Thread: ISO Collection 151/300: ISO/TC 163-Thermal performance and energy use in the built en
    ISO/TC 163
    ISO 7345:1987 Thermal insulation -- Physical quantities and definitions
    ISO 9229:2007 Thermal insulation -- Vocabulary
    ISO 9251:1987 Thermal insulation -- Heat transfer conditions and properties of materials -- Vocabulary
    ISO 9288:1989 Thermal insulation -- Heat transfer by radiation -- Physical quantities and definitions
    ISO 9346:2007 Hygrothermal performance of buildings and building materials -- Physical quantities for mass transfer -- Vocabulary
    ISO 12655:2013 Energy performance of buildings -- Presentation of measured energy use of buildings
    ISO 16343:2013 Energy performance of buildings -- Methods for expressing energy performance and for energy certification of buildings
    ISO/TR 16344:2012 Energy performance of buildings -- Common terms* definitions and symbols for the overall energy performance rating and certification
    ISO 16346:2013 Energy performance of buildings -- Assessment of overall energy performance
    ISO 18523-1:2016 Energy performance of buildings -- Schedule and condition of building* zone and space usage for energy calculation -- Part 1: Non-residential buildings
    Test and measurement methods
    ISO 6781-3:2015 Performance of buildings -- Detection of heat* air and moisture irregularities in buildings by infrared methods -- Part 3: Qualifications of equipment operators* data analysts and report writers
    ISO 6781:1983 Thermal insulation -- Qualitative detection of thermal irregularities in building envelopes -- Infrared method
    ISO 8301:1991 Thermal insulation -- Determination of steady-state thermal resistance and related properties -- Heat flow meter apparatus
    ISO 8301:1991/Amd 1:2010 Thermal insulation -- Determination of steady-state thermal resistance and related properties -- Heat flow meter apparatus
    ISO 8302:1991 Thermal insulation -- Determination of steady-state thermal resistance and related properties -- Guarded hot plate apparatus
    ISO 8497:1994 Thermal insulation -- Determination of steady-state thermal transmission properties of thermal insulation for circular pipes
    ISO 8990:1994 Thermal insulation -- Determination of steady-state thermal transmission properties -- Calibrated and guarded hot box
    ISO 9869-1:2014 Thermal insulation -- Building elements -- In-situ measurement of thermal resistance and thermal transmittance -- Part 1: Heat flow meter method
    ISO 9972:2015 Thermal performance of buildings -- Determination of air permeability of buildings -- Fan pressurization method
    ISO 10051:1996 Thermal insulation -- Moisture effects on heat transfer -- Determination of thermal transmissivity of a moist material
    ISO 11561:1999 Ageing of thermal insulation materials -- Determination of the long-term change in thermal resistance of closed-cell plastics (accelerated laboratory test methods)
    ISO 12344:2010 Thermal insulating products for building applications -- Determination of bending behaviour
    ISO 12567-1:2010 Thermal performance of windows and doors -- Determination of thermal transmittance by the hot-box method -- Part 1: Complete windows and doors
    ISO 12567-1:2010/Cor 1:2010 Thermal performance of windows and doors -- Determination of thermal transmittance by the hot-box method -- Part 1: Complete windows and doors
    ISO 12567-2:2005 Thermal performance of windows and doors -- Determination of thermal transmittance by hot box method -- Part 2: Roof windows and other projecting windows
    ISO 12569:2012 Thermal performance of buildings and materials -- Determination of specific airflow rate in buildings -- Tracer gas dilution method
    ISO 12570:2000 Hygrothermal performance of building materials and products -- Determination of moisture content by drying at elevated temperature
    ISO 12570:2000/Amd 1:2013 Hygrothermal performance of building materials and products -- Determination of moisture content by drying at elevated temperature
    ISO 12571:2013 Hygrothermal performance of building materials and products -- Determination of hygroscopic sorption properties
    ISO 12572:2016 Hygrothermal performance of building materials and products -- Determination of water vapour transmission properties -- Cup method
    ISO 12623:2011 Thermal insulating products for building equipment and industrial installations -- Determination of short-term water absorption by partial immersion of preformed pipe insulation
    ISO 12624:2011 Thermal insulating products for building equipment and industrial installations -- Determination of trace quantities of water soluble chloride* fluoride* silicate* sodium ions and pH
    ISO 12628:2011 Thermal insulating products for building equipment and industrial installations -- Determination of dimensions* squareness and linearity of preformed pipe insulation
    ISO 12629:2011 Thermal insulating products for building equipment and industrial installations -- Determination of water vapour transmission properties of preformed pipe insulation
    ISO 12968:2010 Thermal insulation products for building applications -- Determination of the pull-off resistance of external thermal insulation composite systems (ETICS) (foam block test)
    ISO 14857:2014 Thermal performance in the built environment -- Determination of air permeance of building materials
    ISO 15148:2002 Hygrothermal performance of building materials and products -- Determination of water absorption coefficient by partial immersion
    ISO 15148:2002/Amd 1:2016 Hygrothermal performance of building materials and products -- Determination of water absorption coefficient by partial immersion
    ISO 16534:2012 Thermal insulating products for building applications -- Determination of compressive creep
    ISO 16535:2012 Thermal insulating products for building applications -- Determination of long-term water absorption by immersion
    ISO 16536:2012 Thermal insulating products for building applications -- Determination of long-term water absorption by diffusion
    ISO 16537:2012 Thermal insulating products for building applications -- Determination of shear behaviour
    ISO 16544:2012 Thermal insulating products for building applications -- Conditioning to moisture equilibrium under specified temperature and humidity conditions
    ISO 16545:2012 Thermal insulating products for building applications -- Determination of behaviour under cyclic loading
    ISO 16546:2012 Thermal insulating products for building applications -- Determination of freeze-thaw resistance
    ISO 16956:2015 Thermal performance in the built environment -- Determination of air flow rate in building applications by field measuring methods
    ISO 16957:2016 Measurement of apparent thermal conductivity of wet porous building materials by a periodic method
    ISO 18096:2013 Thermal insulating products for building equipment and industrial installations -- Determination of maximum service temperature for preformed pipe insulation
    ISO 18097:2013 Thermal insulating products for building equipment and industrial installations -- Determination of maximum service temperature
    ISO 18098:2013 Thermal insulating products for building equipment and industrial installations -- Determination of the apparent density of preformed pipe insulation
    ISO 18099:2013 Thermal insulating products for building equipment and industrial installations -- Determination of the coefficient of thermal expansion
    ISO 18393-1:2012 Thermal insulation products -- Determination of ageing by settlement -- Part 1: Blown loose-fill insulation for ventilated attics
    ISO 21129:2007 Hygrothermal performance of building materials and products -- Determination of water-vapour transmission properties -- Box method
    ISO 24353:2008 Hygrothermal performance of building materials and products -- Determination of moisture adsorption/desorption properties in response to humidity variation
    ISO 29465:2008 Thermal insulating products for building applications -- Determination of length and width
    ISO 29466:2008 Thermal insulating products for building applications -- Determination of thickness
    ISO 29467:2008 Thermal insulating products for building applications -- Determination of squareness
    ISO 29467:2008/Amd 1:2014 Thermal insulating products for building applications -- Determination of squareness
    ISO 29468:2008 Thermal insulating products for building applications -- Determination of flatness
    ISO 29469:2008 Thermal insulating products for building applications -- Determination of compression behaviour
    ISO 29470:2008 Thermal insulating products for building applications -- Determination of the apparent density
    ISO 29471:2008 Thermal insulating products for building applications -- Determination of dimensional stability under constant normal laboratory conditions (23 degrees C/50 % relative humidity)
    ISO 29471:2008/Amd 1:2014 Thermal insulating products for building applications -- Determination of dimensional stability under constant normal laboratory conditions (23 degrees C/50 % relative humidity)
    ISO 29472:2008 Thermal insulating products for building applications -- Determination of dimensional stability under specified temperature and humidity conditions
    ISO 29472:2008/Amd 1:2014 Thermal insulating products for building applications -- Determination of dimensional stability under specified temperature and humidity conditions
    ISO 29764:2008 Thermal insulating products for building applications -- Determination of deformation under specified compressive load and temperature conditions
    ISO 29765:2008 Thermal insulating products for building applications -- Determination of tensile strength perpendicular to faces
    ISO 29766:2008 Thermal insulating products for building applications -- Determination of tensile strength parallel to faces
    ISO 29767:2008 Thermal insulating products for building applications -- Determination of short-term water absorption by partial immersion
    ISO 29767:2008/Amd 1:2014 Thermal insulating products for building applications -- Determination of short-term water absorption by partial immersion
    ISO 29768:2008 Thermal insulating products for building applications -- Determination of linear dimensions of test specimens
    ISO 29769:2008 Thermal insulating products for building applications -- Determination of behaviour under point load
    ISO 29770:2008 Thermal insulating products for building applications -- Determination of thickness for floating-floor insulating products
    ISO 29771:2008 Thermal insulating materials for building applications -- Determination of organic content
    ISO 29771:2008/Amd 1:2014 Thermal insulating materials for building applications -- Determination of organic content
    ISO 29803:2010 Thermal insulation products for building applications -- Determination of the resistance to impact of external thermal insulation composite systems (ETICS)
    ISO 29804:2009 Thermal insulation products for building applications -- Determination of the tensile bond strength of the adhesive and of the base coat to the thermal insulation material
    ISO 29805:2009 Thermal insulation products for building applications -- Determination of the mechanical properties of glass fibre meshes
    Calculation methods
    ISO 6243:1997 Climatic data for building design -- Proposed system of symbols
    ISO 6946:2007 Building components and building elements -- Thermal resistance and thermal transmittance -- Calculation method
    ISO 10077-1:2006 Thermal performance of windows* doors and shutters -- Calculation of thermal transmittance -- Part 1: General
    ISO 10077-1:2006/Cor 1:2009 Thermal performance of windows* doors and shutters -- Calculation of thermal transmittance -- Part 1: General
    ISO 10077-2:2012 Thermal performance of windows* doors and shutters -- Calculation of thermal transmittance -- Part 2: Numerical method for frames
    ISO 10077-2:2012/Cor 1:2012 Thermal performance of windows* doors and shutters -- Calculation of thermal transmittance -- Part 2: Numerical method for frames
    ISO 10211:2007 Thermal bridges in building construction -- Heat flows and surface temperatures -- Detailed calculations
    ISO 10456:2007 Building materials and products -- Hygrothermal properties -- Tabulated design values and procedures for determining declared and design thermal values
    ISO 10456:2007/Cor 1:2009 Building materials and products -- Hygrothermal properties -- Tabulated design values and procedures for determining declared and design thermal values
    ISO 10916:2014 Calculation of the impact of daylight utilization on the net and final energy demand for lighting
    ISO 12241:2008 Thermal insulation for building equipment and industrial installations -- Calculation rules
    ISO 12631:2012 Thermal performance of curtain walling -- Calculation of thermal transmittance
    ISO 13370:2007 Thermal performance of buildings -- Heat transfer via the ground -- Calculation methods
    ISO 13786:2007 Thermal performance of building components -- Dynamic thermal characteristics -- Calculation methods
    ISO 13787:2003 Thermal insulation products for building equipment and industrial installations -- Determination of declared thermal conductivity
    ISO 13788:2012 Hygrothermal performance of building components and building elements -- Internal surface temperature to avoid critical surface humidity and interstitial condensation -- Calculation methods
    ISO 13789:2007 Thermal performance of buildings -- Transmission and ventilation heat transfer coefficients -- Calculation method
    ISO 13790:2008 Energy performance of buildings -- Calculation of energy use for space heating and cooling
    ISO 13791:2012 Thermal performance of buildings -- Calculation of internal temperatures of a room in summer without mechanical cooling -- General criteria and validation procedures
    ISO 13792:2012 Thermal performance of buildings -- Calculation of internal temperatures of a room in summer without mechanical cooling -- Simplified methods
    ISO 13793:2001 Thermal performamce of buildings - Thermal design of foundations to avoid frost heave
    ISO 14683:2007 Thermal bridges in building construction -- Linear thermal transmittance -- Simplified methods and default values
    ISO 15099:2003 Thermal performance of windows* doors and shading devices -- Detailed calculations
    ISO 15758:2014 Hygrothermal performance of building equipment and industrial installations -- Calculation of water vapour diffusion -- Cold pipe insulation systems
    ISO 15927-1:2003 Hygrothermal performance of buildings -- Calculation and presentation of climatic data -- Part 1: Monthly means of single meteorological elements
    ISO 15927-2:2009 Hygrothermal performance of buildings -- Calculation and presentation of climatic data -- Part 2: Hourly data for design cooling load
    ISO 15927-3:2009 Hygrothermal performance of buildings - Calculation and presentation of climatic data -- Part 3: Calculation of a driving rain index for vertical surfaces from hourly wind and rain data
    ISO 15927-4:2005 Hygrothermal performance of buildings -- Calculation and presentation of climatic data -- Part 4: Hourly data for assessing the annual energy use for heating and cooling
    ISO 15927-5:2004 Hygrothermal performance of buildings -- Calculation and presentation of climatic data -- Part 5: Data for design heat load for space heating
    ISO 15927-5:2004/Amd 1:2011 Hygrothermal performance of buildings -- Calculation and presentation of climatic data -- Part 5: Data for design heat load for space heating
    ISO 15927-6:2007 Hygrothermal performance of buildings -- Calculation and presentation of climatic data -- Part 6: Accumulated temperature differences (degree-days)
    ISO 18292:2011 Energy performance of fenestration systems for residential buildings -- Calculation procedure
    ISO 18292:2011/Cor 1:2012 Energy performance of fenestration systems for residential buildings -- Calculation procedure
    ISO 23993:2008 Thermal insulation products for building equipment and industrial installations -- Determination of design thermal conductivity
    ISO 8142:1990 Thermal insulation -- Bonded preformed man-made mineral fibre pipe sections -- Specification
    ISO 8143:2010 Thermal insulation products for building equipment and industrial installations -- Calcium silicate products
    ISO 8144-1:1995 Thermal insulation -- Mineral wool mats for ventilated roof spaces -- Part 1: Specification for applications with restricted ventilation
    ISO 8144-2:1995 Thermal insulation -- Mineral wool mats for ventilated roof spaces -- Part 2: Specification for horizontal applications with unrestricted ventilation
    ISO 8145:1994 Thermal insulation -- Mineral wool board for overdeck insulation of roofs -- Specification
    ISO 9076-2:2008 Thermal insulation -- Mineral-wool loose-fill for horizontal applications in ventilated roof spaces -- Part 2: Principal responsibilities of installers
    ISO 12574-2:2008 Thermal insulation -- Cellulose-fibre loose-fill for horizontal applications in ventilated roof spaces -- Part 2: Principal responsibilities of installers
    ISO 12575-1:2012 Thermal insulation products -- Exterior insulating systems for foundations -- Part 1: Material specification
    ISO 12575-2:2007 Thermal insulation products -- Exterior insulating systems for foundations -- Part 2: Principal responsibilities of installers
    ISO 12576-1:2001 Thermal insulation -- Insulating materials and products for buildings -- Conformity control systems -- Part 1: Factory-made products
    ISO 12576-2:2008 Thermal insulation products -- Conformity control systems -- Part 2: In-situ products
    ISO 17738-1:2017 Thermal insulation products -- Exterior insulation and finish systems -- Part 1: Materials and systems
    missing are:
    Re: ISO Collection 151/300: ISO/TC 163-Thermal performance and energy use in the buil
    update:
    missing* new* BQ* EN:
    ISO 17772-1:2017 Energy performance of buildings -- Indoor environmental quality -- Part 1: Indoor environmental input parameters for the design and assessment of energy performance of buildings
    ISO 19467:2017 Thermal performance of windows and doors -- Determination of solar heat gain coefficient using solar simulator
    they've issued a lot of new stanrads here*so the missing list is big:.
    ISO 6946:2017 Building components and building elements -- Thermal resistance and thermal transmittance -- Calculation methods
    ISO 10077-1:2017 Thermal performance of windows* doors and shutters -- Calculation of thermal transmittance -- Part 1: General
    ISO 10077-2:2017 Thermal performance of windows* doors and shutters -- Calculation of thermal transmittance -- Part 2: Numerical method for frames
    ISO 10211:2017 Thermal bridges in building construction -- Heat flows and surface temperatures -- Detailed calculations
    ISO 12631:2017 Thermal performance of curtain walling -- Calculation of thermal transmittance
    ISO 13370:2017 Thermal performance of buildings -- Heat transfer via the ground -- Calculation methods
    ISO 13786:2017 Thermal performance of building components -- Dynamic thermal characteristics -- Calculation methods
    ISO 13789:2017 Thermal performance of buildings -- Transmission and ventilation heat transfer coefficients -- Calculation method
    ISO 14683:2017 Thermal bridges in building construction -- Linear thermal transmittance -- Simplified methods and default values
    ISO 52000-1:2017 Energy performance of buildings -- Overarching EPB assessment -- Part 1: General framework and procedures
    ISO/TR 52000-2:2017 Energy performance of buildings -- Overarching EPB assessment -- Part 2: Explanation and justification of ISO 52000-1
    ISO 52003-1:2017 Energy performance of buildings -- Indicators* requirements* ratings and certificates -- Part 1: General aspects and application to the overall energy performance
    ISO/TR 52003-2:2017 Energy performance of buildings -- Indicators* requirements* ratings and certificates -- Part 2: Explanation and justification of ISO 52003-1
    ISO 52010-1:2017 Energy performance of buildings -- External climatic conditions -- Part 1: Conversion of climatic data for energy calculations
    ISO/TR 52010-2:2017 Energy performance of buildings - External climatic conditions -- Part 2: Explanation and justification of ISO 52010-1
    ISO 52016-1:2017 Energy performance of buildings -- Energy needs for heating and cooling* internal temperatures and sensible and latent heat loads -- Part 1: Calculation procedures
    ISO/TR 52016-2:2017 Energy performance of buildings -- Energy needs for heating and cooling* internal temperatures and sensible and latent heat loads -- Part 2: Explanation and justification of ISO 52016-1 and ISO 52017-1
    ISO 52017-1:2017 Energy performance of buildings -- Sensible and latent heat loads and internal temperatures -- Part 1: Generic calculation procedures
    ISO 52018-1:2017 Energy performance of buildings -- Indicators for partial EPB requirements related to thermal energy balance and fabric features -- Part 1: Overview of options
    ISO/TR 52018-2:2017 Energy performance of buildings -- Indicators for partial EPB requirements related to thermal energy balance and fabric features -- Part 2: Explanation and justification of ISO 52018-1
    ISO/TR 52019-2:2017 Energy performance of buildings -- Hygrothermal performance of building components and building elements -- Part 2: Explanation and justification
    ISO 52022-1:2017 Energy performance of buildings -- Thermal* solar and daylight properties of building components and elements -- Part 1: Simplified calculation method of the solar and daylight characteristics for solar protection devices combined with glazing
    ISO/TR 52022-2:2017 Energy performance of buildings -- Thermal* solar and daylight properties of building components and elements -- Part 2: Explanation and justification
    ISO 52022-3:2017 Energy performance of buildings -- Thermal* solar and daylight properties of building components and elements -- Part 3: Detailed calculation method of the solar and daylight characteristics for solar protection devices combined with glazing
    use "reply with quote" to see the direct link
  5. Re: ISO Collection 151/300: ISO/TC 163-Thermal performance and energy use in the buil
    Some Links of the website was updated * You can search the site through search
    or visit
    Petroleum Community Forum Home
    Read more:
    thank you community and greetings
  1. Replies: 6
    Last Post: 12-28-2017, 04:07 PM
  2. Replies: 4
    Last Post: 12-09-2017, 01:55 PM
  3. Replies: 5
    Last Post: 07-12-2017, 07:41 AM
  4. Replies: 9
    Last Post: 06-08-2017, 04:43 PM
  5. Replies: 3
    Last Post: 11-19-2013, 08:59 AM
