Hey guys!!!! ... I am collecting all standards of the collection: "IEEE Power Transmission and Distribution Standards Collection: VuSpec™"
Later I will post all standards in a single link for use of the community. I have some standards but I need others. I am working on that!
Please share with us if you have any standards of the following list:
IEEE Power Transmission and Distribution Standards Collection: VuSpec™ contains the latest standards,
guides, and recommended practices of the Institute of Electrical and Electronics Engineers, Inc. (IEEE)
Transmission and Distribution Committee. This collection represents the most complete resource available
for professional engineers looking for best practices and techniques treatment of all matters related to the
design, theoretical and experimental performance, installation, and service operation of parts of electric
power systems which serve to transmit electric energy between the generating sources and substations or
customer points of common coupling through AC or DC lines.
It covers the analysis and treatment of the following areas are included: Overhead and underground AC
and DC transmission and distribution systems; Flexible AC transmission systems (FACTS); Overhead
conductors; Environmental impact of transmission lines; Lightning phenomena; Secondary network
systems; Insulated line conductors; Structural coordination and mechanical problems of transmission
lines; Switching surges and overvoltage phenomena; Insulation coordination (jointly with other
Committees); Inductive coordination; Corona, electric fields, and magnetic fields; Towers, poles,
insulators, and hardware; Shunt and series capacitors; Engineering in the safety, maintenance, and
operation of lines; Harmonics and power quality; Distributed resources and distributed generation;
Superconductivity analysis and devices; Integration of renewable energy sources into T&D systems;
Security in T&D systems.
Table of Contents:
Active
• IEEE18-2012, IEEE Standard for Shunt Power Capacitors
• IEEE Std 516™-2009, IEEE Guide for Maintenance Methods on Energized Power Lines
• IEEE 519-2014, IEEE Recommended Practice and Requirements for Harmonic Control in Electric
Power Systems
• IEEE524-2003, IEEE Guide to the Installation of Overhead Transmission Line Conductors (Revision
of IEEE Std 524 - 1992)
• IEEE Std 539™-2005 (R2010), Definitions of Terms Relating to Corona and Field Effects of
Overhead Power Lines
• IEEE 563-1978 (R2007), IEEE Guide on Conductor Self-Damping Measurements
• IEEE 644-1994 (R2008), IEEE Standard Procedures for Measurement of Power Frequency Electric
and Magnetic Fields From AC Power Lines
• IEEE 656-1992, IEEE Standard for the Measurement of Audible Noise From Overhead Transmission
Lines
• IEEE 664-1993 (R2007), IEEE Guide for Laboratory Measurement of the Power Dissipation
Characteristics of Aeolian Vibaration
• IEEE 691-2001 (R2007) IEEE Guide for Transmission Structure Foundation Design and Testing
• IEEE 738-2012, IEEE Standard for Calculating the Current-Temperature Relationship of Bare
Overhead Conductors
• IEEE Std 824™-2004,IEEE Standard for Series Capacitor Banks in Power Systems
• IEEE 935-1989 (R2011), IEEE Guide on Terminology for Tools and Equipment to Be Used in Live
Line Working
• IEEE 951-1996 (R2009), IEEE Guide to the Assembly and Erection of Metal Transmission Structures
• IEEE Std 957™-2005, IEEE Guide for Cleaning Insulators
• IEEE 977-2010, IEEE Guide to Installation of Foundations for Transmission Line Structures
• IEEE 1025-1993 (R2011), IEEE Guide to the Assembly and Erection of Concrete Pole Structures
• IEEE1036-2010, IEEE Guide for the Application of Shunt Power Capacitors
• IEEE1048-2003, IEEE Guide for Protective Grounding of Power Lines
• IEEE 1124-2003, IEEE Guide for the Analysis and Definition of DC-Side Harmonic Performance of
HVDC Transmission Systems
• IEEE Std 1067™-2012, IEEE Guide for In-Service Use, Care, Maintenance, and Testing of
Conductive Clothing for Use on Voltages up to 765 kV ac and 1750 kV dc
• IEEE Std 1070™-2006 (R2012), Design and Testing of Transmission Modular Restoration Structure
Components
• IEEE 1124-2003 (R2010), IEEE Guide for Analysis and Definition of DC Side Harmonic Performance
of HVDC Transmission Systems
• IEEE 1159-2009, IEEE Recommended Practice for Monitoring Electric Power Quality
• IEEE 1159.3-2003 (R2009), IEEE Recommended Practice for the Transfer of Power Quality Data
• IEEE 1204-1997, IEEE Guide for Planning DC Links Terminating at AC Locations Having Low ShortCircuit
Capacities
• IEEE 1217-2001 (R2009), IEEE Guide for Preservative Treatment of Wood Distribution and
• IEEE 1227-1990 (R2001), IEEE Guide for the Measurement of DC Electric-Field Strength and Ion
Related Quantities
• IEEE 1243-1997 (R2008), IEEE Guide for Improving the Lightning Performance of Transmission
Lines
• IEEE 1250-2011, IEEE Guide for Service to Equipment Sensitive to Momentary Voltage
Disturbances
• IEEE 1260-1996 (R2007), IEEE Guide on the Prediction, Measurement, and Analysis of AM
Broadcast Reradiation by Power Lines
• IEEE 1283-2013, IEEE Guide for Determining the Effects of High-Temperature Operation on
Conductors, Connectors, and Accessories
• IEEE 1307-2004 (R2008), IEEE Standard for Fall Protection for Utility Work - IEEE Power
Engineering Society
• IEEE 1308-1994 (R2010, IEEE Recommended Practice for Instrumentation: Specifications for
Magnetic Flux Density and Electric Field Strength Meters-10 Hz to 3 kHz
• IEEE 1366-2012, IEEE Guide for Electric Power Distribution Reliability Indices
• IEEE Std 1368™-2006, IEEE Guide for Aeolian Vibration Field Measurements of Overhead
Conductors
• IEEE 1409-2012, EEE Guide for Application of Power Electronics for Power Quality Improvement on
Distribution Systems Rated 1 kV Through 38 kV
• IEEE 1410-2010, IEEE Guide for Improving the Lightning Performance of Electric Power Overhead
Distribution Lines
• IEEE 1453-2011, IEEE Recommended Practice--Adoption of IEC 61000-4-15:2010, Electromagnetic
compatibility (EMC)--Testing and measurement techniques--Flickermeter--Functional and design
specifications
• IEEE 1453.1-2012, IEEE Guide--Adoption of IEC/TR 61000-3-7:2008, Electromagnetic compatibility
(EMC)--Limits--Assessment of emission limits for the connection of fluctuating installations to MV,
HV and EHV power systems
• IEEE 1531-2003 (R2009), IEEE Guide for Application and Specification of Harmonic Filters
• IEEE 1542-2007, IEEE Guide for Installation, Maintenance, and Operation of Irrigation Equipment
Located Near or Under Power Lines
• IEEE 1564-2014, IEEE Guide for Voltage Sag Indices
• IEEE 1613.1-2013, IEEE Standard Environmental and Testing Requirements for Communications
Networking Devices Installed in Transmission and Distribution Facilities
• IEEE 1651-2010, IEEE Guide for Reducing Bird-Related Outages
• IEEE 1654-2009, IEEE Guide for RF Protection of Personnel Working in the Vicinity of Wireless
Communications Antennas Attached to Electric Power Line Structures
• IEEE 1656-2010, IEEE Guide for Testing the Electrical, Mechanical, and Durability Performance of
Wildlife Protective Devices on Overhead Power Distribution Systems Rated up to 38 kV
• IEEE 1676-2010, IEEE Guide for Control Architecture for High Power Electronics (1 MW and
Greater) Used in Electric Power Transmission and Distribution Systems
• IEEE 1724-2011, IEEE Guide for the Preparation of a Transmission Line Design Criteria Document
• IEEE 1726-2013, IEEE Guide for the Functional Specification of Fixed-Series Capacitor Banks for
Transmission System Applications
• IEEE 1782-2014, IEEE Guide for Collecting, Categorizing, and Utilizing Information Related to
Electric Power Distribution Interruption Events
• IEEE 1808-2011, IEEE Guide for Collecting and Managing Transmission Line Inspection and
Maintenance Data
• IEEE 1815-2012, IEEE Standard for Electric Power Systems Communications-Distributed Network
Protocol (DNP3)
• IEEE/ANSI C93.5-1997, American National Standard Requirements for Single
Function Power-Line Carrier Transmitter/Receiver Equipment
• IEEE C135.1-1999, IEEE Standard for Zinc-Coated Steel Bolts and Nuts for Overhead Line
Construction
• IEEE C135.2-1999, IEEE Standard for Threaded Zinc-Coated Ferrous Strand-Eye Anchor Rods and
Nuts for Overhead Line Construction
• IEEE C135.3-2001, IEEE Standard for Zinc-Coated Ferrous Lag Screws for Overhead Line
Construction
• IEEE C135.20-1998 (R2010), IEEE Standard for Zinc-Coated Ferrous Insulator Clevises for
• IEEE C135.62-2009, IEEE Standard for Zinc-Coated Forged Anchor S****les
• IEEE C135.61-1997 (R2006), IEEE Standard for the Testing of Overhead Transmission and
Distribution Line Hardware
• IEEE C135.63-1998 (R2006), IEEE Standard for Shoulder Live Line Extension Links for Overhead
Line Construction
• IEEE C135.64-2012, IEEE Guide for Slip and Pull-Out Strength Testing of Bolted Dead End Strain
Clamps
• IEEE C135.80-2012, EEE Standard for Fasteners for Overhead Line Construction
• IEEE C135.90-2014, IEEE Standard for Pole Line Hardware for Overhead Line Construction
Archived
• IEEE 1441-2004 - IEEE Guide for Inspection of Overhead Transmission Line Construction
• IEEE C135.14-1979 - American National Standard staples with rolled or slush points for overhead
line construction
THANK YOU FOR YOUR FUTURE CONTRIBUTION!
Raz
