Require following standards urgently.
1. ASTM A36-14
2. ASTM A370-17
3. ASTM A193-16
4. ASTM A194-16a
5. ASTM F436-16
6. ASTM F3125 / F3125M - 15a
7. ASTM A325-14
8. ASTM A123 / A123M - 15
9. ASTM A153 / A153M - 16a
Thanks in advance
1. ASTM A36-14
2. ASTM A370-17
3. ASTM A193-16
4. ASTM A194-16a
5. ASTM F436-16
7. ASTM A325-14
Thanks in advance
urgently??? why?
Download Telegram from the Apple app store or the web* and go to the telegram GroupEgpet for the latest ASTM standards
Let me rant for a minute...If everyone who states that they "need" really need them then they have a budget to aquire them legitimately
Marco has posted archive files of all of the ASTMs that I have shared.
You have been on egpet since 2011 and posted only 2 times* where is your contribution?
OK* done with rant* I will share your request now.
A36A36M-14 Standard Specification for Carbon Structural Steel
A370-17 Standard Test Methods and Definitions for Mechanical Testing of Steel Products
A193A193M-16 Standard Specification for Alloy-Steel and Stainless Steel Bolting for High Temperature or High Pressure Service and Other Special Purpose Applications
A194A194M-16a Standard Specification for Carbon Steel* Alloy Steel* and Stainless Steel Nuts for Bolts for High Pressure or High Temperature Service* or Both
F436F436M-16 Standard Specification for Hardened Steel Washers Inch and Metric Dimensions
F3125F3125M-15a Standard Specification for High Strength Structural Bolts* Steel and Alloy Steel* Heat Treated* 120 ksi (830 MPa) and 150 ksi (1040 MPa) Minimum Tensile Strength* Inch and Metric Dimensions
A325-14 Standard Specification for Structural Bolts* Steel* Heat Treated* 120-105 ksi Minimum Tensile Strength - AASHTO No. M 164
A123A123M-15 Standard Specification for Zinc (Hot-Dip Galvanized) Coatings on Iron and Steel Products
A153A153M-16a Standard Specification for Zinc Coating (Hot-Dip) on Iron and Steel Hardware AASHTO No. M232
Sorry for not posting or contributing anything. I was recently transferred to material testing. Even i had joined this portal in 2011* i came to actively use this forum just now. Will keep posting whatever i have.
Thank you for the standards
Dear Friend
see here
Request to give ASTM A194-17a. Thanks.
Hi. Thank You everyone fro helping out. if any one could share ASTM A123 - 17 (latest)* I will really appreciate it.
see here
Dear Sir,
I need following standards if you please send me same;
ASTM E1359-17
astm e543-15
Friend thank you for uploading valuable documents. Very small request that when upload pl use "mediafire".
Again tanks in advance for great cooperation.
