full list:
EN 16601-00-01:2015 Space systems - Glossary of terms
EN 16601-10:2015 Space project management - Project planning and implementation
EN 16601-10-01:2014 Space project management - Part 10-01: Organization and conduct of reviews
EN 16601-40:2014 Space project management - Configuration and information management
EN 16601-60:2014 Space project management - Cost and schedule management
EN 16601-80:2014 Space project management - Part 80: Risk management
EN 16602-10-04:2014 Space product assurance - Critical-item control
EN 16602-10-09:2014 Space product assurance - Nonconformance control system
EN 16602-20:2014 Space product assurance - Quality assurance
EN 16602-20-10:2014 Space product assurance - Off-the-shelf items utilization in space systems
EN 16602-30-02:2014 Space product assurance - Failure modes, effects (and criticality) analysis (FMEA/FMECA)
EN 16602-30-09:2014 Space product assurance - Availability analysis
EN 16602-30-11:2014 Space product assurance - Derating - EEE components
EN 16602-40-02:2014 Space product assurance - Hazard analysis
EN 16602-40-12:2014 Space product assurance - Fault tree analysis - Adoption notice ECSS/IEC 61025
EN 16602-60:2015 Space product assurance - Electrical, electronic and electromechanical (EEE) components
EN 16602-60-02:2014 Space product assurance - ASIC and FPGA development
EN 16602-60-05:2014 Space product assurance - Generic procurement requirements for hybrids
EN 16602-60-12:2014 Space product assurance - Design, selection, procurement and use of die form monolithic microwave integrated circuits (MMICs)
EN 16602-60-13:2015 Space product assurance - Requirements for the use of COTS components
EN 16602-60-14:2014 Space product assurance - Relifing procedure - EEE components
EN 16602-60-15:2014 Space product assurance - Radiation hardness assurance - EEE components
EN 16602-70-01:2014 Space product assurance - Cleanliness and contamination control
EN 16602-70-02:2014 Space product assurance - Thermal vacuum outgassing test for the screening of space materials
EN 16602-70-03:2014 Space product assurance - Black-anodizing of metals with inorganic dyes
EN 16602-70-04:2014 Space product assurance - Thermal testing for the evaluation of space materials, processes, mechanical parts and assemblies
EN 16602-70-05:2014 Space product assurance - Detection of organic contamination surfaces by infrared spectroscopy
EN 16602-70-06:2014 Space product assurance - Particle and UV radiation testing for space materials
EN 16602-70-07:2014 Space product assurance - Verification and approval of automatic machine wave soldering
EN 16602-70-08:2015 Space product assurance - Manual soldering of high-reliability electrical connections
EN 16602-70-09:2015 Space product assurance - Measurements of thermo-optical properties of thermal control materials
EN 16602-70-10:2015 Space product assurance - Qualification of printed circuit boards
EN 16602-70-11:2015 Space product assurance - Procurement of printed circuit boards
EN 16602-70-13:2015 Space product assurance - Measurements of the peel and pull-off strength of coatings and finishes using pressure-sensitive tapes
EN 16602-70-18:2014 Space product assurance - Preparation, assembly and mounting of RF coaxial cables
EN 16602-70-20:2014 Space product assurance - Determination of the susceptibility of silver-plated copper wire and cable to "red-plague" corrosion
EN 16602-70-21:2014 Space product assurance - Flammability testing for the screening of space materials
EN 16602-70-22:2014 Space product assurance - Control of limited shelf-life materials
EN 16602-70-26:2014 Space product assurance - Crimping of high-reliability electrical connections
EN 16602-70-28:2014 Space product assurance - Repair and modification of printed circuit board assemblies for space use
EN 16602-70-29:2014 Space product assurance - Determination of offgassing products from materials and assembled articles to be used in a manned space vehicle crew compartment
EN 16602-70-30:2014 Space product assurance - Wire wrapping of high-reliability electrical connections
EN 16602-70-31:2014 Space product assurance - Application of paints and coatings on space hardware
EN 16602-70-36:2014 Space product assurance - Material selection for controlling stress-corrosion *****ing
EN 16602-70-37:2014 Space product assurance - Determination of the susceptibility of metals to stress-corrosion *****ing
EN 16602-70-45:2014 Space product assurance - Mechanical testing of metallic materials
EN 16602-70-46:2014 Space product assurance - Requirements for manufacturing and procurement of threaded fasteners
EN 16602-70-50:2015 Space product assurance - Particles contamination monitoring for spacecraft systems and cleanrooms
EN 16602-70-53:2015 Space product assurance - Materials and hardware compatibility tests for sterilization processes
EN 16602-70-55:2015 Space product assurance - Microbiological examination of flight hardware and cleanrooms
EN 16602-70-56:2015 Space product assurance - Vapour Phase Bioburden Reduction for Flight Hardware
EN 16602-70-57:2015 Space product assurance - Dry Heat Bioburden Reduction for Flight Hardware
EN 16602-70-58:2015 Space product assurance - Bioburden control of cleanrooms
EN 16603-10-03:2014 Space engineering - Testing
EN 16603-10-04:2015 Space engineering - Space environment
EN 16603-10-06:2014 Space engineering - Part 10-06: Technical requirements specification
EN 16603-10-09:2014 Space engineering - Reference coordinate system
EN 16603-10-11:2014 Space engineering - Human factors engineering
EN 16603-10-12:2014 Space engineering - Method for the calculation of radiation received and its effects, and a policy for design margins
EN 16603-20-06:2014 Space engineering - Spacecraft charging
EN 16603-20-07:2014 Space engineering - Electromagnetic compatibility
EN 16603-20-08:2014 Space engineering - Part 20-08: Photovoltaic assemblies and components
EN 16603-31:2014 Space engineering - Thermal control general requirements
EN 16603-31-02:2015 Space engineering - Two-phase heat transport equipment
EN 16603-32:2014 Space engineering - Structural general requirements
EN 16603-32-01:2014 Space engineering - Fracture control
EN 16603-32-02:2014 Space engineering - Structural design and verification of pressurized hardware
EN 16603-32-03:2014 Space engineering - Structural finite element models
EN 16603-32-10:2014 Space engineering - Structural factors of safety for spaceflight hardware
EN 16603-32-11:2014 Space engineering - Structural factors of safety for spaceflight hardware
EN 16603-34:2014 Space engineering - Part 34: Environmental control and life support (ECLS)
EN 16603-35:2014 Space engineering - Propulsion general requirements
EN 16603-35-01:2014 Space engineering - Liquid and electric propulsion for spacecraft
EN 16603-35-02:2014 Space engineering - Solid propulsion for spacecrafts and launchers
EN 16603-35-03:2014 Space engineering - Liquid propulsion for launchers
EN 16603-35-06:2014 Space engineering - Cleanliness requirements for spacecraft propulsion hardware
EN 16603-35-10:2014 Space engineering - Compatibility testing for liquid propulsion components, subsystems and systems
EN 16603-40:2014 Space engineering - Part 40: Software
EN 16603-50:2014 Space engineering - Communications
EN 16603-50-01:2014 Space engineering - Space data links - Telemetry synchronization and channel coding
EN 16603-50-02:2014 Space engineering - Ranging and Doppler tracking
EN 16603-50-03:2014 Space engineering - Space data links - Telemetry transfer frame protocol
EN 16603-50-04:2014 Space engineering - Space data links - Telecommand protocols, synchronization and channel coding
EN 16603-50-05:2014 Space engineering - Radio frequency and modulation
EN 16603-50-13:2014 Space engineering - Interface and communication protocol for MIL-STD-1553B data bus onboard spacecraft
EN 16603-50-14:2014 Space engineering - Spacecraft discrete interfaces
EN 16603-50-51:2014 Space engineering - SpaceWire protocol identification
EN 16603-50-52:2014 Space engineering - SpaceWire - Remote memory access protocol
EN 16603-50-53:2015 Space engineering - SpaceWire - CCSDS packet transfer protocol
EN 16603-60-10:2014 Space engineering - Control performances
EN 16603-60-20:2014 Space engineering - Star sensor terminology and performance specification
EN 16603-60-30:2015 Space engineering - Satellite AOCS requirements
EN 16603-70:2015 Space engineering - Ground systems and operations
EN 16603-70-01:2015 Space engineering - On-board control procedures
EN 16603-70-11:2015 Space engineering - Space segment operability
EN 16603-70-31:2015 Space engineering - Ground systems and operations - Monitoring and control data definition
EN 16603-70-32:2014 Space engineering - Test and operations procedure language
EN 16604-10:2014 Space sustainability - Adoption Notice of ISO 24113: Space systems - Space debris mitigation requirements
missing list:
linkz:
or
