Steel tubes
ISO 65:1981 Carbon steel tubes suitable for screwing in accordance with ISO 7-1
ISO 559:1991 Steel tubes for water and sewage
ISO 1127:1992 Stainless steel tubes -- Dimensions* tolerances and conventional masses per unit length
ISO 1129:1980 Steel tubes for boilers* superheaters and heat exchangers -- Dimensions* tolerances and conventional masses per unit length
ISO 2037:1992 Stainless steel tubes for the food industry
ISO 2851:1993 Stainless steel bends and tees for the food industry
ISO 2852:1993 Stainless steel clamp pipe couplings for the food industry
ISO 2853:1993 Stainless steel threaded couplings for the food industry
ISO 2937:1974 Plain end seamless steel tubes for mechanical application
ISO 2938:1974 Hollow steel bars for machining
ISO 3304:1985 Plain end seamless precision steel tubes -- Technical conditions for delivery
ISO 3305:1985 Plain end welded precision steel tubes -- Technical conditions for delivery
ISO 3306:1985 Plain end as-welded and sized precision steel tubes -- Technical conditions for delivery
ISO 3545-1:1989 Steel tubes and fittings -- Symbols for use in specifications -- Part 1: Tubes and tubular accessories with circular cross-section
ISO 3545-2:1989 Steel tubes and fittings -- Symbols for use in specifications -- Part 2: Square and rectangular hollow sections
ISO 3545-3:1989 Steel tubes and fittings -- Symbols for use in specifications -- Part 3: Tubular fittings with circular cross-section
ISO 4200:1991 Plain end steel tubes* welded and seamless -- General tables of dimensions and masses per unit length
ISO 5252:1991 Steel tubes -- Tolerance systems
ISO 5256:1985 Steel pipes and fittings for buried or submerged pipe lines -- External and internal coating by bitumen or coal tar derived materials
ISO 6761:1981 Steel tubes -- Preparation of ends of tubes and fittings for welding
ISO 7598:1988 Stainless steel tubes suitable for screwing in accordance with ISO 7-1
ISO 9095:1990 Steel tubes -- Continuous character marking and colour coding for material identification
ISO 10799-1:2011 Cold-formed welded structural hollow sections of non-alloy and fine grain steels -- Part 1: Technical delivery conditions
ISO 10799-2:2011 Cold-formed welded structural hollow sections of non-alloy and fine grain steels -- Part 2: Dimensions and sectional properties
ISO 12633-1:2011 Hot-finished structural hollow sections of non-alloy and fine grain steels -- Part 1: Technical delivery conditions
Cast iron pipes* fittings and their joints
ISO 2531:2009 Ductile iron pipes* fittings* accessories and their joints for water applications
ISO 2531:2009/Cor 1:2010 Ductile iron pipes* fittings* accessories and their joints for water applications
ISO 4179:2005 Ductile iron pipes and fittings for pressure and non-pressure pipelines -- Cement mortar lining
ISO 6594:2006 Cast iron drainage pipes and fittings -- Spigot series
ISO 7186:2011 Ductile iron products for sewerage applications
ISO 8179-1:2004 Ductile iron pipes -- External zinc-based coating -- Part 1: Metallic zinc with finishing layer
ISO 8179-2:1995 Ductile iron pipes -- External zinc coating -- Part 2: Zinc rich paint with finishing layer
ISO 8180:2006 Ductile iron pipelines -- Polyethylene sleeving for site application
ISO 9349:2004 Preinsulated ductile iron pipeline systems
ISO 10802:1992 Ductile iron pipelines -- Hydrostatic testing after installation
ISO 10803:2011 Design method for ductile iron pipes
ISO 10804:2010 Restrained joint systems for ductile iron pipelines -- Design rules and type testing
ISO 13470:2012 Trenchless applications of ductile iron pipes systems -- Product design and installation
ISO 16132:2016 Ductile iron pipes and fittings -- Seal coats for cement mortar linings
ISO 16134:2006 Earthquake- and subsidence-resistant design of ductile iron pipelines
ISO 16631:2016 Ductile iron pipes* fittings* accessories and their joints compatible with plastic (PVC or PE) piping systems* for water applications and for plastic pipeline connections* repair and replacement
Threaded fittings* solder fittings* welding fittings* pipe threads* thread gauges
ISO 7-1:1994 Pipe threads where pressure-tight joints are made on the threads -- Part 1: Dimensions* tolerances and designation
ISO 7-1:1994/Cor 1:2007 Pipe threads where pressure-tight joints are made on the threads -- Part 1: Dimensions* tolerances and designation
ISO 7-2:2000 Pipe threads where pressure-tight joints are made on the threads -- Part 2: Verification by means of limit gauges
ISO 49:1994 Malleable cast iron fittings threaded to ISO 7-1
ISO 49:1994/Cor 1:1997 Malleable cast iron fittings threaded to ISO 7-1
ISO 228-1:2000 Pipe threads where pressure-tight joints are not made on the threads -- Part 1: Dimensions* tolerances and designation
ISO 228-2:1987 Pipe threads where pressure-tight joints are not made on the threads -- Part 2: Verification by means of limit gauges
ISO 2016:1981 Capillary solder fittings for copper tubes -- Assembly dimensions and tests
ISO 3419:1981 Non-alloy and alloy steel butt-welding fittings
ISO 4144:2003 Pipework -- Stainless steel fittings threaded in accordance with ISO 7-1
ISO 4145:1986 Non-alloy steel fittings threaded to ISO 7-1
ISO 5251:1981 Stainless steel butt-welding fittings
Metallic flanges and their joints
ISO 6708:1995 Pipework components -- Definition and selection of DN (nominal size)
ISO 7005-1:2011 Pipe flanges -- Part 1: Steel flanges for industrial and general service piping systems
ISO 7005-2:1988 Metallic flanges -- Part 2: Cast iron flanges
ISO 7005-3:1988 Metallic flanges -- Part 3: Copper alloy and composite flanges
ISO 7268:1983 Pipe components -- Definition of nominal pressure
ISO 7268:1983/Amd 1:1984 Pipe components -- Definition of nominal pressure
ISO 7483:1991 Dimensions of gaskets for use with flanges to ISO 7005
ISO 7483:1991/Cor 1:1995 Dimensions of gaskets for use with flanges to ISO 7005
Metal hoses and expansion joints
Reference Title
ISO 7369:2004 Pipework -- Metal hoses and hose assemblies -- Vocabulary
ISO 10380:2012 Pipework -- Corrugated metal hoses and hose assemblies
ISO 10806:2003 Pipework -- Fittings for corrugated metal hoses
ISO 10807:1994 Pipework -- Corrugated flexible metallic hose assemblies for the protection of electrical cables in explosive atmospheres
ISO 15465:2004 Pipework -- Stripwound metal hoses and hose assemblies
missing are:
links:
or
