Cype software 2016o
CYPE Ingenieros, S.A., a firm that develops and distributes technical software for Architecture, Engineering and Construction professionals, presents the 2016o version of CYPE, is composed of several modules that allow the engineer to analyze various types of structure, or to evaluate various structural alternatives solutions without the need to calculate certain situations or analyze manually or with the aid of additional software.
CYPE programs have a wide range of national and international codes available which are applied to carry out the analysis, design and check of reinforced concrete, rolled steel, welded steel, cold-formed steel, composite, aluminium and timber structures for gravitational, wind, seismic and snow loads.
CYPE's building services programs contain design codes which are used to analyse and design building services (water supply, waste water, air conditioning, solar capture for hot sanitary water, lightning protection, lighting, gas, electricity and telecommunication installations), and to check thermal and acoustic insulation, the building's energy certification and fire safety.
Amongst the codes contemplated in CYPE software are codes currently in force, and those which a no longer in use but are still required, either to check structures which were designed when they could be applied, or because they are still applicable in countries other than those of their origin.
Depending on the country where the user acquires the license (or where he/she specifically chooses to acquire it), only the design codes corresponding to that country will be activated for each program, regardless of the language in which it is installed.
The design codes and programs corresponding to other countries, which are not included in the user license, can be acquired separately. Please contact us for more information.
About CYPE Ingenieros, S.A.
CYPE’s journey began in 1983 with an intense activity in the field of engineering and structural analysis, which motivated the computer development of applications to cover its own needs and those of its clients. The success of these programs led the company to concentrate its activity in the development, commercialisation and distribution of technical software.
As a result of this work, CYPE occupies a leading position within the sector, offering a variety of programs that stand out due to the wide range of casuistry that is dealt with, the reliability of the results and the ease with which they can be managed.
Version: 2016o
Supported Architectures: 32bit / 64bit
Website Home Page :[link Point to another website Only the registered members can access]
Interface: multilanguage
System Requirements: PC
Supported Operating Systems: Windows Vista / 7even / 8.x / 10 / Windows 2003 Server / Windows 2008 Server
Password:9bd4
Please one by one download, don't think selection all at same time.
