Results 1 to 10 of 10
Thread: ISO Collection 78/300:ISO/TC 58 - Gas cylinders
    Standards and projects under the direct responsibility of ISO/TC 58 Secretariat
    ISO 3807:2013 Gas cylinders -- Acetylene cylinders -- Basic requirements and type testing
    ISO 10286:2015 Gas cylinders -- Terminology
    ISO 11114-1:2012 Gas cylinders -- Compatibility of cylinder and valve materials with gas contents -- Part 1: Metallic materials
    ISO 11114-2:2013 Gas cylinders -- Compatibility of cylinder and valve materials with gas contents -- Part 2: Non-metallic materials
    ISO 11114-3:2010 Gas cylinders -- Compatibility of cylinder and valve materials with gas contents -- Part 3: Autogenous ignition test for non-metallic materials in oxygen atmosphere
    ISO 11114-4:2005 Transportable gas cylinders -- Compatibility of cylinder and valve materials with gas contents -- Part 4: Test methods for selecting metallic materials resistant to hydrogen embrittlement
    ISO/TR 11364:2012 Gas cylinders -- Compilation of national and international valve stem/gas cylinder neck threads and their identification and marking system
    ISO 13341:2010 Gas cylinders -- Fitting of valves to gas cylinders
    ISO 13341:2010/AMD 1:2015 Gas cylinders -- Fitting of valves to gas cylinders
    ISO/TR 14600:2000 Gas cylinders -- International quality conformance system -- Basic rules
    Cylinder fittings
    ISO 407:2004 Small medical gas cylinders -- Pin-index yoke-type valve connections
    ISO 5145:2014 Cylinder valve outlets for gases and gas mixtures -- Selection and dimensioning
    ISO/TR 7470:1988 Valve outlets for gas cylinders -- List of provisions which are either standardized or in use
    ISO 10156:2010 Gases and gas mixtures -- Determination of fire potential and oxidizing ability for the selection of cylinder valve outlets
    ISO 10156:2010/COR 1:2010 Gases and gas mixtures -- Determination of fire potential and oxidizing ability for the selection of cylinder valve outlets
    ISO 10297:2014 Gas cylinders -- Cylinder valves -- Specification and type testing
    ISO 10298:2010 Determination of toxicity of a gas or gas mixture
    ISO 10692-1:2001 Gas cylinders -- Gas cylinder valve connections for use in the micro-electronics industry -- Part 1: Outlet connections
    ISO 10692-2:2001 Gas cylinders -- Gas cylinder valve connections for use in the micro-electronics industry -- Part 2: Specification and type testing for valve to cylinder connections
    ISO 11117:2008 Gas cylinders -- Valve protection caps and valve guards -- Design, construction and tests
    ISO 11363-1:2010 Gas cylinders -- 17E and 25E taper threads for connection of valves to gas cylinders -- Part 1: Specifications
    ISO 11363-1:2010/COR 2:2012 Gas cylinders -- 17E and 25E taper threads for connection of valves to gas cylinders -- Part 1: Specifications
    ISO 11363-2:2010 Gas cylinders -- 17E and 25E taper threads for connection of valves to gas cylinders -- Part 2: Inspection gauges
    ISO 12209:2013 Gas cylinders -- Outlet connections for gas cylinder valves for compressed breathable air
    ISO 13338:1995 Determination of tissue corrosiveness of a gas or gas mixture
    ISO 14245:2006 Gas cylinders -- Specifications and testing of LPG cylinder valves -- Self-closing
    ISO 14246:2014 Gas cylinders -- Cylinder valves -- Manufacturing tests and examinations
    ISO 14456:2015 Gas cylinders -- Gas properties and associated classification (FTSC) codes
    ISO 15245-1:2001 Gas cylinders -- Parallel threads for connection of valves to gas cylinders -- Part 1: Specification
    ISO 15245-1:2001/AMD 1:2013 Gas cylinders -- Parallel threads for connection of valves to gas cylinders -- Part 1: Specification
    ISO 15245-2:2001 Gas cylinders -- Parallel threads for connection of valves to gas cylinders -- Part 2: Gauge inspection
    ISO 15995:2006 Gas cylinders -- Specifications and testing of LPG cylinder valves -- Manually operated
    ISO 15996:2005 Gas cylinders -- Residual pressure valves -- General requirements and type testing
    ISO 15996:2005/AMD 1:2007 Gas cylinders -- Residual pressure valves -- General requirements and type testing
    ISO 16964:2015 Gas cylinders -- Flexible hoses assemblies -- Specification and testing
    ISO 17871:2015 Gas cylinders -- Quick-release cylinder valves -- Specification and type testing
    ISO 22434:2006 Transportable gas cylinders -- Inspection and maintenance of cylinder valves
    ISO 22435:2007 Gas cylinders -- Cylinder valves with integrated pressure regulators -- Specification and type testing
    ISO 22435:2007/AMD 1:2012 Gas cylinders -- Cylinder valves with integrated pressure regulators -- Specification and type testing
    Cylinder design
    ISO 3500:2005 Gas cylinders -- Seamless steel CO2 cylinders for fixed fire-fighting installations on ships
    ISO 3500:2005/AMD 1:2010 Gas cylinders -- Seamless steel CO2 cylinders for fixed fire-fighting installations on ships
    ISO 4706:2008 Gas cylinders -- Refillable welded steel cylinders -- Test pressure 60 bar and below
    ISO 7866:2012 Gas cylinders -- Refillable seamless aluminium alloy gas cylinders -- Design, construction and testing
    ISO 7866:2012/COR 1:2014 Gas cylinders -- Refillable seamless aluminium alloy gas cylinders -- Design, construction and testing
    ISO 9809-1:2010 Gas cylinders -- Refillable seamless steel gas cylinders -- Design, construction and testing -- Part 1: Quenched and tempered steel cylinders with tensile strength less than 1 100 MPa
    ISO 9809-2:2010 Gas cylinders -- Refillable seamless steel gas cylinders -- Design, construction and testing -- Part 2: Quenched and tempered steel cylinders with tensile strength greater than or equal to 1 100 MPa
    ISO 9809-3:2010 Gas cylinders -- Refillable seamless steel gas cylinders -- Design, construction and testing -- Part 3: Normalized steel cylinders
    ISO 9809-4:2014 Gas cylinders -- Refillable seamless steel gas cylinders -- Design, construction and testing -- Part 4: Stainless steel cylinders with an Rm value of less than 1 100 MPa
    ISO 11118:2015 Gas cylinders -- Non-refillable metallic gas cylinders -- Specification and test methods
    ISO 11119-1:2012 Gas cylinders -- Refillable composite gas cylinders and tubes -- Design, construction and testing -- Part 1: Hoop wrapped fibre reinforced composite gas cylinders and tubes up to 450 l
    ISO 11119-2:2012 Gas cylinders -- Refillable composite gas cylinders and tubes -- Design, construction and testing -- Part 2: Fully wrapped fibre reinforced composite gas cylinders and tubes up to 450 l with load-sharing metal liners
    ISO 11119-2:2012/AMD 1:2014 Gas cylinders -- Refillable composite gas cylinders and tubes -- Design, construction and testing -- Part 2: Fully wrapped fibre reinforced composite gas cylinders and tubes up to 450 l with load-sharing metal liners
    ISO 11119-3:2013 Gas cylinders -- Refillable composite gas cylinders and tubes -- Design, construction and testing -- Part 3: Fully wrapped fibre reinforced composite gas cylinders and tubes up to 450L with non-load-sharing metallic or non-metallic liners
    ISO 11119-4:2016 Gas cylinders -- Refillable composite gas cylinders -- Design, construction and testing -- Part 4: Fully wrapped fibre reinforced composite gas cylinders up to 150 l with load-sharing welded metallic liners
    ISO 11120:2015 Gas cylinders -- Refillable seamless steel tubes of water capacity between 150 l and 3000 l -- Design, construction and testing
    ISO 11439:2013 Gas cylinders -- High pressure cylinders for the on-board storage of natural gas as a fuel for automotive vehicles
    ISO 11513:2011 Gas cylinders -- Refillable welded steel cylinders containing materials for sub-atmospheric gas packaging (excluding acetylene) -- Design, construction, testing, use and periodic inspection
    ISO 11515:2013 Gas cylinders -- Refillable composite reinforced tubes of water capacity between 450 L and 3000 L -- Design, construction and testing
    ISO/TR 12391-1:2001 Gas cylinders -- Refillable seamless steel -- Performance tests -- Part 1: Philosophy, background and conclusions
    ISO/TR 12391-2:2002 Gas cylinders -- Refillable seamless steel -- Performance tests -- Part 2: Fracture performance tests -- Monotonic burst tests
    ISO/TR 12391-3:2002 Gas cylinders -- Refillable seamless steel -- Performance tests -- Part 3: Fracture performance tests -- Cyclical burst tests
    ISO/TR 12391-4:2002 Gas cylinders -- Refillable seamless steel -- Performance tests -- Part 4: Flawed-cylinder cycle test
    ISO/TR 13086-1:2011 Gas cylinders - Guidance for design of composite cylinders -- Part 1: Stress rupture of fibres and burst ratios related to test pressure
    ISO/TR 16115:2013 Gas cylinders -- Classification of imperfections arising during the manufacture of seamless steel and aluminium alloy gas cylinders
    ISO 18172-1:2007 Gas cylinders -- Refillable welded stainless steel cylinders -- Part 1: Test pressure 6 MPa and below
    ISO 18172-2:2007 Gas cylinders -- Refillable welded stainless steel cylinders -- Part 2: Test pressure greater than 6 MPa
    ISO 20703:2006 Gas cylinders -- Refillable welded aluminium-alloy cylinders -- Design, construction and testing
    ISO 21172-1:2015 Gas cylinders -- Welded steel pressure drums up to 3 000 litres capacity for the transport of gases -- Design and construction -- Part 1: Capacities up to 1 000 litres
    ISO 22991:2004 Gas cylinders -- Transportable refillable welded steel cylinders for liquefied petroleum gas (LPG) -- Design and construction
    Operational requirements for gas cylinders
    ISO 32:1977 Gas cylinders for medical use -- Marking for identification of content
    ISO 6406:2005 Gas cylinders -- Seamless steel gas cylinders -- Periodic inspection and testing
    ISO 7225:2005 Gas cylinders -- Precautionary labels
    ISO 7225:2005/AMD 1:2012 Gas cylinders -- Precautionary labels
    ISO 10460:2005 Gas cylinders -- Welded carbon-steel gas cylinders -- Periodic inspection and testing
    ISO 10461:2005 Gas cylinders -- Seamless aluminium-alloy gas cylinders -- Periodic inspection and testing
    ISO 10461:2005/AMD 1:2006 Gas cylinders -- Seamless aluminium-alloy gas cylinders -- Periodic inspection and testing
    ISO 10462:2013 Gas cylinders -- Acetylene cylinders -- Periodic inspection and maintenance
    ISO 10464:2004 Gas cylinders -- Refillable welded steel cylinders for liquefied petroleum gas (LPG) -- Periodic inspection and testing
    ISO 10691:2004 Gas cylinders -- Refillable welded steel cylinders for liquified petroleum gas (LPG) -- Procedures for checking before, during and after filling
    ISO 10961:2010 Gas cylinders -- Cylinder bundles -- Design, manufacture, testing and inspection
    ISO 11372:2011 Gas cylinders -- Acetylene cylinders -- Filling conditions and filling inspection
    ISO 11621:1997 Gas cylinders -- Procedures for change of gas service
    ISO 11623:2015 Gas cylinders -- Composite construction -- Periodic inspection and testing
    ISO 11625:2007 Gas cylinders -- Safe handling
    ISO 11755:2005 Gas cylinders -- Cylinder bundles for compressed and liquefied gases (excluding acetylene) -- Inspection at time of filling
    ISO 13088:2011 Gas cylinders -- Acetylene cylinder bundles -- Filling conditions and filling inspection
    ISO 13769:2007 Gas cylinders -- Stamp marking
    ISO 13770:1997 Aluminium alloy gas cylinders -- Operational requirements for avoidance of neck and shoulder *****s
    ISO 16148:2016 Gas cylinders -- Refillable seamless steel gas cylinders and tubes -- Acoustic emission examination (AT) and follow-up ultrasonic examination (UT) for periodic inspection and testing
    ISO/TR 17329:2015 Gas cylinders -- Identification of gas cylinder manufacturer marks and their assigned radio frequency identification (RFID) codes
    ISO 19078:2013 Gas cylinders -- Inspection of the cylinder installation, and requalification of high pressure cylinders for the on-board storage of natural gas as a fuel for automotive vehicles
    ISO 21007-1:2005 Gas cylinders -- Identification and marking using radio frequency identification technology -- Part 1: Reference architecture and terminology
    ISO 21007-2:2015 Gas cylinders -- Identification and marking using radio frequency identification technology -- Part 2: Numbering schemes for radio frequency identification
    ISO/TR 22694:2008 Gas cylinders -- Methods for establishing acceptance/rejection criteria for flaws in seamless steel and aluminium alloy cylinders at time of periodic inspection and testing
    ISO 24431:2016 Gas cylinders -- Seamless, welded and composite cylinders for compressed and liquefied gases (excluding acetylene) -- Inspection at time of filling
    ISO 25760:2009 Gas cylinders -- Operational procedures for the safe removal of valves from gas cylinders
    the missing are:
    links:
    or
    Re: ISO/TC 58 - Gas cylinders
    Dear BornToSin,
    Many thanks for shared
    Re: ISO Collection 78/300:ISO/TC 58 - Gas cylinders
    just one more new goes to missing list:
    ISO 12209:2013/AMD 1:2016 Outlet connection up to a maximum cylinder working pressure of 500 bar
    ISO 24431:2016 Gas cylinders -- Seamless* welded and composite cylinders for compressed and liquefied gases (excluding acetylene) -- Inspection at time of filling
    anyway* fresh link:
    update:
    better quality:
    ISO 11119-2:2012/AMD 1:2014 Gas cylinders -- Refillable composite gas cylinders and tubes -- Design* construction and testing -- Part 2: Fully wrapped fibre reinforced composite gas cylinders and tubes up to 450 l with load-sharing metal liners
    added missing:
    new missing list:
    ISO 11114-1:2012/AMD 1:2017 Gas cylinders -- Compatibility of cylinder and valve materials with gas contents -- Part 1: Metallic materials
    ISO 11114-4:2017 Transportable gas cylinders -- Compatibility of cylinder and valve materials with gas contents -- Part 4: Test methods for selecting steels resistant to hydrogen embrittlement
    ISO 10297:2014/AMD 1:2017 Pressure drums and tubes
    ISO/TS 15453:2017 Gas cylinders -- Seamless steel and aluminium-alloy gas cylinders -- Evaluation of existing gas cylinders and consideration of their safe use in other jurisdictions
    I need Australian standard AS 4332 - The storage and handling of gases in cylinders.
    Please upload
    will try to get it for you next week* cause in the moment I'm little bit helpless with updating standards/uploading new standards cause my PC is on the repair* so until I get it back..will upload just books
    Thanks BornToSin!
    full list 26.11.2017:
    ISO 10156:2017 Gas cylinders -- Gases and gas mixtures -- Determination of fire potential and oxidizing ability for the selection of cylinder valve outlets
    ISO 11117:2008 Gas cylinders -- Valve protection caps and valve guards -- Design* construction and tests
    ISO 11363-2:2017 Gas cylinders -- 17E and 25E taper threads for connection of valves to gas cylinders -- Part 2: Inspection gauges
    ISO 13338:2017 Gas cylinders -- Gases and gas mixtures -- Determination of tissue corrosiveness for the selection of cylinder valve outlets
    ISO 14246:2014/AMD 1:2017 Gas cylinders -- Cylinder valves -- Manufacturing tests and examinations
    ISO 15996:2017 Gas cylinders -- Residual pressure valves -- Specification and type testing of cylinder valves incorporating residual pressure devices
    ISO 16945:2015 Gas cylinders -- Flexible hoses assemblies -- Specification and testing
    ISO 17879:2017 Gas cylinders -- Self-closing cylinder valves -- Specification and type testing
    ISO 7866:2012 Gas cylinders -- Refillable seamless aluminium alloy gas cylinders -- Design* construction and testing
    ISO 7866:2012/COR 1:2014 Gas cylinders -- Refillable seamless aluminium alloy gas cylinders -- Design* construction and testing
    ISO 9809-1:2010 Gas cylinders -- Refillable seamless steel gas cylinders -- Design* construction and testing -- Part 1: Quenched and tempered steel cylinders with tensile strength less than 1 100 MPa
    ISO 9809-2:2010 Gas cylinders -- Refillable seamless steel gas cylinders -- Design* construction and testing -- Part 2: Quenched and tempered steel cylinders with tensile strength greater than or equal to 1 100 MPa
    ISO 9809-3:2010 Gas cylinders -- Refillable seamless steel gas cylinders -- Design* construction and testing -- Part 3: Normalized steel cylinders
    ISO 9809-4:2014 Gas cylinders -- Refillable seamless steel gas cylinders -- Design* construction and testing -- Part 4: Stainless steel cylinders with an Rm value of less than 1 100 MPa
    ISO 11119-1:2012 Gas cylinders -- Refillable composite gas cylinders and tubes -- Design* construction and testing -- Part 1: Hoop wrapped fibre reinforced composite gas cylinders and tubes up to 450 l
    ISO 11119-2:2012 Gas cylinders -- Refillable composite gas cylinders and tubes -- Design* construction and testing -- Part 2: Fully wrapped fibre reinforced composite gas cylinders and tubes up to 450 l with load-sharing metal liners
    ISO 11119-3:2013 Gas cylinders -- Refillable composite gas cylinders and tubes -- Design* construction and testing -- Part 3: Fully wrapped fibre reinforced composite gas cylinders and tubes up to 450L with non-load-sharing metallic or non-metallic liners
    ISO 11119-4:2016 Gas cylinders -- Refillable composite gas cylinders -- Design* construction and testing -- Part 4: Fully wrapped fibre reinforced composite gas cylinders up to 150 l with load-sharing welded metallic liners
    ISO 11120:2015 Gas cylinders -- Refillable seamless steel tubes of water capacity between 150 l and 3000 l -- Design* construction and testing
    ISO 11513:2011 Gas cylinders -- Refillable welded steel cylinders containing materials for sub-atmospheric gas packaging (excluding acetylene) -- Design* construction* testing* use and periodic inspection
    ISO 11515:2013 Gas cylinders -- Refillable composite reinforced tubes of water capacity between 450 L and 3000 L -- Design* construction and testing
    ISO/TR 12391-1:2001 Gas cylinders -- Refillable seamless steel -- Performance tests -- Part 1: Philosophy* background and conclusions
    ISO/TR 19811:2017 Gas cylinders -- Service life testing for cylinders and tubes of composite construction
    ISO 20703:2006 Gas cylinders -- Refillable welded aluminium-alloy cylinders -- Design* construction and testing
    ISO 10691:2004 Gas cylinders -- Refillable welded steel cylinders for liquified petroleum gas (LPG) -- Procedures for checking before* during and after filling
    ISO 10961:2010 Gas cylinders -- Cylinder bundles -- Design* manufacture* testing and inspection
    ISO 19078:2013 Gas cylinders -- Inspection of the cylinder installation* and requalification of high pressure cylinders for the on-board storage of natural gas as a fuel for automotive vehicles
    the missing:
  13. Re: ISO Collection 78/300:ISO/TC 58 - Gas cylinders
    Thank you for sharing.
  1. Replies: 17
    Last Post: 03-27-2019, 12:10 AM
  2. ISO 11625 : Gas cylinders. Safe handling, PLEASE
    By tufanbora in forum Safety And Environment
    Last Post: 05-16-2016, 02:02 PM
  3. Circular Cylinders and Pressure Vessels: Stress Analysis and Design
    By Han Ah kwang in forum Mechanical Engineering
    Last Post: 11-02-2015, 07:42 AM
  4. Thick circular cylinders
    By dongono in forum General Engineering
    Last Post: 04-26-2015, 05:16 AM
  5. Replies: 13
    Last Post: 03-26-2014, 02:51 AM
