full list:
EN 204:2016 Classification of thermoplastic wood adhesives for non-structural applications
EN 205:2016 Adhesives - Wood adhesives for non-structural applications - Determination of tensile shear strength of lap joints
EN 301:2013 Adhesives, phenolic and aminoplastic, for load-bearing timber structures - Classification and performance requirements
EN 302-1:2013 Adhesives for load-bearing timber structures - Test methods - Part 1: Determination of longitudinal tensile shear strength
EN 302-2:2013 Adhesives for load-bearing timber structures - Test methods - Part 2: Determination of resistance to delamination
EN 302-3:2013 Adhesives for load-bearing timber structures - Test methods - Part 3: Determination of the effect of acid damage to wood fibres by temperature and humidity cycling on the transverse tensile strength
EN 302-4:2013 Adhesives for load-bearing timber structures - Test methods - Part 4: Determination of the effects of wood shrinkage on the shear strength
EN 302-5:2013 Adhesives for load-bearing timber structures - Test methods - Part 5: Determination of maximum assembly time under referenced conditions
EN 302-6:2013 Adhesives for load-bearing timber structures - Test methods - Part 6: Determination of the minimum pressing time under referenced conditions
EN 302-7:2013 Adhesives for load-bearing timber structures - Test methods - Part 7: Determination of the working life under referenced conditions
EN 542:2003 Adhesives - Determination of density
EN 543:2003 Adhesives - Determination of apparent density of powder and granule adhesives
EN 827:2005 Adhesives - Determination of conventional solids content and constant mass solids content
EN 828:2013 Adhesives - Wettability - Determination by measurement of contact angle and surface free energy of solid surface
EN 923:2015 Adhesives - Terms and definitions
EN 924:2003 Adhesives - Solvent-borne and solvent-free adhesives - Determination of flashpoint
EN 1067:2005 Adhesives - Examination and preparation of samples for testing
EN 1238:2011 Adhesives - Determination of the softening point of thermoplastic adhesives (ring and ball)
EN 1239:2011 Adhesives - Freeze-thaw stability
EN 1240:2011 Adhesives - Determination of hydroxyl value and/or hydroxyl content
EN 1241:1998 Adhesives - Determination of acid value
EN 1242:2013 Adhesives - Determination of isocyanate content
EN 1243:2011 Adhesives - Determination of free formaldehyde in amino and amidoformaldehyde condensates
EN 1244:1998 Adhesives - Determination of the colour and/or colour changes of adhesive coats under the influence of light
EN 1245:2011 Adhesives - Determination of pH
EN 1246:1998 Adhesives - Determination of ash and sulphated ash
EN 1372:2015 Adhesives - Test method for adhesives for floor and wall coverings - Peel test
EN 1373:2015 Adhesives - Test method for adhesives for floor and wall coverings - Shear test
EN 1392:2006 Adhesives for leather and footwear materials-Solvent-based and dispersion adhesives-Testing of bond strength under specified conditions
EN 1464:2010 Adhesives - Determination of peel resistance of adhesive bonds - Floating roller method
EN 1465:2009 Adhesives - Determination of tensile lap-shear strength of bonded assemblies
EN 1719:1998 Adhesives for paper and board, packaging and disposable sanitary products - Tack measurement for pressure sensitive adhesives - Determination of loop tack
EN 1720:1998 Adhesives for paper and board, packaging and disposable sanitary products - Determination of dispersability
EN 1721:1998 Adhesives for paper and board, packaging and disposable sanitary products - Track measurement for pressure sensitive adhesives - Determination of rolling ball track
EN 1841:1998 Adhesives - Test methods for adhesives for floor coverings and wall coverings - Determination of dimensional changes of a linoleum floor covering in contact with an adhesive
EN 1895:2001 Adhesives for paper and board, packaging and disposable sanitary products - 180° - "T" peel test for a flexible-to-flexible assembly
EN 1895:2001/AC:2007 Adhesives for paper and board, packaging and disposable sanitary products - 180°-"T" peel test for a flexible-to-flexible assembly
EN 1896:2001 Adhesives for paper and board, packaging and disposable sanitary products - Determination of tensile strength and elongation
EN 1902:2015 Adhesives - Test method for adhesives for floor and wall coverings - Shear creep test
EN 1903:2015 Adhesives - Test method for adhesives for plastic or rubber floor coverings or wall coverings - Determination of dimensional changes after accelerated ageing
EN 1937:1999 Test method for hydraulic setting floor smoothing and/or levelling compounds - Standard mixing procedures
EN 1939:2003 Self adhesive tapes - Determination of peel adhesion properties
EN 1942:2008 Self adhesive tapes - Measurement of Thickness
EN 1943:2002 Self adhesive tapes - Measurement of static shear adhesion
EN 1944:1996 Self-adhesive tapes - Measurement of unwind adhesion at low speed
EN 1945:1996 Self-adhesive tapes - Measurement of quick stick
EN 1965-1:2011 Structural adhesives - Corrosion - Part 1: Determination and classification of corrosion to a copper substrate
EN 1965-2:2011 Structural adhesives - Corrosion - Part 2: Determination and classification of corrosion to a brass substrate
EN 1966:2009 Structural adhesives - Characterization of a surface by measuring adhesion by means of the three point bending method
EN ISO 8510-2:2010 Adhesives - Peel test for a flexible-bonded-to-rigid test specimen assembly - Part 2: 180 degree peel (ISO 8510-2:2006)
EN ISO 9142:2003 Adhesives - Guide to the selection of standard laboratory ageing conditions for testing bonded joints (ISO 9142:2003)
EN ISO 9311-1:2005 Adhesives for thermoplastic piping systems - Part 1: Determination of film properties (ISO 9311-1:2005)
EN ISO 9311-2:2011 Adhesives for thermoplastic piping systems - Part 2: Determination of shear strength (ISO 9311-2:2011)
EN ISO 9311-3:2005 Adhesives for thermoplastic piping systems - Part 3: Test method for the determination of resistance to internal pressure (ISO 9311-3:2005)
EN ISO 9653:2000 Adhesives - Test method for shear impact strength of adhesive bonds (ISO 9653:1998)
EN ISO 9664:1995 Adhesives - Test methods for fatigue properties of structural adhesives in tensile shear (ISO 9664:1993)
EN ISO 9665:2000 Adhesives - Animal glues - Methods of sampling and testing (ISO 9665:1998)
EN ISO 10363:1995 Hot-melt adhesives - Determination of thermal stability (ISO 10363:1992)
EN ISO 10365:1995 Adhesives - Designation of main failure patterns (ISO 10365:1992)
EN ISO 11339:2010 Adhesives - T-peel test for flexible-to-flexible bonded assemblies (ISO 11339:2010)
EN ISO 11343:2005 Adhesives - Determination of dynamic resistance to cleavage of high-strength adhesive bonds under impact conditions - Wedge impact method (ISO 11343:2003)
EN 12023:1996 Self-adhesive tapes - Measurement of water transmission in a warm humid atmosphere
EN 12024:1996 Self-adhesive tapes - Measurement of resistance to elevated temperature and humidity
EN 12025:1996 Self-adhesive tapes - Measurement of tear resistance by the pendulum
EN 12026:1996 Self-adhesive tapes - Measurement of the unwinding force at high speed
EN 12027:1996 Self-adhesive tapes - Measurement of flame resistance
EN 12028:1996 Self-adhesive tapes - Measurement of elongation under static load
EN 12029:1996 Self-adhesive tapes - Determination of the water-soluble corrosive ions
EN 12030:1996 Self-adhesive tapes - Measurement of impact resistance
EN 12031:1996 Self-adhesive tapes - Measurement of bursting strength
EN 12032:1996 Self-adhesive tapes - Measurement of bonding of thermosetting adhesive tapes during curing
EN 12033:1996 Self-adhesive tapes - Measurement of bonding of thermosetting adhesive tapes after curing
EN 12034:1996 Self-adhesive tapes - Measurement of the length of a roll of adhesive tape
EN 12035:1996 Self-adhesive tapes - Flagging of adhesive tape
EN 12036:1996 Self-adhesive tapes - Solvent penetration into adhesive masking tapes
EN 12092:2001 Adhesives - Determination of viscosity
EN 12436:2001 Adhesives for load-bearing timber structures - Casein adhesives - Classification and performance requirements
EN 12481:2000 Self adhesive tapes - Terminology
EN 12701:2001 Structural adhesives - Storage - Determination of words and phrases relating to the product life of structural adhesives and related materials
EN 12702:2000 Adhesives for paper and board, packaging and disposable sanitary products - Determination of blocking behaviour of potentially adhesive layers
EN 12703:2016 Adhesives for paper and board, packaging and disposable sanitary products - Determination of low temperature flexibility or cold ***** temperature
EN 12704:2016 Adhesives for paper and board, packaging and disposable sanitary products - Determination of foam formation for aqueous adhesives
EN 12705:2011 Adhesives for leather and footwear materials - Determination of colour change of white or bright coloured leather surfaces by migration
EN 12706:1999 Adhesives - Test methods for hydraulic setting floor smoothing and/or levelling compounds - Determination of flow characteristics
EN 12765:2016 Classification of thermosetting wood adhesives for non-structural applications
EN 12960:2001 Adhesives for paper and board, packaging and disposable sanitary products - Determination of shear resistance
EN 12960:2001/AC:2007 Adhesives for paper and board, packaging and disposable sanitary products - Determination of shear resistance
EN 12961:2001 Adhesives for leather and footwear materials - Determination of optimum activation temperatures and maximum activation life of solvent-based and dispersion adhesives
EN 12961:2001/A1:2005 Adhesives for leather and footwear materials - Determination of optimum activation temperatures and maximum activation life or solvent-based and dispersion adhesives
EN 12962:2011 Adhesives - Determination of elastic behaviour of liquid adhesives (elasticity index)
EN 12963:2001 Adhesives - Determination of free monomer content in adhesives based on synthetic polymers
EN 12964:2001 Adhesives for leather and footwear materials - Lasting adhesives - Testing heat resistance of bonds at increasing temperature
EN 13408:2002 Methods of test for hydraulic setting floor smoothing and/or levelling compounds - Determination of bond strength
EN 13409:2002 Methods of test for hydraulic setting floor smoothing and/or levelling compounds - Determination of setting time
EN 13415:2010 Test of adhesives for floor covering - Determination of the electrical resistance of adhesive films and composites
EN ISO 13445:2006 Adhesives - Determination of shear strength of adhesive bonds between rigid substrates by the block-shear method (ISO 13445:2003)
EN 13872:2004 Methods of test for hydraulic setting floor smoothing and/or levelling compounds - Determination of dimensional change
EN 13887:2003 Structural Adhesives - Guidelines for surface preparation of metals and plastics prior to adhesive bonding
EN 13999-1:2013 Adhesives - Short term method for measuring the emission properties of low-solvent or solvent-free adhesives after application - Part 1: General procedure
EN 13999-2:2013 Adhesives - Short term method for measuring the emission properties of low-solvent or solvent-free adhesives after application - Part 2: Determination of volatile organic compounds
EN 13999-3:2007+A1:2009 Adhesives - Short term method for measuring the emission properties of low-solvent or solvent-free adhesives after application - Part 3: Determination of volatile aldehydes
EN 13999-4:2007+A1:2009 Adhesives - Short term method for measuring the emission properties of low-solvent or solvent-free adhesives after application - Part 4: Determination of volatile diisocyanates
EN 14022:2010 Structural Adhesives - Determination of the pot life (working life) of multi-component adhesives
EN 14256:2007 Adhesives for non-structural wood applications - Test method and requirements for resistance to static load
EN 14257:2006 Adhesives - Wood adhesives - Determination of tensile strength of lap joints at elevated temperature (WATT '91)
EN 14258:2004 Structural adhesives - Mechanical behaviour of bonded joints subjected to short and long terms exposure at specified conditions of temperature
EN 14259:2003 Adhesives for floor coverings - Requirements for mechanical and electrical performance
EN 14292:2005 Adhesives - Wood adhesives - Determination of static load resistance with increasing temperature
EN 14293:2006 Adhesives - Adhesives for bonding parquet to subfloor - Test methods and minimum requirements
EN 14294:2010 Adhesives for leather and footwear materials - Preparation of bonded test pieces by moulding-on processes
CR 14376:2002 Adhesives - Adhesives for paper and board, packaging and disposable sanitary products - Description and assessment of the setting process
EN 14410:2003 Self adhesive tapes - Measurement of breaking strength and elongation at break
EN 14444:2005 Structural adhesives - Qualitative assessment of durability of bonded assemblies - Wedge rupture test (ISO 10354:1992 modified)
EN 14444:2005/AC:2008 Structural adhesives - Qualitative assessment of durability of bonded assemblies - Wedge rupture test (ISO 10354:1992 modified)
EN 14510:2005 Adhesives for leather and footwear materials - Solvent-based and dispersion adhesives - Determination of sole positioning tack (spotting tack)
EN ISO 14678:2005 Adhesives - Determination of resistance to flow (sagging) (ISO 14678:2005)
EN 14680:2015 Adhesives for non-pressure thermoplastics piping systems - Specifications
EN 14713:2016 Adhesives for paper and board, packaging and disposable sanitary products - Determination of friction properties of films potentially suitable for bonding
EN 14814:2016 Adhesives for thermoplastic piping systems for fluids under pressure - Specifications
EN 14869-1:2011 Structural adhesives - Determination of shear behaviour of structural bonds - Part 1: Torsion test method using butt-bonded hollow cylinders (ISO 11003-1:2001, modified)
EN 14869-2:2011 Structural adhesives - Determination of shear behaviour of structural bonds - Part 2: Thick adherends shear test (ISO 11003-2:2001, modified)
CEN/TS 14999:2013 Adhesives for thermoplastic piping systems - Accelerated ageing test in storage container
EN 15062:2006 Adhesives for leather and footwear materials - Solvent-based and dispersion adhesives - Testing ageing of bonds under specified conditions
EN 15190:2007 Structural adhesives - Test methods for assessing long term durability of bonded metallic structures
EN 15274:2015 General purpose adhesives for structural assembly - Requirements and test methods
EN 15275:2015 Structural adhesives - Characterisation of anaerobic adhesives for co-axial metallic assembly in building and civil engineering structures
EN 15307:2014 Adhesives for leather and footwear materials - Sole-upper bonds - Minimum strength requirements
EN 15336:2007 Adhesives - Determination of the time to rupture of bonded joints under static load ( ISO 15109:1998 modified)
EN 15337:2007 Adhesives - Determination of shear strength of anaerobic adhesives using pin-and-collar specimens (ISO 10123:1990 modified)
EN 15416-2:2007 Adhesives for load bearing timber structures other than phenolic and aminoplastic - Test methods - Part 2: Static load test of multiple bondline specimens in compression shear
EN 15416-3:2007+A1:2010 Adhesives for load bearing timber structures other than phenolic and aminoplastic - Test methods - Part 3: Creep deformation test at cyclic climate conditions with specimens loaded in bending shear
EN 15416-4:2006 Adhesives for load bearing timber structures other than phenolic and aminoplastic - Test methods - Part 4: Determination of open assembly time for one component polyurethane adhesives
EN 15416-5:2006 Adhesives for load bearing timber structures other than phenolic and aminoplastic - Test methods - Part 5: Determination of conventional pressing time
EN 15425:2008 Adhesives - One component polyurethane for load bearing timber structures - Classification and performance requirements
EN ISO 15605:2004 Adhesives - Sampling (ISO 15605:2000)
EN 15865:2009 Adhesives - Determination of torque strength of anaerobic adhesives on threaded fasteners (ISO 10964:1993 modified)
EN 15870:2009 Adhesives - Determination of tensile strength of butt joints (ISO 6922:1987 modified)
EN ISO 15908:2002 Adhesives for thermoplastic piping systems - Test method for the determination of thermal stability of adhesives (ISO 15908:2002)
CEN/TR 15990:2010 Data Sheets - Footwear Tests Materials and Test Adhesives
CEN/TR 15990:2010/AC:2010 Data Sheets - Footwear Tests Materials and Test Adhesives
EN 16254:2013+A1:2016 Adhesives - Emulsion polymerized isocyanate (EPI) for load-bearing timber structures - Classification and performance requirements
EN 16556:2014 Determination of the maximum open time for thermoplastic wood adhesives for non-structural applications
EN 28510-1:2014 Adhesives - Peel test for a flexible-bonded-to-rigid test specimen assembly - Part 1: 90º peel
missing are:
links:
or
