Thread: ISO Collection 147/300: ISO/TC 47-Chemistry
    ISO/TC 47
    ISO 739:1976 Sodium carbonate for industrial use -- Preparation and storage of test samples
    ISO 740:1976 Sodium carbonate for industrial use -- Determination of total soluble alkalinity -- Titrimetric method
    ISO 746:1976 Sodium carbonate for industrial use -- Determination of matter insoluble in water at 50 degrees C
    ISO 756-1:1981 Propan-2-ol for industrial use -- Methods of test -- Part 1: General
    ISO 758:1976 Liquid chemical products for industrial use -- Determination of density at 20 degrees C
    ISO 904:1976 Hydrochloric acid for industrial use -- Determination of total acidity -- Titrimetric method
    ISO 910:1977 Sulphuric acid and oleum for industrial use -- Determination of total acidity* and calculation of free sulphur trioxide content of oleum -- Titrimetric method
    ISO 918:1983 Volatile organic liquids for industrial use -- Determination of distillation characteristics
    ISO 979:1974 Sodium hydroxide for industrial use -- Method of assay
    ISO 981:1973 Sodium hydroxide for industrial use -- Determination of chloride content -- Mercurimetric method
    ISO 1385-1:1977 Phthalate esters for industrial use -- Methods of test -- Part 1: General
    ISO 1388-1:1981 Ethanol for industrial use -- Methods of test -- Part 1: General
    ISO 1388-2:1981 Ethanol for industrial use -- Methods of test -- Part 2: Detection of alkalinity or determination of acidity to phenolphthalein
    ISO 1388-3:1981 Ethanol for industrial use -- Methods of test -- Part 3: Estimation of content of carbonyl compounds present in small amounts -- Photometric method
    ISO 1388-4:1981 Ethanol for industrial use -- Methods of test -- Part 4: Estimation of content of carbonyl compounds present in moderate amounts -- Titrimetric method
    ISO 1388-5:1981 Ethanol for industrial use -- Methods of test -- Part 5: Determination of aldehydes content -- Visual colorimetric method
    ISO 1388-6:1981 Ethanol for industrial use -- Methods of test -- Part 6: Test for miscibility with water
    ISO 1388-7:1981 Ethanol for industrial use -- Methods of test -- Part 7: Determination of methanol content (methanol contents between 0*01 and 0*20 % (V/V)) -- Photometric method
    ISO 1388-8:1981 Ethanol for industrial use -- Methods of test -- Part 8: Determination of methanol content (methanol contents between 0*10 and 1*50 % (V/V)) -- Visual colorimetric method
    ISO 1388-9:1981 Ethanol for industrial use -- Methods of test -- Part 9: Determination of esters content -- Titrimetric method after saponification
    ISO 1388-10:1981 Ethanol for industrial use -- Methods of test -- Part 10: Estimation of hydrocarbons content -- Distillation method
    ISO 1388-11:1981 Ethanol for industrial use -- Methods of test -- Part 11: Test for detection of furfural
    ISO 1388-12:1981 Ethanol for industrial use -- Methods of test -- Part 12: Determination of permanganate time
    ISO 1552:1976 Liquid chlorine for industrial use -- Method of sampling (for determining only the volumetric chlorine content)
    ISO 1686:1976 Sodium and potassium silicates for industrial use -- Samples and methods of test -- General
    ISO 1689:1976 Sodium and potassium silicates for industrial use -- Calculation of the ratio : silicon dioxide/sodium oxide or silicon dioxide/potassium oxide
    ISO 1690:1976 Sodium and potassium silicates for industrial use -- Determination of silica content -- Gravimetric method by insolubilization
    ISO 1691:1976 Sodium and potassium silicates for industrial use -- Determination of carbonates content -- Gas-volumetric method
    ISO 1692:1976 Sodium and potassium silicates for industrial use -- Determination of total alkalinity -- Titrimetric method
    ISO 1995:1981 Aromatic hydrocarbons -- Sampling
    ISO 2096:1972 Glycerols for industrial use -- Methods of sampling
    ISO 2120:1972 Liquid chlorine for industrial use -- Determination of the content of chlorine by volume in the vaporized product
    ISO 2121:1972 Liquid chlorine for industrial use -- Determination of water content -- Gravimetric method
    ISO 2122:1972 Sodium and potassium silicates for industrial use -- Preparation of solution of products not easily soluble in boiling water and determination of matter insoluble in water
    ISO 2197:1972 Sodium hydrogen carbonate for industrial use -- List of methods of test and preparation of the test sample
    ISO 2199:1972 Sodium hydrogen carbonate for industrial use -- Determination of sodium hydrogen carbonate content -- Titrimetric method
    ISO 2209:1973 Liquid halogenated hydrocarbons for industrial use -- Sampling
    ISO 2227:1972 Formaldehyde solutions for industrial use -- Determination of formaldehyde content
    ISO 2460:1973 Sodium hydrogen carbonate for industrial use -- Determination of iron content -- 1*10- Phenanthroline photometric method
    ISO 2461:1973 Sodium chlorate for industrial use -- Determination of matter insoluble in water
    ISO 2462:1973 Sodium chlorate for industrial use -- Determination of moisture content -- Gravimetric method
    ISO 2463:1973 Sodium chlorate for industrial use -- Determination of chloride content -- Mercurimetric method
    ISO 2466:1973 Potassium hydroxide for industrial use -- Sampling -- Test sample -- Preparation of the main solution for carrying out certain determinations
    ISO 2479:1972 Sodium chloride for industrial use -- Determination of matter insoluble in water or in acid and preparation of principal solutions for other determinations
    ISO 2480:1972 Sodium chloride for industrial use -- Determination of sulphate content -- Barium sulphate gravimetric method
    ISO 2481:1973 Sodium chloride for industrial use -- Determination of halogens* expressed as chlorine -- Mercurimetric method
    ISO 2482:1973 Sodium chloride for industrial use -- Determination of calcium and magnesium contents -- EDTA complexometric methods
    ISO 2483:1973 Sodium chloride for industrial use -- Determination of the loss of mass at 110 degrees C
    ISO 2762:1973 Hydrochloric acid for industrial use -- Determination of soluble sulphates -- Turbidimetric method
    ISO 2831:1973 Sodium fluoride for industrial use -- Determination of water-insoluble matter
    ISO 2832:1973 Sodium fluoride for industrial use -- Determination of moisture content
    ISO 2833:1973 Sodium fluoride for industrial use -- Determination of fluorine content -- Modified Willard-Winter method
    ISO 2992:1974 Ammonium sulphate for industrial use -- Determination of iron content -- 2*2'- Bipyridyl photometric method
    ISO 2993:1974 Ammonium sulphate for industrial use -- Determination of free acidity -- Titrimetric method
    ISO 2997:1974 Phosphoric acid for industrial use -- Determination of sulphate content -- Method by reduction and titrimetry
    ISO 3137:1974 Anhydrous hydrogen fluoride for industrial use -- Sampling
    ISO 3139:1976 Aqueous hydrofluoric acid for industrial use -- Sampling and methods of test
    ISO 3139:1976/Amd 1:1980 Aqueous hydrofluoric acid for industrial use -- Sampling and methods of test
    ISO 3165:1976 Sampling of chemical products for industrial use -- Safety in sampling
    ISO 3195:1975 Sodium hydroxide for industrial use -- Sampling -- Test Sample -- Preparation of the main solution for carrying out certain determinations
    ISO 3196:1975 Sodium hydroxide for industrial use -- Determination of carbonates content -- Titrimetric method
    ISO 3199:1975 Sodium chlorate for industrial use -- Determination of chlorate content -- Dichromate titrimetric method
    ISO 3332:1975 Ammonium sulphate for industrial use -- Determination of ammoniacal nitrogen content -- Titrimetric method after distillation
    ISO 3357:1975 Sodium tripolyphosphate and sodium pyrophosphate for industrial use -- Determination of total phosphorus(V) oxide content -- Quinoline phosphomolybdate gravimetric method
    ISO 3360:1976 Phosphoric acid and sodium phosphates for industrial use (including foodstuffs) -- Determination of fluorine content -- Alizarin complexone and lanthanum nitrate photometric method
    ISO 3363:1976 Fluorochlorinated hydrocarbons for industrial use -- Determination of acidity -- Titrimetric method
    ISO 3423:1975 Sulphuric acid and oleums for industrial use -- Determination of sulphur dioxide content -- Iodometric method
    ISO 3425:1975 Sulphur for industrial use -- Determination of ash at 850-900 degrees C and of residue at 200 degrees C
    ISO 3426:1975 Sulphur for industrial use -- Determination of loss in mass at 80 degrees C
    ISO 3427:1976 Gaseous halogenated hydrocarbons (liquefied gases) -- Taking of a sample
    ISO 3428:1976 Sodium fluoride for industrial use -- Preparation and storage of test samples
    ISO 3696:1987 Water for analytical laboratory use -- Specification and test methods
    ISO 3704:1976 Sulphur for industrial use -- Determination of acidity -- Titrimetric method
    ISO 3705:1976 Sulphur for industrial use -- Determination of arsenic content -- Silver diethyldithiocarbamate photometric method
    ISO 3706:1976 Phosphoric acid for industrial use (including foodstuffs) -- Determination of total phosphorus (V) oxide content -- Quinoline phosphomolybdate gravimetric method
    ISO 3707:1976 Phosphoric acid for industrial use (including foodstuffs) -- Determination of calcium content -- Flame atomic absorption method
    ISO 4281:1977 Sodium hexafluorosilicate for industrial use -- Determination of free acidity and total hexafluorosilicate content -- Titrimetric method
    ISO 4285:1977 Phosphoric acid for industrial use -- Guide to sampling techniques
    ISO 5272:1979 Toluene for industrial use -- Specifications
    ISO 5280:1979 Xylene for industrial use -- Specification
    ISO 5282:1982 Aromatic hydrocarbons -- Determination of sulphur content -- Pitt-Ruprecht reduction and spectrophotometric method
    ISO 5373:1981 Condensed phosphates for industrial use (including foodstuffs) -- Determination of calcium content -- Flame atomic absorption spectrometric method
    ISO 5440:1978 Sodium hexafluorosilicate for industrial use -- Determination of phosphate content -- Molybdovanadate spectrophotometric method
    ISO 5444:1978 Sodium fluorosilicate for industrial use -- Determination of loss in mass at 105 degrees C
    ISO 5789:1979 Fluorinated hydrocarbons for industrial use -- Determination of non-volatile residue
    ISO 5993:1979 Sodium hydroxide for industrial use -- Determination of mercury content -- Flameless atomic absorption spectrometric method
    ISO 6206:1979 Chemical products for industrial use -- Sampling -- Vocabulary
    ISO 6353-1:1982 Reagents for chemical analysis -- Part 1: General test methods
    ISO 6353-2:1983 Reagents for chemical analysis -- Part 2: Specifications -- First series
    ISO 6353-2:1983/Add 2:1986 Reagents for chemical analysis -- Part 2: Specifications -- First series
    ISO 6353-3:1987 Reagents for chemical analysis -- Part 3: Specifications -- Second series
    ISO 6796:1981 Polyglycols for industrial use -- Determination of hydroxyl number -- Phthalic anhydride esterification method
    ISO 7103:1982 Liquefied anhydrous ammonia for industrial use -- Sampling -- Taking a laboratory sample
    ISO 7105:1985 Liquefied anhydrous ammonia for industrial use -- Determination of water content -- Karl Fischer method
    ISO 7106:1985 Liquefied anhydrous ammonia for industrial use -- Determination of oil content -- Gravimetric and infra-red spectrometric methods
    ISO 7108:1985 Ammonia solution for industrial use -- Determination of ammonia content -- Titrimetric method
    ISO 7109:1985 Ammonia solution for industrial use -- Determination of residue after evaporation at 105 degrees C -- Gravimetric method
    ISO 7382:1986 Ethylene for industrial use -- Sampling in the liquid and the gaseous phase
    ISO 8174:1986 Ethylene and propylene for industrial use -- Determination of acetone* acetonitrile* propan-2-ol and methanol -- Gas chromatographic method
    ISO 8213:1986 Chemical products for industrial use -- Sampling techniques -- Solid chemical products in the form of particles varying from powders to coarse lumps
    ISO 8563:1987 Propylene and butadiene for industrial use -- Sampling in the liquid phase
    ISO 11014:2009 Safety data sheet for chemical products -- Content and order of sections
    General methods
    ISO 78-2:1999 Chemistry -- Layouts for standards -- Part 2: Methods of chemical analysis
    ISO 759:1981 Volatile organic liquids for industrial use -- Determination of dry residue after evaporation on water bath -- General method
    ISO 760:1978 Determination of water -- Karl Fischer method (General method)
    ISO 1392:1977 Determination of crystallizing point -- General method
    ISO 2211:1973 Liquid chemical products -- Measurement of colour in Hazen units (platinum-cobalt scale)
    ISO 6227:1982 Chemical products for industrial use -- General method for determination of chloride ions -- Potentiometric method
    ISO 6228:1980 Chemical products for industrial use -- General method for determination of traces of sulphur compounds* as sulphate* by reduction and titrimetry
    no missing standards here
    Re: ISO Collection 147/300: ISO/TC 47-Chemistry
    update:
    BQ:
    still complete
  1. Concrete Chemistry
    By Han Ah kwang in forum Civil & Structural Engineering
    Last Post: 02-26-2015, 07:54 PM
  2. Diazo chemistry II
    By dongono in forum General Engineering
    Last Post: 02-08-2015, 04:42 AM
  3. Water Chemistry
    By Nabilia in forum Electrical & Power Engineering
    Last Post: 05-20-2011, 06:20 PM
