Results 1 to 7 of 7
Thread: Request: PFI std ES3 Fabrication tolerances
  1. Request: PFI std ES3 Fabrication tolerances
    Hi
    I am looking for the PSI ES3 standard 2009 0r 2000 edition.
    I found many links on this site, but unfortunately, all links have expired. Could someone please upload?
    Thank you
    Re: Request: PFI std ES3 Fabrication tolerances
    PFI ES-3-2000 Fabricating Tolerances
    Attached Files Attached Files
  5. Re: Request: PFI std ES3 Fabrication tolerances
    Quote Originally Posted by Marty Thompson View Post
    Thanks a lot Mr. Marty
  6. Re: Request: PFI std ES3 Fabrication tolerances
  7. Re: Request: PFI std ES3 Fabrication tolerances
    Quote Originally Posted by mnthiraviam View Post
    Hi
    Thank you
    2009 version attached....
    mnthiraviam, do you have other newer ones to post?
  10. Re: Request: PFI std ES3 Fabrication tolerances
    hi, unfortunately i don`t have other newer ones... but will surely try and post if i get any
  1. fabrication calculation
    By parul in forum Mechanical Engineering
    Last Post: 08-29-2013, 03:50 AM
  2. Permissible Variations (Tolerances) in Pipe (Tube) Wall Thickness per ASME & API
    Last Post: 09-15-2012, 02:31 PM
  3. fabrication of tnaks
    By abdul.tawab41 in forum Mechanical Engineering
    Last Post: 04-16-2011, 06:16 PM
  4. Carbon Steel Structures - Dimensional Tolerances
    By Inspector.Soldadura in forum Mechanical Engineering
    Last Post: 03-17-2011, 10:34 PM
