Results 1 to 8 of 8
Thread: CEN Standards Collection 337/370: CEN TC 218-Rubber And Plastics Hoses
    full list:
    EN 853:2015 Rubber hoses and hose assemblies - Wire braid reinforced hydraulic type - Specification
    EN 854:2015 Rubber hoses and hose assemblies - Textile reinforced hydraulic type - Specification
    EN 856:2015 Rubber hoses and hose assemblies - Rubber-covered spiral wire reinforced hydraulic type - Specification
    EN 857:2015 Rubber hoses and hose assemblies - Wire braid reinforced compact type for hydraulic applications - Specification
    EN ISO 1307:2008 Rubber and plastics hoses - Hose sizes, minimum and maximum inside diameters, and tolerances on cut-to-length hoses (ISO 1307:2006)
    EN 1360:2013 Rubber and plastic hoses and hose assemblies for measured fuel dispensing systems - Specification
    EN ISO 1401:1999 Rubber hoses for agricultural spraying (ISO 1401:1999)
    EN ISO 1402:2009 Rubber and plastics hoses and hose assemblies - Hydrostatic testing (ISO 1402:2009)
    EN ISO 1403:2008 Rubber hoses, textile-reinforced, for general-purpose water applications - Specification (ISO 1403:2005)
    EN 1761:1999 Rubber hoses and hose assemblies for fuel truck delivery - Specification
    EN 1762:2003 Rubber hoses and hose assemblies for liquefied petroleum gas, LPG (liquid or gaseous phase), and natural gas up to 25 bar (2,5 MPa) - Specification
    EN 1762:2003/AC:2007 Rubber hoses and hose assemblies for liquefied petroleum gas, LPG (liquid or gaseous phase), and natural gas up to 25 bar (2,5 MPa) - Specification
    EN 1765:2016 Rubber hose assemblies for oil suction and discharge services - Specification for the assemblies
    EN ISO 1825:2011 Rubber hoses and hose assemblies for aircraft ground fuelling and defuelling - Specification (ISO 1825:2010)
    EN ISO 2398:2008 Rubber hoses, textile-reinforced, for compressed air - Specification (ISO 2398:2006)
    EN ISO 3861:2008 Rubber hoses for sand and grit blasting - Specification (ISO 3861:2005)
    EN ISO 3949:2014 Plastics hoses and hose assemblies - Textile-reinforced types for hydraulic applications - Specification (ISO 3949:2009)
    EN ISO 3994:2014 Plastics hoses - Helical-thermoplastic-reinforced thermoplastics hoses for suction and discharge of aqueous materials - Specification (ISO 3994:2014)
    EN ISO 4023:2009 Rubber hoses and hose assemblies for steam - Test methods (ISO 4023:2009)
    EN ISO 4080:2009 Rubber and plastics hoses and hose assemblies - Determination of permeability to gas (ISO 4080:2009)
    EN ISO 4641:2011 Rubber hoses and hose assemblies for water suction and discharge - Specification (ISO 4641:2010)
    EN ISO 4671:2007 Rubber and plastics hoses and hose assemblies - Methods of measurement of the dimensions of hoses and the lengths of hose assemblies (ISO 4671:2007)
    EN ISO 4671:2007/A1:2011 Rubber and plastics hoses and hose assemblies - Methods of measurement of the dimensions of hoses and the lengths of hose assemblies - Amendment 1: Clarification of position at which outside diameter is measured (ISO 4671:2007/Amd 1:2011)
    EN ISO 5771:2008 Rubber hoses and hose assemblies for transferring anhydrous ammonia - Specification (ISO 5771:2008)
    EN ISO 5774:2016 Plastics hoses - Textile-reinforced types for compressed-air applications - Specification (ISO 5774:2016)
    EN ISO 6134:2005 Rubber hoses and hose assemblies for saturated steam - Specification (ISO 6134:2005)
    EN ISO 6224:2011 Thermoplastics hoses, textile-reinforced, for general-purpose water applications - Specification (ISO 6224:2011)
    EN ISO 6802:2008 Rubber and plastics hoses and hose assemblies with wire reinforcements - Hydraulic impulse test with flexing (ISO 6802:2005)
    EN ISO 6803:2008 Rubber or plastics hoses and hose assemblies - Hydraulic-pressure impulse test without flexing (ISO 6803:2008)
    EN ISO 6806:2014 Rubber hoses and hose assemblies for use in oil burners - Specification (ISO 6806:2014)
    EN ISO 6807:2003 Rubber hoses and hose assemblies for rotary drilling and vibration applications - Specification (ISO 6807:2003)
    EN ISO 6808:2014 Plastics hoses and hose assemblies for suction and low-pressure discharge of petroleum liquids - Specification (ISO 6808:2014)
    EN ISO 7233:2008 Rubber and plastics hoses and hose assemblies - Determination of resistance to vacuum (ISO 7233:2006)
    EN ISO 7326:2008 Rubber and plastics hoses - Assessment of ozone resistance under static conditions (ISO 7326:2006)
    EN ISO 7662:1996 Rubber and plastics hoses - Determination of abrasion of lining (ISO 7662:1988)
    EN ISO 7751:1997 Rubber and plastics hoses and hose assemblies - Ratios of proof and burst pressure to design working pressure (ISO 7751:1991)
    EN ISO 7751:1997/A1:2011 Rubber and plastics hoses and hose assemblies - Ratios of proof and burst pressure to maximum working pressure - Amendment 1 - Replacement of "design working pressure" by "maximum working pressure" throughout text (ISO 7751:1991/Amd 1:2011)
    EN ISO 8028:2000 Rubber and/or plastics hoses and hose assemblies for airless paint spraying - Specification (ISO 8028:1999)
    EN ISO 8029:2014 Plastics hose - General-purpose collapsible water hose, textile-reinforced - Specification (ISO 8029:2014)
    EN ISO 8030:2014 Rubber and plastics hoses - Method of test for flammability (ISO 8030:2014)
    EN ISO 8031:2009 Rubber and plastics hoses and hose assemblies - Determination of electrical resistance and conductivity (ISO 8031:2009)
    EN ISO 8032:1999 Rubber and plastics hose assemblies - Flexing combined with hydraulic impulse test (half-omega test) (ISO 8032:1997)
    EN ISO 8033:2006 Rubber and plastics hoses - Determination of adhesion between components (ISO 8033:2006)
    EN ISO 8308:2015 Rubber and plastics hoses and tubing - Determination of transmission of liquids through hose and tubing walls (ISO 8308:2015)
    EN ISO 8330:2014 Rubber and plastics hoses and hose assemblies - Vocabulary (ISO 8330:2014)
    EN ISO 8331:2014 Rubber and plastics hoses and hose assemblies - Guidelines for selection, storage, use and maintenance (ISO 8331:2014)
    EN ISO 10619-1:2011 Rubber and plastics hoses and tubing - Measurement of flexibility and stiffness - Part 1: Bending tests at ambient temperature (ISO 10619-1:2011)
    EN ISO 10619-2:2011 Rubber and plastics hoses and tubing - Measurement of flexibility and stiffness - Part 2: Bending tests at sub-ambient temperatures (ISO 10619-2:2011)
    EN ISO 10619-3:2011 Rubber and plastics hoses and tubing - Measurement of flexibility and stiffness - Part 3: Bending tests at high and low temperatures (ISO 10619-3:2011)
    EN ISO 10960:1996 Rubber and plastics hoses - Assessment of ozone resistance under dynamic conditions (ISO 10960:1994)
    EN 12115:2011 Rubber and thermoplastics hoses and hose assemblies for liquid or gaseous chemicals - Specification
    EN 13482:2013 Rubber hoses and hose assemblies for asphalt and bitumen - Specification
    EN 13483:2013 Rubber and plastic hoses and hose assemblies with internal vapour recovery for measured fuel dispensing systems - Specification
    EN 13765:2010+A1:2015 Thermoplastic multi-layer (non-vulcanized) hoses and hose assemblies for the transfer of hydrocarbons, solvents and chemicals - Specification
    EN 13766:2010 Thermoplastic multi-layer (non-vulcanized) hoses and hose assemblies for the transfer of liquid petroleum gas and liquefied natural gas - Specification
    EN 14420-1:2013 Hose fittings with clamp units - Part 1: Requirements, types of fixing and connection, designation and testing
    EN 14420-2:2013 Hose fittings with clamp units - Part 2: Hose side parts of hose tail
    EN 14420-3:2013 Hose fittings with clamp units - Part 3: Clamp units, bolted or pinned
    EN 14420-4:2013 Hose fittings with clamp units - Part 4: Flange connections
    EN 14420-5:2013 Hose fittings with clamp units - Part 5: Threaded connections
    EN 14420-6:2013 Hose fittings with clamp units - Part 6: TW tank truck couplings
    EN 14420-7:2013 Hose fittings with clamp units - Part 7: Cam locking couplings
    EN 14420-8:2013+A1:2016 Hose fittings with clamp units - Part 8: Symmetrical half coupling (Guillemin system)
    CEN/TS 14421:2006 Hose tail and ferrule for crimping and swaging
    EN 14422:2013 Clamp type coupling assemblies for liquefied petroleum gas (LPG) transfer hoses
    EN 14423:2013 Clamp type coupling assemblies for use with steam hoses rated for pressures up to 18 bar
    EN 14424:2013 Hose fittings with screwed ferrules
    EN 16643:2016 Rubber and plastics hoses and hose assemblies - Non-bonded fluoroplastic lined (e.g. PTFE) hoses and hose assemblies for liquid and gaseous chemicals - Specification
    CEN/TS 16650:2014 Specification for hose couplings for petrol, oil and lubricants - High pressure couplings
    EN ISO 18752:2016 Rubber hoses and hose assemblies - Wire- or textile-reinforced single-pressure types for hydraulic applications - Specification (ISO 18752:2014)
    EN 26801:1993 Rubber or plastics hoses - Determination of volumetric expansion (ISO 6801:1983)
    EN 26801:1993/A1:2011 Rubber or plastics hoses - Determination of volumetric expansion - Amendment 1: Deletion of alcohol as pressurizing fluid (ISO 6801:1983/Amd 1:2011)
    EN ISO 28017:2011 Rubber hoses and hose assemblies, wire or textile reinforced, for dredging applications - Specification (ISO 28017:2011)
    EN ISO 28017:2011/A1:2015 Rubber hoses and hose assemblies, wire or textile reinforced, for dredging applications - Specification - Amendment 1 (ISO 28017:2011/Amd 1:2015)
    EN ISO 30013:2011 Rubber and plastics hoses - Methods of exposure to laboratory light sources - Determination of changes in colour, appearance and other physical properties (ISO 30013:2011)
    missing are:
    links:
    or
    Re: CEN Standards Collection 337/370: CEN TC 218-Rubber And Plastics Hoses
    ok* added some missing standards:
    EN ISO 7233:2016 Rubber and plastics hoses and hose assemblies - Determination of resistance to vacuum (ISO 7233:2016)
    EN ISO 7326:2016 Rubber and plastics hoses - Assessment of ozone resistance under static conditions (ISO 7326:2016)
    EN ISO 8331:2016 Rubber and plastics hoses and hose assemblies - Guidelines for selection* storage* use and maintenance (ISO 8331:2016)
    and the missing are now:
    EN ISO 1401:2016 Rubber hoses for agricultural spraying (ISO 1401:2016)
    EN ISO 2398:2016 Rubber hoses* textile-reinforced* for compressed air - Specification (ISO 2398:2016)
    EN ISO 4641:2016 Rubber hoses and hose assemblies for water suction and discharge - Specification (ISO 4641:2016)
    EN ISO 7751:2016 Rubber and plastics hoses and hose assemblies - Ratios of proof and burst pressure to maximum working pressure (ISO 7751:2016)
    EN 14423:2013+A1:2016 Clamp type coupling assemblies for use with steam hoses rated for pressures up to 18 bar
    new link:
    thanks dear
    update:
    new missing list is:
    EN ISO 6134:2017 Rubber hoses and hose assemblies for saturated steam - Specification (ISO 6134:2017)
    EN ISO 8033:2017 Rubber and plastics hoses - Determination of adhesion between components (ISO 8033:2016)
    new link:
    Could you have BS 336:2010 * the important one of fire hose coupling
    update:
    missing* new* EN* BQ:
    EN 1762:2017 Rubber hoses and hose assemblies for liquefied petroleum gas* LPG (liquid or gaseous phase)* and natural gas up to 25 bar (2*5 MPa) - Specification
    EN ISO 6224:2011 Thermoplastics hoses* textile-reinforced* for general-purpose water applications - Specification (ISO 6224:2011)
    EN ISO 6803:2017 Rubber or plastics hoses and hose assemblies - Hydraulic-pressure impulse test without flexing (ISO 6803:2017)
    EN ISO 6806:2017 Rubber hoses and hose assemblies for use in oil burners - Specification (ISO 6806:2017)
    EN 16820:2017 Rubber and plastics hoses and hose assemblies for use in the pharmaceutical and biotechnological industry - Bonded elastomeric hoses with or without a lining
    EN 16821:2017 Rubber and plastics hoses and hose assemblies for use in the pharmaceutical and biotechnological industry - Silicone rubber hoses
    EN ISO 30013:2011 Rubber and plastics hoses - Methods of exposure to laboratory light sources - Determination of changes in colour* appearance and other physical properties (ISO 30013:2011)
    complete
  10. Re: CEN Standards Collection 337/370: CEN TC 218-Rubber And Plastics Hoses
    thank for sharing. The docs are very useful
    Thanks a lot friend
  1. CEN Standards Collection 88/370: CEN TC 249-Plastics
    Last Post: 08-03-2018, 02:20 PM
  2. CEN Standars Collection 55/370: CEN TC 342 - Metal Hoses...
    Last Post: 11-23-2017, 10:34 PM
  3. Replies: 7
    Last Post: 07-18-2017, 06:39 AM
  4. Extrusion Dies for Plastics and Rubber: Design and
    By Abdel fatah in forum Materials Science &Corrosion
    Last Post: 03-13-2011, 04:24 AM
  5. Replies: 0
    Last Post: 01-24-2011, 03:16 PM
