1-PVelite is for a vessels as a whole. It contains already Codecalc.
Codecalc alone is for component design ( a head alone, a shell alone,flange alone ..) it can also not calculate wind or seimic.
2-A vacuum give quickly a thick vessel shell, unless you use stiffer rings to make shell a bit stiff ( rigid).
3-It seems that your external pressure is a bit high, why don' t you talk to your process people a use a more realistic value than you will get lower thicknesses.
4-For your case the load of the vessel= horizontal tank is governing this means the reaction of the saddles and their disposition will give some moment onto the vessel, but no worries PVelite will calculate that for you
5-Flat heads are thick, why don't you use elliptical heads: cheaper and easy to weld a also can get more external pressure. Flat heads are a bad idea.
6-Easier for you to calculate wind loads ( forces and moment) on anchor bolts/foundation. You have the whole procedure here (=Vessel Design Manual / By Moses) , just follow the procedure a do calcs by hand till you understand them, at the end use excel or similar.
here is the link for dowloding this manual:
PVelite uses also this book and it refers to it in his calcs
7- for your case , DO NOT forget to leave one saddle free to expand/ move
6/-Use a wear plate between saddle and vessel , this a good practice, also remove sharp edges of wear plates.
talk care
greetings to all people on this forum
