Thread: ISO Collection 135/300: ISO/TC 256-Pigments* dyestuffs and extenders
    full list:
    ISO 473:1982 Lithopone pigments for paints -- Specifications and methods of test
    ISO 510:1977 Red lead for paints
    ISO 591-1:2000 Titanium dioxide pigments for paints -- Part 1: Specifications and methods of test
    ISO 787-1:1982 General methods of test for pigments and extenders -- Part 1: Comparison of colour of pigments
    ISO 787-2:1981 General methods of test for pigments and extenders -- Part 2: Determination of matter volatile at 105 degrees C
    ISO 787-3:2000 General methods of test for pigments and extenders -- Part 3: Determination of matter soluble in water -- Hot extraction method
    ISO 787-4:1981 General methods of test for pigments and extenders -- Part 4: Determination of acidity or alkalinity of the aqueous extract
    ISO 787-5:1980 General methods of test for pigments and extenders -- Part 5: Determination of oil absorption value
    ISO 787-7:2009 General methods of test for pigments and extenders -- Part 7: Determination of residue on sieve -- Water method -- Manual procedure
    ISO 787-8:2000 General methods of test for pigments and extenders -- Part 8: Determination of matter soluble in water -- Cold extraction method
    ISO 787-9:1981 General methods of test for pigments and extenders -- Part 9: Determination of pH value of an aqueous suspension
    ISO 787-10:1993 General methods of test for pigments and extenders -- Part 10: Determination of density -- Pyknometer method
    ISO 787-11:1981 General methods of test for pigments and extenders -- Part 11: Determination of tamped volume and apparent density after tamping
    ISO 787-13:2002 General methods of test for pigments and extenders -- Part 13: Determination of water-soluble sulfates* chlorides and nitrates
    ISO 787-14:2002 General methods of test for pigments and extenders -- Part 14: Determination of resistivity of aqueous extract
    ISO 787-15:1986 General methods of test for pigments and extenders -- Part 15: Comparison of resistance to light of coloured pigments of similar types
    ISO 787-16:1986 General methods of test for pigments and extenders -- Part 16: Determination of relative tinting strength (or equivalent colouring value) and colour on reduction of coloured pigments -- Visual comparison method
    ISO 787-17:2002 General methods of test for pigments and extenders -- Part 17: Comparison of lightening power of white pigments
    ISO 787-18:1983 General methods of test for pigments and extenders -- Part 18: Determination of residue on sieve -- Mechanical flushing procedure
    ISO 787-19:1974 General methods of test for pigments -- Part 19: Determination of water-soluble nitrates (Salicylic acid method)
    ISO 787-21:1979 General methods of test for pigments and extenders -- Part 21: Comparison of heat stability of pigments using a stoving medium
    ISO 787-22:1980 General methods of test for pigments and extenders -- Part 22: Comparison of resistance to bleeding of pigments
    ISO 787-23:1979 General methods of test for pigments and extenders -- Part 23: Determination of density (using a centrifuge to remove entrained air)
    ISO 787-24:1985 General methods of test for pigments and extenders -- Part 24: Determination of relative tinting strength of coloured pigments and relative scattering power of white pigments -- Photometric methods
    ISO 787-25:1993 General methods of test for pigments and extenders -- Part 25: Comparison of the colour* in full-shade systems* of white* black and coloured pigments -- Colorimetric method
    ISO 788:1974 Ultramarine pigments for paints
    ISO 1247:1974 Aluminium pigments for paints
    ISO 1247:1974/Amd 1:1982 Aluminium pigments for paints
    ISO 1248:2006 Iron oxide pigments -- Specifications and methods of test
    ISO 1248:2006/Cor 1:2007 Iron oxide pigments -- Specifications and methods of test
    ISO 1248:2006/Cor 2:2008 Iron oxide pigments -- Specifications and methods of test
    ISO 1249:1974 Zinc chromate pigments -- Basic zinc potassium chromate pigments and zinc tetrahydroxychromate pigments
    ISO 1249:1974/Cor 1:1992 Zinc chromate pigments -- Basic zinc potassium chromate pigments and zinc tetrahydroxychromate pigments
    ISO 2040:1972 Strontium chromate pigments for paints
    ISO 2068:1972 Barium chromate pigments for paints
    ISO 2495:1995 Iron blue pigments -- Specifications and methods of test
    ISO 3262-1:1997 Extenders for paints -- Specifications and methods of test -- Part 1: Introduction and general test methods
    ISO 3262-2:1998 Extenders for paints -- Specifications and methods of test -- Part 2: Barytes (natural barium sulfate)
    ISO 3262-3:1998 Extenders for paints -- Specifications and methods of test -- Part 3: Blanc fixe
    ISO 3262-4:1998 Extenders for paints -- Specifications and methods of test -- Part 4: Whiting
    ISO 3262-5:1998 Extenders for paints -- Specifications and methods of test -- Part 5: Natural crystalline calcium carbonate
    ISO 3262-6:1998 Extenders for paints -- Specifications and methods of test -- Part 6: Precipitated calcium carbonate
    ISO 3262-7:1998 Extenders for paints -- Specifications and methods of test -- Part 7: Dolomite
    ISO 3262-8:1999 Extenders for paints -- Specifications and methods of test -- Part 8: Natural clay
    ISO 3262-9:1997 Extenders for paints -- Specifications and methods of test -- Part 9: Calcined clay
    ISO 3262-10:2000 Extenders for paints -- Specifications and methods of test -- Part 10: Natural talc/chlorite in lamellar form
    ISO 3262-11:2000 Extenders for paints -- Specifications and methods of test -- Part 11: Natural talc* in lamellar form* containing carbonates
    ISO 3262-12:2001 Extenders for paints -- Specifications and methods of test -- Part 12: Muscovite-type mica
    ISO 3262-13:1997 Extenders for paints -- Specifications and methods of test -- Part 13: Natural quartz (ground)
    ISO 3262-14:2000 Extenders for paints -- Specifications and methods of test -- Part 14: Cristobalite
    ISO 3262-15:2000 Extenders for paints -- Specifications and methods of test -- Part 15: Vitreous silica
    ISO 3262-16:2000 Extenders for paints -- Specifications and methods of test -- Part 16: Aluminium hydroxides
    ISO 3262-17:2000 Extenders for paints -- Specifications and methods of test -- Part 17: Precipitated calcium silicate
    ISO 3262-18:2000 Extenders for paints -- Specifications and methods of test -- Part 18: Precipitated sodium aluminium silicate
    ISO 3262-19:2000 Extenders for paints -- Specifications and methods of test -- Part 19: Precipitated silica
    ISO 3262-20:2000 Extenders for paints -- Specifications and methods of test -- Part 20: Fumed silica
    ISO 3262-21:2000 Extenders for paints -- Specifications and methods of test -- Part 21: Silica sand (unground natural quartz)
    ISO 3262-22:2001 Extenders for paints -- Specifications and methods of test -- Part 22: Flux-calcined kieselguhr
    ISO 3549:1995 Zinc dust pigments for paints -- Specifications and test methods
    ISO 3711:1990 Lead chromate pigments and lead chromate-molybdate pigments -- Specifications and methods of test
    ISO 3856-1:1984 Paints and varnishes -- Determination of "soluble" metal content -- Part 1: Determination of lead content -- Flame atomic absorption spectrometric method and dithizone spectrophotometric method
    ISO 3856-2:1984 Paints and varnishes -- Determination of "soluble" metal content -- Part 2: Determination of antimony content -- Flame atomic absorption spectrometric method and Rhodamine B spectrophotometric method
    ISO 3856-3:1984 Paints and varnishes -- Determination of "soluble" metal content -- Part 3: Determination of barium content -- Flame atomic emission spectrometric method
    ISO 3856-4:1984 Paints and varnishes -- Determination of "soluble" metal content -- Part 4: Determination of cadmium content -- Flame atomic absorption spectrometric method and polarographic method
    ISO 3856-5:1984 Paints and varnishes -- Determination of "soluble" metal content -- Part 5: Determination of hexavalent chromium content of the pigment portion of the liquid paint or the paint in powder form -- Diphenylcarbazide spectrophotometric method
    ISO 3856-6:1984 Paints and varnishes -- Determination of "soluble" metal content -- Part 6: Determination of total chromium content of the liquid portion of the paint -- Flame atomic absorption spectrometric method
    ISO 3856-7:1984 Paints and varnishes -- Determination of "soluble" metal content -- Part 7: Determination of mercury content of the pigment portion of the paint and of the liquid portion of water-dilutable paints -- Flameless atomic absorption spectrometric method
    ISO 4620:1986 Cadmium pigments -- Specifications and methods of test
    ISO 4621:1986 Chrome oxide green pigments -- Specifications and methods of test
    ISO 6503:1984 Paints and varnishes -- Determination of total lead -- Flame atomic absorption spectrometric method
    ISO 6713:1984 Paints and varnishes -- Preparation of acid extracts from paints in liquid or powder form
    ISO 6745:1990 Zinc phosphate pigments for paints -- Specifications and methods of test
    ISO 7252:1984 Paints and varnishes -- Determination of total mercury -- Flameless atomic absorption spectrometric method
    ISO 7579:2009 Dyestuffs -- Determination of solubility in organic solvents -- Gravimetric and photometric methods
    ISO 8780-1:1990 Pigments and extenders -- Methods of dispersion for assessment of dispersion characteristics -- Part 1: Introduction
    ISO 8780-2:1990 Pigments and extenders -- Methods of dispersion for assessment of dispersion characteristics -- Part 2: Dispersion using an oscillatory shaking machine
    ISO 8780-3:1990 Pigments and extenders -- Methods of dispersion for assessment of dispersion characteristics -- Part 3: Dispersion using a high-speed impeller mill
    ISO 8780-4:1990 Pigments and extenders -- Methods of dispersion for assessment of dispersion characteristics -- Part 4: Dispersion using a bead mill
    ISO 8780-5:1990 Pigments and extenders -- Methods of dispersion for assessment of dispersion characteristics -- Part 5: Dispersion using an automatic muller
    ISO 8780-6:1990 Pigments and extenders -- Methods of dispersion for assessment of dispersion characteristics -- Part 6: Dispersion using a triple-roll mill
    ISO 8781-1:1990 Pigments and extenders -- Methods of assessment of dispersion characteristics -- Part 1: Assessment from the change in tinting strength of coloured pigments
    ISO 8781-2:1990 Pigments and extenders -- Methods of assessment of dispersion characteristics -- Part 2: Assessment from the change in fineness of grind
    ISO 8781-3:1990 Pigments and extenders -- Methods of assessment of dispersion characteristics -- Part 3: Assessment from the change in gloss
    ISO 10601:2007 Micaceous iron oxide pigments for paints -- Specifications and test methods
    ISO 18314-1:2015 Analytical colorimetry -- Part 1: Practical colour measurement
    ISO 18314-2:2015 Analytical colorimetry -- Part 2: Saunderson correction* solutions of the Kubelka-Munk equation* tinting strength* hiding power
    ISO 18314-3:2015 Analytical colorimetry -- Part 3: Special indices
    ISO 18451-1:2015 Pigments* dyestuffs and extenders -- Terminology -- Part 1: General terms
    ISO 18451-2:2015 Pigments* dyestuffs and extenders -- Terminology -- Part 2: Classification of colouring materials according to colouristic and chemical aspects
    ISO 18473-1:2015 Functional pigments and extenders for special applications -- Part 1: Nanoscale calcium carbonate for sealant application
    ISO 18473-2:2015 Functional pigments and extenders for special applications -- Part 2: Nanoscale titanium dioxide for sunscreen application
    ISO 23900-1:2015 Pigments and extenders -- Methods of dispersion and assessment of dispersibility in plastics -- Part 1: General introduction
    ISO 23900-2:2015 Pigments and extenders -- Methods of dispersion and assessment of dispersibility in plastics -- Part 2: Determination of colouristic properties and ease of dispersion in plasticized polyvinyl chloride by two-roll milling
    ISO 23900-3:2015 Pigments and extenders -- Methods of dispersion and assessment of dispersibility in plastics -- Part 3: Determination of colouristic properties and ease of dispersion of black and colour pigments in polyethylene by two-roll milling
    ISO 23900-4:2015 Pigments and extenders -- Methods of dispersion and assessment of dispersibility in plastics -- Part 4: Determination of colouristic properties and ease of dispersion of white pigments in polyethylene by two-roll milling
    ISO 23900-5:2015 Pigments and extenders -- Methods of dispersion and assessment of dispersibility in plastics -- Part 5: Determination by filter pressure value test
    ISO 23900-6:2015 Pigments and extenders -- Methods of dispersion and assessment of dispersibility in plastics -- Part 6: Determination by film test
    the missing one is:
    the link:
    Re: ISO Collection 135/300: ISO/TC 256-Pigments* dyestuffs and extenders
    update:
    added missing:
    En version:
    now it's complete!
  1. CEN Standards Collection 281/370: CEN TC 298-Pigments & Extenders
    Last Post: 07-12-2017, 01:36 AM
