Link:[link Point to another website Only the registered members can access]
API STD 670-2014.rar
API STD 600-2015 13th Steel Gate Valves - Flanged and Butt-welding Ends, Bolted Bonnets.rar
API Std 599-2013 Metal Plug Valves—Flanged, Threaded, and Welding Ends.rar
API STD 510-2014 10th Pressure Vessel Inspection Code In-service Inspection.rar
API RP 1174-2015 Recommended Practice for Onshore Hazardous Liquid Pipeline Emer.rar
API RP 1174-2015 Recommended Practice for Onshore Hazardous Liquid Pipeline Emer (1).rar
API RP 10B-4-2015 Preparation and Testing of Foamed Cement Formulations at Atmos.rar
API TR 1166-2015 Excavation Monitoring and Observation for Damage Prevention.pdf
API TR 1149-2015 Pipeline Variable Uncertainties and Their Effects on Leak Detec.pdf
API TR 17TR13-2016 General Overview of Subsea Production Systems.pdf
API STD 2350:2012.pdf
API STD 2000 2014-Venting Atmospheric And Low Pressure, Seventh Edition.pdf
API STD 674-e2 2015 Positive Displacement Pumps—Reciprocating.PDF
API STD 673 2014.pdf
API Std 663-2014 Hairpin-type Heat Exchangers.pdf
API Std 625-2014 1st ADDENDUM 2 Tank Systems for Refrigerated Liquefied Gas.pdf
API STD 624-2014 Type Testing of Rising Stem Valves Equipped with Packing for Fu.pdf
API STD 609 -2016.pdf
API STD 602-2015.PDF
API STD 521-2014 6th Pressure-relieving and Depressuring Systems.pdf
API STD 20C-2015 Closed Die Forgings for Use in the Petroleum and Natural Gas Industry.PDF
API SPEC 17D-2011.pdf
API SPEC 16C 2nd Mar. 2015 Choke and Kill Equipment.pdf
API SPEC 7K-2016 Drilling and Well Servicing Equipment.pdf
API SPEC 6D 24th 2014.pdf
API RP 1175 - 2015 Draft.pdf
API RP 1171-2015 Functional Integrity of Natural Gas Storage in Depleted Hydroca.pdf
API RP 1170-2015 Design and Operation of Solutionmined Salt Caverns Used for Nat.pdf
API RP 1111-2015 Design, Construction, Operation, and Maintenance of Offshore Hy.pdf
API RP 941 8th Ed.2016 Steels for Hydrogen Service at Elevated Temperatures and Pressures in Pet.pdf
API RP 754-2016 Process Safety Performance Indicators for the Refining and Petro.pdf
API RP 651 4th ed. sept. 2014 Cathodic Protection of Aboveground Petroleum Storage Tanks.pdf
API RP 582-2016 Welding Guidelines for the Chemical, Oil, and Gas Industries.pdf
API RP 581-2016 Risk-Based Inspection Methodology, Third Edition.pdf
API RP 580-2016.pdf
API RP 538-2015 Industrial Fired Boilers for General Refinery and Petrochemical Service.pdf
API RP 100-2-2015 Managing Environmental Aspects Associated with Exploration and.pdf
API RP 100-1-2015 Hydraulic Fracturing〞Well Integrity and Fracture Containment.pdf
API RP 90-2-2016 Annular Casing Pressure Management for Onshore Wells.pdf
API RP 17S-2015 Recommended Practice for the Design, Testing, and Operation of S.pdf
API RP 5C1-1999(R2015).pdf
Visit -- >> engrzone.blogspot.com
