Standards and projects under the direct responsibility of ISO/TC 114 Secretariat
ISO 1112:2009 Horology -- Functional and non-functional jewels
ISO 3158:1976 Timekeeping instruments -- Symbolization of control positions
ISO 3159:2009 Timekeeping instruments -- Wrist-chronometers with spring balance oscillator
ISO 12819:2009 Methods of evaluation of the battery life of a battery-powered watch
ISO 13074:2012 Analogue quartz clocks -- Fitting dimensions of movements to hands
ISO/TS 18684:2015 Timekeeping instruments -- Watch external parts made of hard materials -- General requirements and test methods
IEC 60086-3:2016 Primary batteries -- Part 3: Watch batteries
Shock resistant watches
ISO 1413:2016 Horology -- Shock-resistant wrist watches
Water-resistant watches
ISO 6425:1996 Divers' watches
ISO 22810:2010 Horology -- Water-resistant watches
Luminescence
ISO 3157:1991 Radioluminescence for time measurement instruments -- Specifications
ISO 4168:2002 Timekeeping instruments -- Conditions for carrying out checks on radioluminescent deposits
ISO 17514:2004 Time-measuring instruments -- Photoluminescent deposits -- Test methods and requirements
Precious metal coverings
ISO 3160-1:1998 Watch-cases and accessories -- Gold alloy coverings -- Part 1: General requirements
ISO 3160-1:1998/Amd 1:2000 Watch-cases and accessories -- Gold alloy coverings -- Part 1: General requirements
ISO 3160-2:2015 Watch-cases and accessories -- Gold alloy coverings -- Part 2: Determination of fineness* thickness* corrosion resistance and adhesion
ISO 16253:2007 Watch-cases and accessories -- Vapour phase deposited coatings
ISO 23160:2011 Watch cases and accessories -- Tests of the resistance to wear* scratching and impacts
Overall dimensions
ISO 3764:2016 Timekeeping instruments -- Movements -- Types* dimensions and nomenclature
ISO 3765:1998 Timekeeping instruments -- Wristwatches -- Dimensions of bracelet-to-case fastening elements
ISO 10552:2014 Timekeeping instruments -- Crowns and sealed tubes -- Designs and dimensions
ISO 14856:2001 Timekeeping instruments -- Wristwatch-cases -- Fixing dimensions of non-spring-bar types
Technical definitions
ISO 6426-1:1982 Horological vocabulary -- Part 1: Technical and scientific definitions
ISO 6426-2:2002 Horological vocabulary -- Part 2: Technical and commercial definitions
ISO 6426-2:2002/Amd 1:2012 Horological vocabulary -- Part 2: Technical and commercial definitions
ISO 6426-2:2002/Cor 1:2003 Horological vocabulary -- Part 2: Technical and commercial definitions
Indication of accuracy
ISO 10553:2003 Horology -- Procedure for evaluating the accuracy of quartz watches
Antimagnetism
ISO 764:2002 Horology -- Magnetic resistant watches
Watch-glasses
ISO 14368-1:2000 Mineral and sapphire watch-glasses -- Part 1: Dimensions and tolerances
ISO 14368-1:2000/Cor 1:2006 Mineral and sapphire watch-glasses -- Part 1: Dimensions and tolerances
ISO 14368-2:2003 Mineral and sapphire watch-glasses -- Part 2: Assembly to the case by adhesive or using a gasket
ISO 14368-3:2003 Mineral and sapphire watch-glasses -- Part 3: Qualitative criteria and test methods
Table and wall clocks
ISO 19235:2015 Analogue quartz clocks -- Timing accuracy
and the missing are:
links:
or
