Results 1 to 12 of 12
Thread: Request: IEEE 3000 Standards collection
    Dear all,
    Request you to share following IEEE 300 standards collections:
    a) P3000 - Recommended Practice for the Engineering of Industrial and Commercial Power Systems.
    b) 3001.5-2013 IEEE Recommended Practice for the Application of Power Distribution Apparatus in Industrial and Commercial Power Systems
    c) 3001.8-2013 IEEE Recommended Practice for the Instrumentation and Metering of Industrial and Commercial Power Systems
    d) 3001.5-2013 IEEE Recommended Practice for the Application of Power Distribution Apparatus in Industrial and Commercial Power Systems
    e) P3001.11 IEEE Draft Recommended Practice for Application of controllers and automation to Industrial and Commercial Power Systems (P)
    f) P3001.9 Recommended Practice for the Lighting of Industrial and Commercial Facilities (P) .
    g) P3001.4 Recommended Practice for Estimating the Costs of Industrial and Commercial Power Systems (P
    h) P3001.2 IEEE Recommended Practice for Evaluating the Electrical Service Requirements of Industrial and Commercial Power Systems (P).
    I) P3002.2 IEEE Recommended Practice for Conducting Load-Flow Studies of Industrial and Commercial Power Systems (P) .
    j)P3002.3 IEEE Recommended Practice for Conducting Short-Circuit Studies of Industrial and Commercial Power Systems (P) .
    k) P3002.7 IEEE Recommended Practice for Conducting Motor-Starting Studies in Industrial and Commercial Power Systems (P) .
    l) P3002.8 IEEE Recommended Practice for Conducting Harmonic-Analysis Studies of Industrial and Commercial Power Systems (P)
    m) 3003.2-2014 IEEE Recommended Practice for Equipment Grounding and Bonding in Industrial and Commercial Power Systems.
    n) P3004.3 Recommended Practice for the Application of Low-Voltage Fuses in Industrial and Commercial Power Systems (P) .
    o)P3004.4 Recommended Practice for the Application of Medium- and High-Voltage Fuses in Industrial and Commercial Power Systems (P) .
    p) P3004.7 Recommended Practice for the Protection of Power Cables and Busway Used in Industrial and Commercial Power Systems (P) .
    q) P3004.8 IEEE Recommended Practice for Motor Protection in Industrial and Commercial Power Systems (P) .
    r) P3004.9 Recommended Practice for the Protection of Power Transformers Used in Industrial and Commercial Power Systems (P) .
    s) P3004.10 Recommended Practice for Generator Protection in Industrial and Commercial Power Systems (P) .
    t) P3004.11 Recommended Practice for Bus and Switchgear Protection in Industrial and Commercial Power Systems (P) .
    u) P3004.13 Recommended Practice for Overcurrent Coordination in Industrial and Commercial Power Systems (P)
    v) P3005.4 Recommended Practice for Design and Operational Considerations for Improving the Reliability of Emergency and Stand-By Power Systems (P) .
    w) P3005.7 Recommended Practice for the Application of Metering for Energy Management of Industrial and Commercial Power Systems (P)
    - 3006.2-2016 IEEE Approved Draft Recommended Practice for Evaluating the Reliability of Existing Industrial and Commercial Power Systems
    Active Standard.
    -3006.5-2014 IEEE Recommended Practice for the Use of Probability Methods for Conducting a Reliability Analysis of Industrial and Commercial Power Systems
    Active Standard.
    -3006.7-2013 IEEE Recommended Practice for Determining the Reliability of 7x24 Continuous Power Systems in Industrial and Commercial Facilities
    Active Standard.
    -3006.9-2013 IEEE Recommended Practice for Collecting Data for Use in Reliability, Availability, and Maintainability Assessments of Industrial and Commercial Power Systems
    -P3006.3 Recommended Practice for Determining the Impact of Preventative Maintenance on the Reliability of Industrial and Commercial Power Systems (P) .
    -P3006.8 Recommended Practice for Analyzing Reliability Data for Equipment Used in Industrial and Commercial Power Systems (P)
    -3007.1-2010 IEEE Recommended Practice for the Operation and Management of Industrial and Commercial Power Systems.
    -3007.2-2010 IEEE Recommended Practice for the Maintenance of Industrial and Commercial Power Systems
    -3007.3-2012 IEEE Recommended Practice for Electrical Safety in Industrial and Commercial Power Systems
    Nov 2010
    Sweden
    Re: Request: IEEE 3000 Standards collection
    I just have IEEE Color Books!
    IEEE 3000 are not released yet, I can download any IEEE standard from company user. But IEEE 3000 are not possible to download. some documents related are uploaded, but that are not the standards that we are talking about.
    the standard start with P letter, means that is a proyect. not a released standard.
    how I can remove from a standard (pdf), a quote in every page, licenced to.... downloaded at yyyy/mm/dd hh:mm:ss
    Nov 2010
    Sweden
    Quote Originally Posted by himmelstern View Post
    you can cut the footer with Acrobat Professional! Then you can reprint the document via Acrobat printer.
    naaaaaaa
    Quote Originally Posted by raz View Post
    You cant if its secured,... But ithink hex edit can do it. Havent tried it.
    Nov 2010
    Sweden
    if pdf document is secured you can remove the security and password.--------------------- Is too easy!
    Nov 2010
    Sweden
    naaaaaaa
    what mean "naaaaaa" ??? I dont understand you
    añlksdfjasdklñjfkldasjflkasdjklf jaslñdkjflk
    it's a local expesón,
    Nov 2010
    Sweden
  14. #11
    the first IEEE3000 will be released this year
  16. #12
    Nov 2010
    Sweden
  1. IEEE Color Books / 3000 Standards
    By manuel_cv in forum Electrical & Power Engineering
    Last Post: 03-08-2019, 12:21 AM
  2. Request IEEE 3000 Series
    By hyuni0627 in forum Electrical & Power Engineering
    Last Post: 04-14-2016, 05:37 PM
  3. IEEE Power Transmission and Distribution Standards Collection: VuSpec™
    By raz in forum Electrical & Power Engineering
    Last Post: 09-01-2015, 07:21 PM
  4. IEEE 3000 Standards Collection™
    Last Post: 01-02-2015, 08:32 AM
