Page 1 of 2 1 2 LastLast
Results 1 to 12 of 20
Thread: ASTM Standards Collections 2016
    Link:
    ASTM G65-2016 Standard Test Method for Measuring Abrasion Using the Dry SandRubb.rar
    ASTM F3127-2016 Standard Guide for Validating Cleaning Processes Uesd During the.rar
    ASTM F3111-2016 Standard Specification for Heavy Hex Structural BoltNutWasher As.rar
    ASTM F3061-2016 Standard Specification for System and Equipment in Small Aircraf.rar
    ASTM F3060-2016 Standard Terminology for Aircraft.part1.rar
    ASTM F3060-2016 Standard Terminology for Aircraft.part2.rar
    ASTM F2930-2016 Standard Guide for Compliance with Light Sport Aircraft Standard.rar
    ASTM F2245-2016 Standard Specification for Design and Performance of a Light Spo.rar
    ASTM F2238-2016 Standard Test Method for Performance of Rapid Cook Ovens.rar
    ASTM F2204-2016 Standard Guide for Describing Shoreline and Inland Response Techniques.rar
    ASTM F2167-2016 Standard Consumer Safety Specification for Infant Bouncer Seats.rar
    ASTM F2097-2016 Standard Guide for Design and Evaluation of Primary Flexible Pac.rar
    ASTM D945-2016 Standard Test Methods for Rubber Properties in Compression or She.rar
    ASTM B283-2016 Standard Specification for Copper and Copper-Alloy Die Forgings .rar
    ASTM B117-2016 Standard Practice for Operating Salt Spray (Fog) Apparatus.rar
    ASTM G215-2016 Standard Guide for Electrode Potential Measurement.pdf
    ASTM G178-2016 Standard Practice for Determining the Activation Spectrum of a Ma.pdf
    ASTM G105-2016 Standard Test Method for Conducting Wet SandRubber Wheel Abrasion.pdf
    ASTM F3194-2016 Standard Guide for Training for Personnel Operating Small Land O.pdf
    ASTM F3193-2016 Standard Guide for Training of a Land Search and Rescue Team Leader.pdf
    ASTM F3190-2016 Standard Practice for Heat Fusion Epquiment(HFE) Operator Qualif.pdf
    ASTM F3188-2016 Standard Specification for Extractable Hazardous Metal in Synthe.pdf
    ASTM F3183-2016 Standard Practice for Guide Side Bend Evaluation of Polyethylene.pdf
    ASTM F3182-2016 Standard Practice for the Application of Spray-Applied Polymeric.pdf
    ASTM F3181-2016 Standard Test Method for The Un-notched,Constant Ligament Stress.pdf
    ASTM F3180-2016 Standard Specification for Low-Speed Flight Characteristics of A.pdf
    ASTM F3179-2016 Standard Specification for Performance of Aeroplanes.pdf
    ASTM F3175-2016 Standard Guide for Training and Equipping Search and Rescue Pers.pdf
    ASTM F3165-2016 Standard Specification for Throat Protective Equipment for Hocke.pdf
    ASTM F3163-2016 Standard Guide for Classification of Cellular andor Tissue-Based.pdf
    ASTM F3161-2016 Standard Test Method for Finite Element Analysis(FEA)of Metallic.pdf
    ASTM F3152-2016 Standard Test Method for Determining Abrasion Resistance of Inks.pdf
    ASTM F3121-2016 Standard Guide for In-Service Inspection,Maintenance,and Electri.pdf
    ASTM F3063-2016 Standard Specification for Design and Integration of FuelEnergy .pdf
    ASTM F3058-2016 Standard Practice for Preliminary Field Testing of Thermoplastic.pdf
    ASTM F3057-2016 Standard Tset Method for Electromagnetic Shielding Effectiveness.pdf
    ASTM F3033-2016 Standard Practice for Installation of a Single-Sized,Cured-In-Pl.pdf
    ASTM F2959-2016 Standard Practice for Aerial Adventure Courses.pdf
    ASTM F2908-2016 Standard Specification or Aircraft Flight Manual(AFM)for a Small.pdf
    ASTM F2786-2016 Standard Practice for Field Leak Testing of Polyethylene (PE) Pr.pdf
    ASTM F2763-2016 Standard Specification for 12 to 60 in.[300 to 1500 mm]Dual and .pdf
    ASTM F2751-2016 Standard Guide for Training of a Land Search and Rescue Team Member.pdf
    ASTM F2750-2016 Standard Tset Method for Determining the Effects of Bending a Me.pdf
    ASTM F2678-2016 Standard Practice for Preparing Panel Underlayments,Thick Poured.pdf
    ASTM F2670-2016 Standard Consumer Safety Specification for Infant Bath Tubs.pdf
    ASTM F2654-2016 Standard Specification for Airsoft Gun Warnings.pdf
    ASTM F2653-2016 Standard Specification for Paintball Valve Threaded Connection f.pdf
    ASTM F2589-2016 Standard Specification for Ornamental Fences Employing Steel Tub.pdf
    ASTM F2527-2016 Standard Specification for Wrought Seamless and Welded and Drawn.pdf
    ASTM F2417-2016 Standard Specification for Fire Safety for Candles.pdf
    ASTM F2408-2016 Standard Specification for Ornamental Fences Employing Galvanize.pdf
    ASTM F2400-2016 Standard Specification for Helmets Used in Pole Vaulting.pdf
    ASTM F2286-2016 Standard Design and Performance Specification for Removable Mesh.pdf
    ASTM F2236-2016 Standard Consumer Safety Specification for Soft Infant and Toddl.pdf
    ASTM F2170-2016 Standard Test Method for Determining Relative Humidity in Concre.pdf
    ASTM F2149-2016 Standard Test Method for Automated Analyses of Cells〞the Electr.pdf
    ASTM F2082-2016 Standard Test Method for Determination of Transformation Tempera.pdf
    ASTM F2050-2016 Standard Consumer Safety Specification for Hand-Held Infant Carriers.pdf
    ASTM F2026-2016 Standard Specification for Polyetheretherketone (PEEK) Polymers.pdf
    ASTM F1972-2016 Standard Guide for Terminology Relating to Candles and Associate.pdf
    ASTM F1896-2016 Test Method for Determining the Electrical Resistivity of a Prin.pdf
    ASTM F1869-2016 Standard Test Method for Measuring Moisture Vapor Emission Rate .pdf
    ASTM E2006-2016 Standard Guide for Benchmark Testing of Light Water Reactor Calc.pdf
    ASTM E1790-2016 Standard Practice for Near Infrared Qualitative Analysis.pdf
    ASTM E1079-2016 Standard Practice for Calibration of Transmission Densitometers.pdf
    ASTM E413-2016 Classification for Rating Sound Insulation.pdf
    ASTM E384-16.pdf
    ASTM E309-2016.pdf
    ASTM E96-E96M-16.pdf
    ASTM E92-16.pdf
    ASTM E8-E8M-2015a.pdf
    ASTM D7984-2016 Standard Test Method for Measurement of Thermal Effusivity of Fa.pdf
    ASTM D7386-16 Standard Practice for Performance Testing of Packages for Single P.pdf
    ASTM D7249-2016 Standard Test Method for Facing Properties of Sandwich Construct.pdf
    ASTM D7215-2016 Standard Test Method for Calculated Flash Point from Simulated D.pdf
    ASTM D6525-2016 Standard Test Method for Measuring Nominal Thickness of Permanen.pdf
    ASTM D6524-2016 Standard Test Method for Measuring the Resiliency of Turf Reinfo.pdf
    ASTM D5978-2016 Standard Guide for Maintenance and Rehabilitation of Ground-Wate.pdf
    ASTM D3802-2016 Standard Test Method for Ball-Pan Hardness of Activated Carbon.pdf
    ASTM D3561-2016 Standard Test Method for Lithium, Potassium, and Sodium Ions in .pdf
    ASTM D3273-2016 Standard Test Method for Resistance to Growth of Mold on the Sur.pdf
    ASTM D2244-2016 Standard Practice for Calculation of Color Tolerances and Color .pdf
    ASTM D1230-10(2016)e1 Standard Test Method for Flammability of Apparel Textiles.pdf
    ASTM C1800-2016 Standard Test Method for Determining Density of Roller-Compacted.pdf
    ASTM C1382-2016 Test Method for Determining Tensile Adhesion Properties of Seala.pdf
    ASTM B687-2016 Standard Specification for Brass, Copper, and Chromium-Plated Pip.pdf
    ASTM B506-2016 Standard Specification for Copper-Clad Stainless Steel Sheet and .pdf
    ASTM A694_A694M-16 Standard Specification for Carbon and Alloy Steel Forgings fo..pdf
    ASTM A484A484M-16.pdf
    ASTM A479A479M-16a.pdf
    ASTM A479A479M-16.pdf
    ASTM A420-16.pdf
    ASTM A416-16.pdf
    ASTM A370-2016 .pdf
    ASTM A370-16.pdf
    ASTM A338A338M-16.pdf
    ASTM A351A351M-16.pdf
    ASTM A335-15a.pdf
    ASTM A333-2016.pdf
    ASTM A312A312M-16.pdf
    ASTM A276A276M-16.pdf
    ASTM A240-2016 Std Spec for Chromium and Chromium-Nickel Stainless Steel Plate, .pdf
    ASTM A216A216M-16.pdf
    ASTM A194A194M-16.pdf
    ASTM A182-A182M-2016.pdf
    ASTM A193A193M-16.pdf
    Nov 2009
    All over EGPET
    Blog Entries
    1
    Re: ASTM Standards Collections 2016
    Dear ayyazveer, Kindly share the docs through some other shareable link
    [link Point to another website Only the registered members can access] . Thanks in Advance.
    Dear ayyazveer
    the link is not working , please upload in another link
    Dear ayyazveer
    please reupload in another link
    thank you in advance
    Dear ayyazveer
    I remind you, please reupload in another link
    Please post live lint the above link is Dear:-- Require ASTM E384-16 urgently..
  10. Re: ASTM Standards Collections 2016
    Thanks..
  11. Re: ASTM Standards Collections 2016
    Once ad fly message appears* use https:// before that web address to open it..
  12. Re: ASTM Standards Collections 2016
    thank you very much* sir.
  13. Re: ASTM Standards Collections 2016
    wonderfull!!
  14. #11
    Thanks a lot. Amazing!!!
  16. Re: ASTM Standards Collections 2016
    Unable to download.* kindly upload to mediafire.com
  1. API Standards Collections 2016
    By ayyazveer in forum Mechanical Engineering
    Last Post: 05-24-2024, 12:06 PM
  2. ASTM 2016 Colletions (113 fils, 2016.08.11)
    By Mechen in forum Mechanical Engineering
    Last Post: 09-04-2017, 10:55 AM
  3. ASTM Handbook of comparative world steel standards DS67D-5th 2016
    Last Post: 05-21-2017, 07:38 PM
  4. Special Request: ASTM C204-2016 & BS EN 196-1-2016
    By Marty Thompson in forum Materials Science &Corrosion
    Last Post: 01-28-2017, 08:43 AM
  5. Need ASTM A247-2016 & ASTM B117-2016
    By chat2bala in forum Mechanical Engineering
    Last Post: 08-04-2016, 06:08 AM
