Results 1 to 12 of 12
Thread: CEN Standards Collection 250/370: CEN TC 187-Refractory Products & Materials
    full list:
    EN 993-1:1995 Methods of test for dense shaped refractory products - Part 1: Determination of bulk density, apparent porosity and true porosity
    EN 993-2:1995 Methods of test for dense shaped refractory products - Part 2: Determination of true density
    EN 993-2:1995/A1:2003 Methods of test for dense shaped refractory products - Part 2 : Determination of true density
    EN 993-3:1997 Methods of test for dense shaped refractory products - Part 3: Test methods for carbon-containing refractories
    EN 993-4:1995 Methods of test for dense shaped refractory products - Part 4: Determination of permeability to gases
    EN 993-5:1998 Methods of test for dense shaped refractory products - Part 5: Determination of cold crushing strength
    EN 993-6:1995 Methods of test for dense shaped refractory products - Part 6: Determination of modulus of rupture at ambient temperature
    EN 993-7:1998 Methods of test for dense shaped refractory products - Part 7: Determination of modulus of rupture at elevated temperatures
    EN 993-9:1997 Methods of testing dense shaped refractory products - Part 9: Determination of creep in compression
    EN 993-10:1997 Methods of test for dense shaped refractory products - Part 10: Determination of permanent change in dimensions on heating
    EN 993-11:2007 Methods of test for dense shaped refractory products - Part 11: Determination of resistance to thermal shock
    EN 993-12:1997 Methods of test for dense shaped refractory products - Part 12: Determination of pyrometric cone equivalent (refractoriness)
    EN 993-13:1995 Methods of test for dense shaped refractory products - Part 13: Specification for pyrometric reference cones for laboratory use
    EN 993-15:2005 Methods of test for dense shaped refractory products - Determination of thermal conductivity by the hot-wire (parallel) method
    EN 993-16:1995 Dense shaped refractory products - Methods of test - Part 16: Determination of resistance to sulphuric acid
    EN 993-17:1998 Methods of test for dense shaped refractory products - Part 17: Determination of bulk density of granular materials by the mercury method with vacuum
    EN 993-18:2002 Methods of test for dense shaped refractory products - Part 18: Determination of bulk density of granular materials by the water method with vacuum
    EN 993-19:2004 Methods of test for dense shaped refractory products - Part 19: Determination of thermal expansion by a differential method
    EN 1094-1:2008 Insulating refractory products - Part 1: Terminology, classification and methods of test for high temperature insulation wool products
    EN 1094-2:1998 Insulating refractory products - Part 2: Classification of shaped products (ISO 2245:1990 modified)
    EN 1094-4:1995 Insulating refractory products - Part 4: Determination of bulk density and true porosity
    EN 1094-6:1998 Insulating refractory products - Part 6: Determination of permanent change in dimensions of shaped products on heating (ISO 2477:1987 modified)
    EN ISO 1893:2008 Refractory products - Determination of refractoriness under load - Differential method with rising temperature (ISO 1893:2007)
    EN ISO 1927-1:2012 Monolithic (unshaped) refractory products - Part 1: Introduction and classification (ISO 1927-1:2012)
    EN ISO 1927-2:2012 Monolithic (unshaped) refractory products - Part 2: Sampling for testing (ISO 1927-2:2012)
    EN ISO 1927-3:2012 Monolithic (unshaped) refractory products - Part 3: Characterization as received (ISO 1927-3:2012)
    EN ISO 1927-4:2012 Monolithic (unshaped) refractory products - Part 4: Determination of consistency of castables (ISO 1927-4:2012)
    EN ISO 1927-5:2012 Monolithic (unshaped) refractory products - Part 5: Preparation and treatment of test pieces (ISO 1927-5:2012)
    EN ISO 1927-6:2012 Monolithic (unshaped) refractory products - Part 6: Measurement of physical properties (ISO 1927-6:2012)
    EN ISO 1927-7:2012 Monolithic (unshaped) refractory products - Part 7: Tests on pre-formed shapes (ISO 1927-7:2012)
    EN ISO 1927-8:2012 Monolithic (unshaped) refractory products - Part 8: Determination of complementary properties (ISO 1927-8:2012)
    EN ISO 8894-1:2010 Refractory materials - Determination of thermal conductivity - Part 1: Hot-wire methods (cross-array and resistance thermometer) (ISO 8894-1:2010)
    EN ISO 8895:2006 Shaped insulating refractory products - Determination of cold crushing strength (ISO 8895:2004)
    EN ISO 10058-1:2008 Chemical analysis of magnesite and dolomite refractory products (alternative to the X-ray fluorescence method) - Part 1: Apparatus, reagents, dissolution and determination of gravimetric silica (ISO 10058-1:2008)
    EN ISO 10058-2:2008 Chemical analysis of magnesite and dolomite refractory products (alternative to the X-ray fluorescence method) - Part 2: Wet chemical analysis (ISO 10058-2:2008)
    EN ISO 10058-3:2008 Chemical analysis of magnesite and dolomite refractory products (alternative to the X-ray fluorescence method) - Part 3: Flame atomic absorption spectrophotometry (FAAS) and inductively coupled plasma atomic emission spectrometry (ICP-AES) (ISO 10058-3:20
    EN ISO 10081-1:2005 Classification of dense shaped refractory products - Part 1: Alumina-silica (ISO 10081-1:2003)
    EN ISO 10081-2:2005 Classification of dense shaped refractory products - Part 2: Basic products containing less than 7 % residual carbon (ISO 10081-2:2003)
    EN ISO 10081-3:2005 Classification of dense shaped refractory products - Part 3: Basic products containing from 7% to 50% residual carbon (ISO 10081-3:2003)
    EN ISO 10081-4:2014 Classification of dense shaped refractory products - Part 4: Special products (ISO 10081-4:2014)
    EN ISO 12676:2003 Refractory products - Determination of resistance to carbon monoxide (ISO 12676:2000)
    EN ISO 12677:2011 Chemical analysis of refractory products by X-ray fluorescence (XRF) - Fused cast-bead method (ISO 12677:2011)
    EN ISO 12680-1:2007 Methods of test for refractory products - Part 1: Determination of dynamic Young's modulus (MOE) by impulse excitation of vibration (ISO 12680-1:2005)
    EN 12698-1:2007 Chemical analysis of nitride bonded silicon carbide refractories - Part 1: Chemical methods
    EN 12698-2:2007 Chemical analysis of nitride bonded silicon carbide refractories - Part 2: XRD methods
    EN ISO 14719:2011 Chemical analysis of refractory material glass and glazes - Determination of Fe2+ and Fe3+ by the spectral photometric method with 1,10-phenanthroline (ISO 14719:2011)
    EN ISO 14720-1:2013 Testing of ceramic raw and basic materials - Determination of sulfur in powders and granules of non-oxidic ceramic raw and basic materials - Part 1: Infrared measurement methods (ISO 14720-1:2013)
    EN ISO 14720-2:2013 Testing of ceramic raw and basic materials - Determination of sulfur in powders and granules of non-oxidic ceramic raw and basic materials - Part 2: Inductively coupled plasma optical emission spectrometry (ICP/OES) or ion chromatography after burning in
    EN 14945:2005 Refractory products and materials - Spectrometric determination of chromium (VI) in chrome bearing refractories, before and after use
    CEN/TS 15418:2006 Methods of test for dense refractory products - Guidelines for testing the corrosion of refractories caused by liquids
    EN 15979:2011 Testing of ceramic raw and basic materials - Direct determination of mass fractions of impurities in powders and granules of silicon carbide by OES by DC arc excitation
    EN 15991:2015 Testing of ceramic and basic materials - Direct determination of mass fractions of impurities in powders and granules of silicon carbide by inductively coupled plasma optical emission spectrometry (ICP OES) with electrothermal vaporisation (ETV)
    EN ISO 16282:2008 Methods of test for dense shaped refractory products - Determination of resistance to abrasion at ambient temperature (ISO 16282:2007)
    EN ISO 20182:2008 Refractory test-piece preparation - Gunning refractory panels by the pneumatic-nozzle mixing type guns (ISO 20182:2008)
    EN ISO 20565-1:2008 Chemical analysis of chrome-bearing refractory products and chrome-bearing raw materials (alternative to the X-ray fluorescence method) - Part 1: Apparatus, reagents, dissolution and determination of gravimetric silica (ISO 20565-1:2008)
    EN ISO 20565-2:2008 Chemical analysis of chrome-bearing refractory products and chrome-bearing raw materials (alternative to the X-ray fluorescence method) - Part 2: Wet chemical analysis (ISO 20565-2:2008)
    EN ISO 20565-3:2008 Chemical analysis of chrome-bearing refractory products and chrome-bearing raw materials (alternative to the X-ray fluorescence method) - Part 3: Flame atomic absorption spectrometry (FAAS) and inductively coupled plasma atomic emission spectrometry (ICP-
    EN ISO 21068-1:2008 Chemical analysis of silicon-carbide-containing raw materials and refractory products - Part 1: General information and sample preparation (ISO 21068-1:2008)
    EN ISO 21068-2:2008 Chemical analysis of silicon-carbide-containing raw materials and refractory products - Part 2: Determination of loss on ignition, total carbon, free carbon and silicon carbide, total and free silica and total and free silicon (ISO 21068-2:2008)
    EN ISO 21068-3:2008 Chemical analysis of silicon-carbide-containing raw materials and refractory products - Part 3: Determination of nitrogen, oxygen and metallic and oxidic constituents (ISO 21068-3:2008)
    EN ISO 21078-1:2008 Determination of boron (III) oxide in refractory products - Part 1: Determination of total boron (III) oxide in oxidic materials for ceramics, glass and glazes (ISO 21078-1:2008)
    EN ISO 21078-2:2007 Determination of boron(III) oxide in refractory products - Part 2: Acid extraction method for the determination of boron(III) oxide in binder components (ISO 21078-2:2006)
    EN ISO 21079-1:2008 Chemical analysis of refractories containing alumina, zirconia and silica - Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) - Part 1: Apparatus, reagents and dissolution (ISO 21079-1:2008)
    EN ISO 21079-2:2008 Chemical analysis of refractories containing alumina, zirconia, and silica - Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) - Part 2: Wet chemical analysis (ISO 21079-2:2008)
    EN ISO 21079-3:2008 Chemical analysis of refractories containing alumina, zirconia, and silica - Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) - Part 3: Flame atomic absorption spectrophotometry (FAAS) and inductively
    EN ISO 21587-1:2007 Chemical analysis of aluminosilicate refractory products (alternative to the X-ray fluorescence method) - Part 1: Apparatus, reagents, dissolution and gravimetric silica (ISO 21587-1:2007)
    EN ISO 21587-2:2007 Chemical analysis of aluminosilicate refractory products (alternative to the X-ray fluorescence method) - Part 2: Wet chemical analysis (ISO 21587-2:2007)
    EN ISO 21587-3:2007 Chemical analysis of aluminosilicate refractory products (alternative to the X-ray fluorescence method) - Part 3: Inductively coupled plasma and atomic absorption spectrometry methods (ISO 21587-3:2007)
    EN ISO 26845:2008 Chemical analysis of refractories - General requirements for wet chemical analysis, atomic absorption spectrometry (AAS) and inductively coupled plasma atomic emission spectrometry (ICP-AES) methods (ISO 26845:2008)
    missing:
    Re: CEN Standards Collection 250/300: CEN TC 187-Refractory Products & Materials
    thanks Bro
    Great! Thanks a lot!
    still missing:
    new links:
    or
    Re: CEN Standards Collection 250/340: CEN TC 187-Refractory Products & Materials
    update:
    EN 993-11:2007 Methods of test for dense shaped refractory products - Part 11: Determination of resistance to thermal shock - EN version
    EN 1094-1:2008 Insulating refractory products - Part 1: Terminology, classification and methods of test for high temperature insulation wool products - EN version
    still missing one:
    new links:
    or
    CEN TC 248 is posssible?
    Re: CEN Standards Collection 250/350: CEN TC 187-Refractory Products & Materials
    still missing same one:
    new links:
    or
    Re: CEN Standards Collection 250/370: CEN TC 187-Refractory Products & Materials
    no changes* still missing:
    update:
    BQ or EN:
    EN ISO 20565-1:2008 Chemical analysis of chrome-bearing refractory products and chrome-bearing raw materials (alternative to the X-ray fluorescence method) - Part 1: Apparatus* reagents* dissolution and determination of gravimetric silica (ISO 20565-1:2008)
    EN ISO 21068-2:2008 Chemical analysis of silicon-carbide-containing raw materials and refractory products - Part 2: Determination of loss on ignition* total carbon* free carbon and silicon carbide* total and free silica and total and free silicon (ISO 21068-2:2008)
    EN ISO 21068-3:2008 Chemical analysis of silicon-carbide-containing raw materials and refractory products - Part 3: Determination of nitrogen* oxygen and metallic and oxidic constituents (ISO 21068-3:2008)
    EN ISO 21078-1:2008 Determination of boron (III) oxide in refractory products - Part 1: Determination of total boron (III) oxide in oxidic materials for ceramics* glass and glazes (ISO 21078-1:2008)
    EN ISO 21079-1:2008 Chemical analysis of refractories containing alumina* zirconia and silica - Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) - Part 1: Apparatus* reagents and dissolution (ISO 21079-1:2008)
    EN ISO 21079-2:2008 Chemical analysis of refractories containing alumina* zirconia* and silica - Refractories containing 5 percent to 45 percent of ZrO2 (alternative to the X-ray fluorescence method) - Part 2: Wet chemical analysis (ISO 21079-2:2008)
    EN ISO 21587-1:2007 Chemical analysis of aluminosilicate refractory products (alternative to the X-ray fluorescence method) - Part 1: Apparatus* reagents* dissolution and gravimetric silica (ISO 21587-1:2007)
    EN ISO 26845:2008 Chemical analysis of refractories - General requirements for wet chemical analysis* atomic absorption spectrometry (AAS) and inductively coupled plasma atomic emission spectrometry (ICP-AES) methods (ISO 26845:2008)
    still missing:
  13. Re: CEN Standards Collection 250/370: CEN TC 187-Refractory Products & Materials
    Quote Originally Posted by BornToSin View Post
    update:
    BQ or EN:
    still missing:
    Please new link!
    Thanks a Million!!!
  14. #11
    itworks*its some boardproblem
    http://
    use without spaces
  16. Re: CEN Standards Collection 250/370: CEN TC 187-Refractory Products & Materials
    Thank you very much for your contribution!
  1. CEN Standards Collection 245/370: CEN TC 411-Bio-based Products
    Last Post: 07-03-2017, 02:52 AM
  2. Replies: 10
    Last Post: 06-08-2017, 04:08 PM
  3. Replies: 6
    Last Post: 06-04-2017, 04:57 AM
  4. CEN Standards Collection 199/370: CEN SS C01-Food Products
