hi
Some ASTM Standard, may be you want them !!
ASTM D2122-2004 : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
ASTM D2122-2004-2 : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
ASTM D2122-2004-3 : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
ASTM D2412-2008 : Standard Test Method for Determination of External Loading Characteristics of Plastic Pipe by Parallel-Plate Loading
ASTM D2412-2008-2 : Standard Test Method for Determination of External Loading Characteristics of Plastic Pipe by Parallel-Plate Loading
ASTM D2412-2008-3 : Standard Test Method for Determination of External Loading Characteristics of Plastic Pipe by Parallel-Plate Loading
ASTM D2657-2007 : Standard Practice for Heat Fusion Joining of Polyolefin Pipe and Fittings
ASTM D2657-2007-2 : Standard Practice for Heat Fusion Joining of Polyolefin Pipe and Fittings
ASTM D2657-2007-3 : Standard Practice for Heat Fusion Joining of Polyolefin Pipe and Fittings
ASTM D3350-2008 : Standard Specification for Polyethylene Plastics Pipe and Fittings Materials
ASTM D3350-2008-2 : Standard Specification for Polyethylene Plastics Pipe and Fittings Materials
ASTM D3350-2008-3 : Standard Specification for Polyethylene Plastics Pipe and Fittings Materials
ASTM F412-2009 : Standard Terminology Relating to Plastic Piping Systems
ASTM F412-2009-2 : Standard Terminology Relating to Plastic Piping Systems
ASTM F412-2009-3 : Standard Terminology Relating to Plastic Piping Systems
ASTM F477-2008- Part 1 : Standard Specification for Elastomeric Seals (Gaskets) for Joining Plastic Pipe
ASTM F477-2008- Part 2 : Standard Specification for Elastomeric Seals (Gaskets) for Joining Plastic Pipe
ASTM F477-2008- Part 3 : Standard Specification for Elastomeric Seals (Gaskets) for Joining Plastic Pipe
ASTM F1759-2004-Part 1 : Standard Practice for Design of High-Density Polyethylene (HDPE) Manholes for Subsurface Applications1
ASTM F1759-2004-Part 2 : Standard Practice for Design of High-Density Polyethylene (HDPE) Manholes for Subsurface Applications1
ASTM F1759-2004-Part 3 : Standard Practice for Design of High-Density Polyethylene (HDPE) Manholes for Subsurface Applications1
ASTM_D_2122_(2010) : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
ASTM_D_2466_(2013) : Standard Specification for Poly Vinyl Chloride (PVC) Plastic Pipe Fittings, Schedule 40
ASTM_D1598_(2009) : Standard Test Method for Time-to-Failure of Plastic Pipe Under Constant Internal Pressure
ASTM_D1784_(2011) : Standard Specification for Rigid Poly Vinyl Chloride (PVC) Compounds and Chlorinated Poly Vinyl Chloride (CPVC) Compounds
ASTM A105
ASTM A182:2010
ASTM A370:2010
