Results 1 to 5 of 5
Thread: CEN Standards Collection 281/370: CEN TC 298-Pigments & Extenders
    complete:
    EN ISO 591-1:2000 Titanium dioxide pigments for paints - Part 1: Specifications and methods of test (ISO 591-1:2000)
    EN ISO 787-2:1995 General methods of test for pigments and extenders - Part 2: Determination of matter volatile at 105 degrees C (ISO 787-2:1981)
    EN ISO 787-3:2000 General methods of test for pigments and extenders - Part 3: Determination of matter soluble in water - Hot extraction method (ISO 787-3:2000)
    EN ISO 787-5:1995 General methods of test for pigments and extenders - Part 5: Determination of oil absorption value (ISO 787-5:1980)
    EN ISO 787-7:2009 General methods of test for pigments and extenders - Part 7: Determination of residue on sieve - Water method - Manual procedure (ISO 787-7:2009)
    EN ISO 787-8:2000 General methods of test for pigments and extenders - Part 8: Determination of matter soluble in water - Cold extraction method (ISO 787-8:2000)
    EN ISO 787-9:1995 General methods of test for pigments and extenders - Part 9: Determination of pH value of aqueous suspension (ISO 787-9:1981)
    EN ISO 787-10:1995 General methods of test for pigments and extenders - Part 10: Determination of density - Pycnometer method (ISO 787-10:1993)
    EN ISO 787-11:1995 General methods of test for pigments and extenders - Part 11: Determination of tamped volume and apparent density after tamping (ISO 787-11:1981)
    EN ISO 787-13:2002 General methods of test for pigments and extenders - Part 13: Determination of water-soluble sulfates, chlorides and nitrates (ISO 787-13:2002)
    EN ISO 787-14:2002 General methods of test for pigments and extenders - Part 14: Determination of resistivity of aqueous extract (ISO 787-14:2002)
    EN ISO 787-15:1995 General methods of test for pigments and extenders - Part 15: Comparison of resistance to light of coloured pigments of similar types (ISO 787-15:1986)
    EN ISO 787-16:1995 General methods of test for pigments and extenders - Part 16: Determination of relative tinting strength (or equivalent colouring value) and colour on reduction of coloured pigments - Visual comparison method (ISO 787-16:1986)
    EN ISO 787-18:1995 General methods of test for pigments and extenders - Part 18: Determination of residue on sieve - Mechanical flushing procedure (ISO 787-18:1983)
    EN ISO 787-19:1995 General methods of test for pigments - Part 19: Determination of water-soluble nitrates (Salicyclic acid method) (ISO 787-19:1974)
    EN ISO 787-23:1995 General method of tests for pigments and extenders - Part 23: Determination of density (using a centrifuge to remove entrained air) (ISO 787-23:1979)
    EN ISO 787-24:1995 General method of tests for pigments and extenders - Part 24: Determination of relative tinting strength of coloured pigments and relative scattering power of white pigments - Photometric methods (ISO 787-24:1985)
    EN ISO 787-25:2006 General methods of test for pigments and extenders - Part 25: Comparison of the colour, in full-shade systems, of white, black and coloured pigments - Colorimetric method (ISO 787-25:1993)
    EN ISO 1248:2008 Iron oxide pigments - Specifications and methods of test (ISO 1248:2006 including Technical Corrigendum 1:2007)
    EN ISO 1248:2008/AC:2009 Iron oxide pigments - Specifications and methods of test (ISO 1248:2006 including Technical Corrigendum 1:2007 and Cor 2:2008)
    EN ISO 2495:2000 Iron blue pigments - Specifications and methods of test (ISO 2495:1995)
    EN ISO 3262-1:1998 Extenders for paints - Specifications and methods of test - Part 1:Introduction and general test methods (ISO 3262-1:1997)
    EN ISO 3262-2:1998 Extenders for paints - Specifications and methods of test - Part 2: Baryte (natural barium sulfate) (ISO 3262-2:1998)
    EN ISO 3262-3:1998 Extenders for paints - Specifications and methods of test - Part 3: Blanc fixe (ISO 3262-3:1998)
    EN ISO 3262-4:1998 Extenders for paints - Specifications and methods of test - Part 4: Whiting (ISO 3262-4:1998)
    EN ISO 3262-5:1998 Extenders for paints - Specifications and methods of test - Part 5: Natural crystalline calcium carbonate (ISO 3262-5:1998)
    EN ISO 3262-6:1998 Extenders for paints - Specifications and methods of test - Part 6: Precipitated calcium carbonate (ISO 3262-6:1998)
    EN ISO 3262-7:1998 Extenders for paints - Specifications and methods of test - Part 7: Dolomite (ISO 3262-7:1998)
    EN ISO 3262-8:1999 Extenders for paints - Specifications and methods of test - Part 8: Natural clay (ISO 3262-8:1999)
    EN ISO 3262-9:1998 Extenders for paints - Specifications and methods of test - Part 9: Calcined clay (ISO 3262-9:1997)
    EN ISO 3262-10:2000 Extenders for paints - Specifications and methods of test - Part 10: Natural talc/chlorite in lamellar form (ISO 3262-10:2000)
    EN ISO 3262-11:2000 Extenders for paints - Specifications and methods of test - Part 11: Natural talc, in lamellar form, containing carbonates (ISO 3262-11:2000)
    EN ISO 3262-12:2001 Extenders for paints - Specifications and methods of test - Part 12: Muscovite-type mica (ISO 3262-12:2001)
    EN ISO 3262-13:1998 Extenders for paints - Specifications and methods of test - Part 13: Natural quartz (ground) (ISO 3262-13:1997)
    EN ISO 3262-14:2000 Extenders for paints - Specifications and methods of test - Part 14: Cristobalite (ISO 3262-14:2000)
    EN ISO 3262-15:2000 Extenders for paints - Specifications and methods of test - Part 15: Vitreous silica (ISO 3262-15:2000)
    EN ISO 3262-16:2000 Extenders for paints - Specifications and methods of test - Part 16: Aluminium hydroxides (ISO 3262-16:2000)
    EN ISO 3262-17:2000 Extenders for paints - Specifications and methods of test - Part 17: Precipitated calcium silicate (ISO 3262-17:2000)
    EN ISO 3262-18:2000 Extenders for paints - Specifications and methods of test - Part 18: Precipitated sodium aluminium silicate (ISO 3262-18:2000)
    EN ISO 3262-19:2000 Extenders for paints - Specifications and methods of test - Part 19: Precipitated silica (ISO 3262-19:2000)
    EN ISO 3262-20:2000 Extenders for paints - Specifications and methods of test - Part 20: Fumed silica (ISO 3262-20:2000)
    EN ISO 3262-21:2000 Extenders for paints - Specifications and methods of test - Part 21: Silica sand (unground natural quartz) (ISO 3262:2000)
    EN ISO 3262-22:2001 Extenders for paints - Specifications and methods of test - Part 22: Flux-calcined kieselguhr (ISO 3262-22:2001)
    EN ISO 3549:2002 Zinc dust pigments for paints - Specifications and test methods (ISO 3549:1995)
    EN ISO 7579:2009 Dyestuffs - Determination of solubility in organic solvents - Gravimetric and photometric methods (ISO 7579:2009)
    EN ISO 8780-1:1995 Pigments and extenders - Methods of dispersion for assessment of dispersion characteristics - Part 1: Introduction (ISO 8780-1:1990)
    EN ISO 8780-2:1995 Pigments and extenders - Methods of dispersion for assessment of dispersion characteristics - Part 2: Dispersion using an oscillatory shaking machine (ISO 8780-2:1990)
    EN ISO 8780-3:1995 Pigments and extenders - Methods of dispersion for assessment of dispersion characteristics - Part 3: Dispersion using a high-speed impeller mill (ISO 8780-3:1990)
    EN ISO 8780-4:1995 Pigments and extenders - Methods of dispersion for assessment of dispersion characteristics - Part 4: Dispersion using a bead mill (ISO 8780-4:1990)
    EN ISO 8780-5:1995 Pigments and extenders - Methods of dispersion for assessment of dispersion characteristics - Part 5: Dispersion using an automatic muller (ISO 8780-5:1990)
    EN ISO 8780-6:1995 Pigments and extenders - Methods of dispersion for assessment of dispersion characteristics - Part 6: Dispersion using a triple-roll mill (ISO 8780-6:1990)
    EN ISO 8781-1:1995 Pigments and extenders - Methods of assessment of dispersion characteristics - Part 1: Assessment from the change in tinting strength of coloured pigments (ISO 8781-1:1990)
    EN ISO 8781-2:1995 Pigments and extenders - Methods of assessment of dispersion characteristics - Part 2: Assessment from the change in fineness of grind (ISO 8781-2:1990)
    EN ISO 8781-3:1995 Pigments and extenders - Methods of assessment of dispersion characteristics - Part 3: Assessment from the change in gloss (ISO 8781-3:1990)
    EN ISO 10601:2008 Micaceous iron oxide pigments for paints - Specifications and test methods (ISO 10601:2007)
    EN 12877-1:1999 Colouring materials in plastics - Determination of colour stability to heat during processing of colouring materials in plastics - Part 1: General introduction
    EN 12877-2:1999 Colouring materials in plastics - Determination of colour stability to heat during processing of colouring materials in plastics - Part 2: Determination by injection moulding
    EN 12877-3:1999 Colouring materials in plastics - Determination of colour stability to heat during processing of colouring materials in plastics - Part 3: Determination by oven test
    EN 12877-4:1999 Colouring materials in plastics - Determination of colour stability to heat during processing of colouring materials in plastics - Part 4: Determination by two-roll milling
    EN 12878:2014 Pigments for the colouring of building materials based on cement and/or lime - Specifications and methods of test
    EN 13900-1:2003 Pigments and extenders - Methods of dispersion and assessment of dispersibility in plastics - Part 1: General introduction
    EN 13900-2:2003 Pigments and extenders - Methods of dispersion and assessment of dispersibility in plastics - Part 2: Determination of colouristic properties and ease of dispersion in plasticized polyvinyl chloride by two-roll milling
    EN 13900-3:2003 Pigments and extenders - Methods of dispersion and assessment of dispersibility in plastics - Part 3: Determination of colouristic properties and ease of dispersion of black and colour pigments in polyethylene by two-roll milling
    EN 13900-4:2004 Pigments and extenders - Methods of dispersion and assessment of dispersibility in plastics - Part 4: Determination of colouristic properties and ease of dispersion of white pigments in polyethylene by two-roll milling
    EN 13900-5:2005 Pigments and extenders - Methods of dispersion and assessment of dispersibility in plastics - Part 5: Determination by filter pressure value test
    EN 13900-6:2012 Pigments and extenders - Methods of dispersion and assessment of dispersability in plastics - Part 6: Determination by film test
    EN 14469-1:2004 Pigments and extenders - Testing of colouring materials in plasticized polyvinyl chloride (PVC-P) - Part 1: Composition and preparation of basic mixtures
    EN 14469-2:2004 Pigments and extenders - Testing of colouring materials in plasticized polyvinyl chloride (PVC-P) - Part 2: Preparation of test specimens
    EN 14469-3:2004 Pigments and extenders - Testing of colouring materials in plasticized polyvinyl chloride (PVC-P) - Part 3: Determination of the relative tinting strength of white pigments
    EN 14469-4:2004 Pigments and extenders - Testing of colouring materials in plasticized polyvinyl chloride (PVC-P) - Part 4: Determination of bleeding of colouring materials
    or
    Re: CEN Standards Collection 281/300: CEN TC 298-Pigments & Extenders
    just fresh links:
    or
    Re: CEN Standards Collection 281/340: CEN TC 298-Pigments & Extenders
    fresh links:
    or
    Re: CEN Standards Collection 281/350: CEN TC 298-Pigments & Extenders
    nothing changed, fresh links:
    or
    Re: CEN Standards Collection 281/370: CEN TC 298-Pigments & Extenders
    update:
    EN versions:
    still complete
  1. Replies: 2
    Last Post: 07-29-2017, 03:33 AM
  2. ISO Collection 135/300: ISO/TC 256-Pigments* dyestuffs and extenders
    Last Post: 07-08-2017, 11:58 PM
  3. CEN Standards collection - Missing standards
    Last Post: 03-24-2017, 12:08 AM
  4. Replies: 0
    Last Post: 12-31-2016, 04:12 AM
  5. CEN Standards Collection
    By Sajid Ali Khan in forum Mechanical Engineering
    Last Post: 06-12-2016, 12:55 AM
