can be introduced automatically. The user can personalise the design and edit the elements that have been introduced* with the on-screen support provided: numerous help options and error and warning texts. Provides very complete and precise construction drawings of the structure. CYPECAD is adapted to the latest national and international construction codes.
CYPE 3D - it is an agile and efficient program brought about to carry out the design of three dimensional structures composed of steel and timber bars* and their foundations* which includes pad footings* pile caps and strap and tie beams. Additionally* these can be redesigned and so obtain their maximum optimisation. It has been adapted to national and international steel* timber* aluminium and concrete construction codes. The program carries out the analysis* design and check of the fire resistance of timber sections. Performs a seismic analysis of the structure (Modal Spectral Analysis) according to national and international codes. Second order effects (P-delta) are considered with wind and seismic loads.
CYPE-Connect - the program can check slabs with or without transverse punching shear reinforcement* takes into account the presence of openings or lightweight zones in the slab* and the position of the supports (internal* edge or corner). Punching shear verification is a program that checks the Failure Limit State of concrete for punching shear in flat and waffle slabs exposed to concentrated loads from rectangular or circular supports.
More info.
Attention of Russian designers: software package CYPECAD â„–0896268 received a certificate of compliance with regulations:
SP 20.13330.2011 Loads and effects The updated edition of SNiP 2.01.07-85
SP 63.13330.2012 Concrete and reinforced concrete structures. The updated edition of SNiP 52-101-2003
SP 14.13330.2011 Construction in seismic areas. The updated edition of SNIP II-7-81
5.3 Gb
[link Point to another website Only the registered members can access] Must be loged on lavteam to see and download
