451 Guidelines and Specifications for High-Reliability Fossil Power Plants* 2nd Edition Best Practice Guideline for Manufacturing and Construction of Grade 91 Steel Components
452 Application Guide for the Automation of Distribution Feeder Capacitors
453 Common Information Model Primer Third Edition
454 Report of the common information model (CIM) extensible markup language (XML) interoperability test # 1
455 Field Guide: Visual Inspection of Polymer Insulators
456 Maintenance work managemant – Best practice guidelines – Maintenance assessment and improvement
457 Tube Repair and Protection for Damage Caused by Sootblower Erosion
458 Pinch Technology/ Process Optimization
459 Water Treatment for Power Plant Cooling Towers: A supplement to the EPRI 2012 RFI for those unfamiliar with the power industry
460 Statistical analysis of steam generator tube degradation: Additional topics
461 Residential Electricity Use Feedback: A Research Synthesis and Economic Framework
462 Descriptions of Past Research Flow-Accelerated Corrosion
463 Infrared Thermography Guide (Revision 3)
464 Practical Guide to SF6 Handling Practices
465 BUDGETING FOR SOLAR PV PLANT OPERATIONS & MAINTENANCE: PRACTICES AND PRICING
466 EPRI Substation Grounding Project Summaries of Published Reports 1981–2011
467 Life Cycle Management Sourcebooks— Volume 10: Feedwater Heaters
468 Air-operated valve evaluation guide
469 Guidelines for Implementing Substation Automation Using IEC61850* the International Power System Information Modeling Standard
470 Increased Power Flow Guidebook Increasing Power Flow in Transmission and Substation Circuits
471 Interconnected Power System Dynamics Tutorial Dynamics of Interconnected Power Systems- Tutorial: Third Edition
472 T&D System Design and Construction for Enhanced Reliability and Power Quality
473 Outline of Guide for Application of Transmission Line Surge Arresters—42 to 765 kV
474 EPRI Power System Dynamics Tutorial
475 Proceedings: Fifth international conference on fossil plant cycle chemistry
