Thread: CEN Standards Collection 343/350: CEN TC 227-Road Materials
    full list:
    EN ISO 11819-1:2001 Acoustics - Measurement of the influence of road surfaces on traffic noise - Part 1: Statistical Pass-By method (ISO 11819-1:1997)
    EN 12271:2006 Surface dressing - Requirements
    EN 12272-1:2002 Surface dressing - Test methods - Part 1: Rate of spread and accuracy of spread of binder and chippings
    EN 12272-2:2003 Surface dressing - Test methods - Part 2: Visual assessment of defects
    EN 12272-3:2003 Surface dressing - Test methods - Part 3: Determination of binder aggregate adhesivity by the Vialit plate shock test method
    EN 12273:2008 Slurry surfacing - Requirements
    EN 12274-1:2002 Slurry surfacing - Test methods - Part 1: Sampling for binder extraction
    EN 12274-2:2003 Slurry surfacing - Test methods - Part 2: Determination of residual binder content
    EN 12274-3:2002 Slurry surfacing - Test methods - Part 3: Consistency
    EN 12274-4:2003 Slurry surfacing - Test methods - Part 4: Determination of cohesion of the mix
    EN 12274-5:2003 Slurry surfacing - Test method - Part 5: Determination of wearing
    EN 12274-6:2002 Slurry surfacing - Test methods - Part 6: Rate of application
    EN 12274-7:2005 Slurry surfacing - Test methods - Part 7: Shaking abrasion test
    EN 12274-8:2005 Slurry surfacing - Test methods - Part 8: Visual assessment of defects
    EN 12697-1:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 1: Soluble binder content
    EN 12697-2:2015 Bituminous mixtures - Test methods - Part 2: Determination of particle size distribution
    EN 12697-3:2013 Bituminous mixtures - Test methods for hot mix asphalt - Part 3: Bitumen recovery: Rotary evaporator
    EN 12697-4:2015 Bituminous mixtures - Test methods - Part 4: Bitumen recovery: Fractionating column
    EN 12697-5:2009 Bituminous mixtures - Test methods for hot mix asphalt - Part 5: Determination of the maximum density
    EN 12697-5:2009/AC:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 5: Determination of the maximum density
    EN 12697-6:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 6: Determination of bulk density of bituminous specimens
    EN 12697-7:2014 Bituminous mixtures - Test methods for hot mix asphalt - Part 7: Determination of bulk density of bituminous specimens by gamma rays
    EN 12697-8:2003 Bituminous mixtures - Test methods for hot mix asphalt - Part 8: Determination of void characteristics of bituminous specimens
    EN 12697-10:2001 Bituminous mixtures - Test methods for hot mix asphalt - Part 10: Compactability
    EN 12697-10:2001/AC:2007 Bituminous mixtures - Test methods for hot mix asphalt - Part 10: Compactability
    EN 12697-11:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 11: Determination of the affinity between aggregate and bitumen
    EN 12697-12:2008 Bituminous mixtures - Test methods for hot mix asphalt - Part 12: Determination of the water sensitivity of bituminous specimens
    EN 12697-13:2000 Bituminous mixtures - Test methods for hot mix asphalt - Part 13: Temperature measurement
    EN 12697-13:2000/AC:2001 Bituminous mixtures - Test methods for hot mix asphalt - Part 13: Temperature measurement
    EN 12697-14:2000 Bituminous mixtures - Test methods for hot mix asphalt - Part 14: Water content
    EN 12697-14:2000/AC:2001 Bituminous mixtures - Test methods for hot mix asphalt - Part 14: Water content
    EN 12697-15:2003 Bituminous mixtures - Test methods for hot mix asphalt - Part 15: Determination of the segregation sensitivity
    EN 12697-16:2016 Bituminous mixtures - Test methods - Part 16: Abrasion by studded tyres
    EN 12697-17:2004+A1:2007 Bituminous mixtures - Test methods for hot mix asphalt - Part 17: Particle loss of porous asphalt specimen
    EN 12697-18:2004 Bituminous mixtures - Test methods for hot mix asphalt - Part 18: Binder drainage
    EN 12697-19:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 19: Permeability of specimen
    EN 12697-20:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 20: Indentation using cube or cylindrical specimens (CY)
    EN 12697-21:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 21: Indentation using plate specimens
    EN 12697-22:2003+A1:2007 Bituminous mixtures - Test methods for hot mix asphalt - Part 22: Wheel tracking
    EN 12697-23:2003 Bituminous mixtures - Test methods for hot mix asphalt - Part 23: Determination of the indirect tensile strength of bituminous specimens
    EN 12697-24:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 24: Resistance to fatigue
    EN 12697-25:2016 Bituminous mixtures - Test methods - Part 25: Cyclic compression test
    EN 12697-26:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 26: Stiffness
    EN 12697-27:2000 Bituminous mixtures - Test methods for hot mix asphalt - Part 27: Sampling
    EN 12697-28:2000 Bituminous mixtures - Test methods for hot mix asphalt - Part 28: Preparation of samples for determining binder content, water content and grading
    EN 12697-29:2002 Bituminous mixtures - Test method for hot mix asphalt - Part 29: Determination of the dimensions of a bituminous specimen
    EN 12697-30:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 30: Specimen preparation by impact compactor
    EN 12697-31:2007 Bituminous mixtures - Test methods for hot mix asphalt - Part 31: Specimen preparation by gyratory compactor
    EN 12697-32:2003+A1:2007 Bituminous mixtures - Test methods for hot mix asphalt - Part 32: Laboratory compaction of bituminous mixtures by vibratory compactor
    EN 12697-33:2003+A1:2007 Bituminous mixtures - Test methods for hot mix asphalt - Part 33: Specimen prepared by roller compactor
    EN 12697-34:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 34: Marshall test
    EN 12697-35:2016 Bituminous mixtures - Test methods - Part 35: Laboratory mixing
    EN 12697-36:2003 Bituminous mixtures - Test methods for hot mix asphalt - Part 36: Determination of the thickness of a bituminous pavement
    EN 12697-37:2003 Bituminous mixtures - Test methods for hot mix asphalt - Part 37: Hot sand test for the adhesivity of binder on precoated chippings for HRA
    EN 12697-38:2004 Bituminous mixtures - Test methods for hot mix asphalt - Part 38: Common equipment and calibration
    EN 12697-39:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 39: Binder content by ignition
    EN 12697-40:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 40: In situ drainability
    EN 12697-41:2013 Bituminous mixtures - Test methods for hot mix asphalt - Part 41: Resistance to de-icing fluids
    EN 12697-42:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 42: Amount of foreign matter in reclaimed asphalt
    EN 12697-43:2014 Bituminous mixtures - Test methods for hot mix asphalt - Part 43: Resistance to fuel
    EN 12697-44:2010 Bituminous mixtures - Test methods for hot mix asphalt - Part 44: ***** propagation by semi-circular bending test
    EN 12697-45:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 45: Saturation Ageing Tensile Stiffness (SATS) conditioning test
    EN 12697-46:2012 Bituminous mixtures - Test methods for hot mix asphalt - Part 46: Low temperature *****ing and properties by uniaxial tension tests
    EN 12697-47:2010 Bituminous mixtures - Test methods for hot mix asphalt - Part 47: Determination of the ash content of natural asphalts
    EN 12697-49:2014 Bituminous mixtures - Test methods for hot mix asphalt - Part 49: Determination of friction after polishing
    CEN/TS 12697-50:2016 Bituminous mixtures - Test methods - Part 50: Resistance to scuffing
    EN 13036-1:2010 Road and airfield surface characteristics - Test methods - Part 1: Measurement of pavement surface macrotexture depth using a volumetric ***** technique
    CEN/TS 13036-2:2010 Road and airfield surface characteristics - Test methods - Part 2: Assessment of the skid resistance of a road pavement surface by the use of dynamic measuring systems
    EN 13036-3:2002 Road and airfield surface characteristics - Test methods - Part 3: Measurement of pavement surface horizontal drainability
    EN 13036-4:2011 Road and airfield surface characteristics - Test methods - Part 4: Method for measurement of slip/skid resistance of a surface: The pendulum test
    EN 13036-6:2008 Road and airfield surface characteristics - Test methods - Part 6: Measurement of transverse and longitudinal profiles in the evenness and megatexture wavelength ranges
    EN 13036-7:2003 Road and airfield surface characteristics - Test methods - Part 7: Irregularity measurement of pavement courses : the straightedge test
    EN 13036-8:2008 Road and airfield surface characteristics - Test methods - Part 8: Determination of transverse unevenness indices
    EN 13108-1:2016 Bituminous mixtures - Material specifications - Part 1: Asphalt Concrete
    EN 13108-2:2016 Bituminous mixtures - Material specifications - Part 2: Asphalt Concrete for Very Thin Layers (BBTM)
    EN 13108-3:2016 Bituminous mixtures - Material specifications - Part 3: Soft Asphalt
    EN 13108-4:2016 Bituminous mixtures - Material specifications - Part 4: Hot Rolled Asphalt
    EN 13108-5:2016 Bituminous mixtures - Material specifications - Part 5: Stone Mastic Asphalt
    EN 13108-6:2016 Bituminous mixtures - Material specifications - Part 6: Mastic Asphalt
    EN 13108-7:2016 Bituminous mixtures - Material specifications - Part 7: Porous Asphalt
    EN 13108-8:2016 Bituminous mixtures - Material specifications - Part 8: Reclaimed asphalt
    EN 13108-9:2016 Bituminous mixtures - Material specifications - Part 9: Asphalt for Ultra-Thin Layer (AUTL)
    EN 13108-20:2016 Bituminous mixtures - Material specifications - Part 20: Type Testing
    EN 13108-21:2016 Bituminous mixtures - Material specifications - Part 21: Factory Production Control
    EN 13285:2010 Unbound mixtures - Specifications
    EN 13286-1:2003 Unbound and hydraulically bound mixtures - Part 1: Test methods for laboratory reference density and water content - Introduction, general requirements and sampling
    EN 13286-2:2010 Unbound and hydraulically bound mixtures - Part 2: Test methods for laboratory reference density and water content - Proctor compaction
    EN 13286-2:2010/AC:2012 Unbound and hydraulically bound mixtures - Part 2: Test methods for laboratory reference density and water content - Proctor compaction
    EN 13286-3:2003 Unbound and hydraulically bound mixtures - Part 3: Test methods for laboratory reference density and water content - Vibrocompression with controlled parameters
    EN 13286-4:2003 Unbound and hydraulically bound mixtures - Part 4: Test methods for laboratory reference density and water content - Vibrating hammer
    EN 13286-5:2003 Unbound and hydraulically bound mixtures - Part 5: Test methods for laboratory reference density and water content - Vibrating table
    EN 13286-7:2004 Unbound and hydraulically bound mixtures - Part 7: Cyclic load triaxial test for unbound mixtures
    EN 13286-40:2003 Unbound and hydraulically bound mixtures - Part 40: Test method for the determination of the direct tensile strength of hydraulically bound mixtures
    EN 13286-41:2003 Unbound and hydraulically bound mixtures - Part 41: Test method for the determination of the compressive strength of hydraulically bound mixtures
    EN 13286-42:2003 Unbound and hydraulically bound mixtures - Part 42: Test method for the determination of the indirect tensile strength of hydraulically bound mixtures
    EN 13286-43:2003 Unbound and hydraulically bound mixtures - Part 43: Test method for the determination of the modulus of elasticity of hydraulically bound mixtures
    EN 13286-44:2003 Unbound and hydraulically bound mixtures - Part 44: Test method for the determination of the alpha coefficient of vitrified blast furnace slag
    EN 13286-45:2003 Unbound and hydraulically bound mixtures - Part 45: Test method for the determination of the workability period of hydraulically bound mixtures
    EN 13286-46:2003 Unbound and hydraulically bound mixtures - Part 46: Test method for the determination of the moisture condition value
    EN 13286-47:2012 Unbound and hydraulically bound mixtures - Part 47: Test method for the determination of California bearing ratio, immediate bearing index and linear swelling
    EN 13286-48:2005 Unbound and hydraulically bound mixtures - Part 48: Test method for the determination of degree of pulverisation
    EN 13286-49:2004 Unbound and hydraulically bound mixtures - Part 49: Accelerated swelling test for soil treated by lime and/or hydraulic binder
    EN 13286-50:2004 Unbound and hydraulically bound mixtures - Part 50: Method for the manufacture of test specimens of hydraulically bound mixtures using Proctor equipment or vibrating table compaction
    EN 13286-51:2004 Unbound and hydraulically bound mixtures - Part 51: Method for the manufacture of test specimens of hydraulically bound mixtures using vibrating hammer compaction
    EN 13286-52:2004 Unbound and hydraulically bound mixtures - Part 52: Method for the manufacture of test specimens of hydraulically bound mixtures using vibrocompression
    EN 13286-53:2004 Unbound and hydraulically bound mixtures - Part 53: Methods for the manufacture of test specimens of hydraulically bound mixtures using axial compression
    CEN/TS 13286-54:2014 Unbound and hydraulically bound mixtures - Part 54: Test method for the determination of frost susceptibility - Resistance to freezing and thawing of hydraulically bound mixtures
    EN ISO 13473-1:2004 Characterization of pavement texture by use of surface profiles - Part 1: Determination of Mean Profile Depth (ISO 13473-1:1997)
    EN ISO 13473-5:2009 Characterization of pavement texture by use of surface profiles - Part 5: Determination of megatexture (ISO 13473-5:2009)
    EN 13863-1:2003 Concrete pavements - Part 1: Test method for the determination of the thickness of a concrete pavement by survey method
    EN 13863-2:2003 Concrete pavements - Part 2: Test method for the determination of the bond between two layers
    EN 13863-3:2004 Concrete pavements - Part 3: Test methods for the determination of the thickness of a concrete pavement from cores
    EN 13863-4:2012 Concrete pavements - Part 4: Test methods for the determination of wear resistance of concrete pavements to studded tyres
    EN 13877-1:2013 Concrete pavements - Part 1: Materials
    EN 13877-2:2013 Concrete pavements - Part 2: Functional requirements for concrete pavements
    EN 13877-3:2004 Concrete pavements - Part 3: Specifications for dowels to be used in concrete pavements
    EN 13880-1:2003 Hot applied joint sealants - Part 1: Test method for the determination of density at 25 °C
    EN 13880-2:2003 Hot applied joint sealants - Part 2: Test method for the determination of cone penetration at 25°C
    EN 13880-3:2003 Hot applied joint sealants - Part 3: Test method for the determination of penetration and recovery (resilience)
    EN 13880-4:2003 Hot applied joint sealants - Part 4: Test method for the determination of heat resistance - Change in penetration value
    EN 13880-5:2004 Hot applied joint sealants - Part 5: Test method for the determination of flow resistance
    EN 13880-6:2004 Hot applied joint sealants - Part 6: Method for the preperation of samples for testing
    EN 13880-7:2003 Hot applied joint sealants - Part 7: Function testing of joint sealants
    EN 13880-8:2003 Hot applied joint sealants - Part 8: Test method for the determination of the change in weight of fuel resistance joint sealants after fuel immersion
    EN 13880-9:2003 Hot applied joint sealants - Part 9: Test method for the determination of compatibility with asphalt pavements
    EN 13880-10:2003 Hot applied joint sealants - Part 10: Test method for the determination of adhesion and cohesion following continuous extension and compression
    EN 13880-11:2003 Hot applied joint sealants - Part 11: Test method for the preparation of asphalt test blocks used in the function test and for the determination of compatibility with asphalt pavements
    EN 13880-12:2003 Hot applied joint sealants - Part 12: Test method for the manufacture of concrete test blocks for bond testing (recipe methods)
    EN 13880-13:2003 Hot applied joint sealants - Part 13: Test method for the determination of the discontinuous extension (adherence test)
    EN 14187-1:2003 Cold applied joint sealants - Part 1:Test method for the determination of rate of cure
    EN 14187-2:2003 Cold applied joint sealants - Part 2:Test method for the determination of tack free time
    EN 14187-3:2003 Cold applied joint sealants - Part 3: Test method for the determination of self-levelling properties
    EN 14187-4:2003 Cold applied joint sealants - Part 4: Test method for the determination of the change in mass and volume after immersion in test fuel
    EN 14187-5:2003 Cold applied joint sealants - Part 5: Test method for the determination of the resistance to hydrolysis
    EN 14187-6:2003 Cold applied joint sealants - Part 6: Test method for the determination of the adhesion/cohesion properties after immersion in chemical liquids
    EN 14187-7:2003 Cold applied joint sealants - Part 7: Test method for the determination of the resistance to flame
    EN 14187-8:2003 Cold applied joint sealants - Part 8: Test method for the determination of the artificial weathering by UV-irradiation
    EN 14187-9:2006 Cold applied joint sealants - Test methods - Part 9: Function testing of joint sealants
    EN 14188-1:2004 Joint fillers and sealants - Part 1: Specifications for hot applied sealants
    EN 14188-2:2004 Joint fillers and sealants - Part 2: Specifications for cold applied sealants
    EN 14188-3:2006 Joint fillers and sealants - Part 3: Specifications for preformed joint seals
    EN 14188-4:2009 Joint fillers and sealants - Part 4: Specifications for primers to be used with joint sealants
    EN 14227-1:2013 Hydraulically bound mixtures - Specifications - Part 1: Cement bound granular mixtures
    EN 14227-2:2013 Hydraulically bound mixtures - Specifications - Part 2: Slag bound granular mixtures
    EN 14227-3:2013 Hydraulically bound mixtures - Specifications - Part 3: Fly ash bound granular mixtures
    EN 14227-4:2013 Hydraulically bound mixtures - Specifications - Part 4: Fly ash for hydraulically bound mixtures
    EN 14227-5:2013 Hydraulically bound mixtures - Specifications - Part 5: Hydraulic road binder bound granular mixtures
    EN 14227-15:2015 Hydraulically bound mixtures - Specifications - Part 15: Hydraulically stabilized soils
    EN 14840:2005 Joint fillers and sealants - Test methods for preformed joint seals
    CEN/TS 15901-1:2009 Road and airfield surface characteristics - Part 1: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal fixed slip ratio (LFCS): RoadSTAR
    CEN/TS 15901-2:2009 Road and airfield surface characteristics - Part 2: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal controlled slip (LFCRNL): ROAR (Road Analyser and Recorder of Norsemeter)
    CEN/TS 15901-3:2009 Road and airfield surface characteristics - Part 3: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal controlled slip (LFCA): The ADHERA
    CEN/TS 15901-4:2009 Road and airfield surface characteristics - Part 4: Procedure for determining the skid resistance of pavements using a device with longitudinal controlled slip (LFCT): Tatra Runway Tester (TRT)
    CEN/TS 15901-5:2009 Road and airfield surface characteristics - Part 5: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal controlled slip (LFCRDK): ROAR (Road Analyser and Recorder of Norsemeter)
    CEN/TS 15901-6:2009 Road and airfield surface characteristics - Part 6: Procedure for determining the skid resistance of a pavement surface by measurement of the sideway force coefficient (SFCS): SCRIM®
    CEN/TS 15901-7:2009 Road and airfield surface characteristics - Part 7: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal fixed slip ratio (LFCG): the GripTester®
    CEN/TS 15901-8:2009 Road and airfield surface characteristics - Part 8: Procedure for determining the skid resistance of a pavement surface by measurement of the sideway-force coefficient (SFCD): SKM
    CEN/TS 15901-9:2009 Road and airfield surface characteristics - Part 9: Procedure for determining the skid resistance of a pavement surface by measurement of the longitudinal friction coefficient (LFCD): DWWNL skid resistance trailer
    CEN/TS 15901-10:2009 Road and airfield surface characteristics - Part 10: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal block measurement (LFCSK): the Skiddometer BV-8
    CEN/TS 15901-11:2011 Road and airfield surface characteristics - Part 11: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal block measurement (LFCSR): the SRM
    CEN/TS 15901-12:2011 Road and airfield surface characteristics - Part 12: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal controlled slip: the BV 11 and Saab friction tester (SFT)
    CEN/TS 15901-13:2011 Road and airfield surface characteristics - Part 13: Procedure for determining the skid resistance of a pavement surface by measurement of a sideway force coefficient (SFCO): the Odoliograph
    CEN/TS 15901-14:2016 Road and airfield surface characteristics - Part 14: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal controlled slip (LFCN): ViaFriction (Road Analyser and Recorder of ViaTech AS)
    CEN/TS 15901-15:2014 Road and airfield surface characteristics - Part 15: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal controlled slip (LFCI): The IMAG
    EN 15466-1:2009 Primers for cold and hot applied joint sealants - Part 1: Determination of homogeneity
    EN 15466-2:2009 Primers for cold and hot applied joint sealants - Part 2: Determination of resistance against alkali
    EN 15466-3:2009 Primers for cold and hot applied joint sealants - Part 3: Determination of solids content and evaporation behaviour of volatiles
    missing are:
    links:
    or
    Re: CEN Standards Collection 343/350: CEN TC 227-Road Materials
    update:
    EN 12697-16:2016 Bituminous mixtures - Test methods - Part 16: Abrasion by studded tyres - added missing standard
    EN 12697-35:2016 Bituminous mixtures - Test methods - Part 35: Laboratory mixing - added missing standard
    EN 12697-25:2016 Bituminous mixtures - Test methods - Part 25: Cyclic compression test - added missing standard
    CEN/TS 12697-50:2016 Bituminous mixtures - Test methods - Part 50: Resistance to scuffing - added missing standard
    EN 13108-1:2016 Bituminous mixtures - Material specifications - Part 1: Asphalt Concrete - added missing standard thanks to Amjad Malik
    EN 13108-2:2016 Bituminous mixtures - Material specifications - Part 2: Asphalt Concrete for Very Thin Layers (BBTM) - added missing standard thanks to Amjad Malik
    EN 13108-3:2016 Bituminous mixtures - Material specifications - Part 3: Soft Asphalt - added missing standard thanks to Amjad Malik
    EN 13108-4:2016 Bituminous mixtures - Material specifications - Part 4: Hot Rolled Asphalt - added missing standard thanks to Amjad Malik
    EN 13108-5:2016 Bituminous mixtures - Material specifications - Part 5: Stone Mastic Asphalt - added missing standard thanks to Amjad Malik
    EN 13108-6:2016 Bituminous mixtures - Material specifications - Part 6: Mastic Asphalt - added missing standard thanks to Amjad Malik
    EN 13108-7:2016 Bituminous mixtures - Material specifications - Part 7: Porous Asphalt - added missing standard thanks to Amjad Malik
    EN 13108-8:2016 Bituminous mixtures - Material specifications - Part 8: Reclaimed asphalt - added missing standard thanks to Amjad Malik
    EN 13108-9:2016 Bituminous mixtures - Material specifications - Part 9: Asphalt for Ultra-Thin Layer (AUTL) - added missing standard thanks to Amjad Malik
    EN 13108-20:2016 Bituminous mixtures - Material specifications - Part 20: Type Testing - added missing standard thanks to Amjad Malik
    EN 13108-21:2016 Bituminous mixtures - Material specifications - Part 21: Factory Production Control - added missing standard thanks to Amjad Malik
    CEN/TS 15901-14:2016 Road and airfield surface characteristics - Part 14: Procedure for determining the skid resistance of a pavement surface using a device with longitudinal controlled slip (LFCN): ViaFriction (Road Analyser and Recorder of ViaTech AS) - added missing standard thanks to Amjad Malik
    sector complete
    or
  1. Replies: 11
    Last Post: 12-14-2018, 02:48 PM
  2. Replies: 7
    Last Post: 08-04-2018, 11:21 AM
  3. CEN Standards Collection 261/370: CEN TC 226-Road Equipment
    Last Post: 07-08-2017, 01:14 AM
  4. CEN Standards Collection 213/370: CEN SS T03-Road Vehicles
    Last Post: 06-16-2017, 11:39 PM
  5. Replies: 6
    Last Post: 05-29-2017, 01:14 AM
