full list:
EN ISO 9862:2005 Geosynthetics - Sampling and preparation of test specimens (ISO 9862:2005)
EN ISO 9863-1:2005 Geosynthetics - Determination of thickness at specified pressures - Part 1: Single layers (ISO 9863-1:2005)
EN ISO 9863-2:1996 Geotextiles and geotextile-related products - Determination of thickness at specified pressures - Part 2: Procedure for determination of thickness of single layers of multilayer products (ISO 9863-2:1996)
EN ISO 9864:2005 Geosynthetics - Test method for the determination of mass per unit area of geotextiles and geotextile-related products (ISO 9864:2005)
EN ISO 10318-1:2015 Geosynthetics - Part 1: Terms and definitions (ISO 10318-1:2015)
EN ISO 10318-2:2015 Geosynthetics - Part 2: Symbols and pictograms (ISO 10318-2:2015)
EN ISO 10319:2015 Geosynthetics - Wide-width tensile test (ISO 10319:2015)
EN ISO 10320:1999 Geotextiles and geotextile-related products - Identification on site (ISO 10320:1999)
EN ISO 10321:2008 Geosynthetics - Tensile test for joints/seams by wide-width strip method (ISO 10321:2008)
EN ISO 10722:2007 Geosynthetics - Index test procedure for the evaluation of mechanical damage under repeated loading - Damage caused by granular material (ISO 10722:2007)
EN ISO 10769:2011 Clay geosynthetic barriers - Determination of water absorption of bentonite (ISO 10769:2011)
EN ISO 10772:2012 Geotextiles - Test method for the determination of the filtration behaviour of geotextiles under turbulent water flow conditions (ISO 10772:2012)
EN ISO 10773:2011 Clay geosynthetic barriers - Determination of permeability to gases (ISO 10773:2011)
EN ISO 10776:2012 Geotextiles and geotextile-related products - Determination of water permeability characteristics normal to the plane, under load (ISO 10776:2012)
EN ISO 11058:2010 Geotextiles and geotextile-related products - Determination of water permeability characteristics normal to the plane, without load (ISO 11058:2010)
EN 12224:2000 Geotextiles and geotextile-related products - Determination of the resistance to weathering
EN 12225:2000 Geotextiles and geotextile-related products - Method for determining the microbiological resistance by a soil burial test
EN 12226:2012 Geosynthetics - General tests for evaluation following durability testing
EN ISO 12236:2006 Geosynthetics - Static puncture test (CBR test) (ISO 12236:2006)
EN 12447:2001 Geotextiles and geotextile-related products - Screening test method for determining the resistance to hydrolysis in water
EN ISO 12956:2010 Geotextiles and geotextile-related products - Determination of the characteristic opening size (ISO 12956:2010)
EN ISO 12957-1:2005 Geosynthetics - Determination of friction characteristics - Part 1: Direct shear test (ISO 12957-1:2005)
EN ISO 12957-2:2005 Geosynthetics - Determination of friction characteristics - Part 2: Inclined plane test (ISO 12957-2:2005)
EN ISO 12958:2010 Geotextiles and geotextile-related products - Determination of water flow capacity in their plane (ISO 12958:2010)
EN ISO 13426-1:2003 Geotextiles and geotextile-related products - Strength of internal structural junctions - Part 1: Geocells (ISO 13426-1:2003)
EN ISO 13426-2:2005 Geotextiles and geotextile-related products - Strength of internal structural junctions - Part 2: Geocomposites (ISO 13426-2:2005)
EN ISO 13427:2014 Geosynthetics - Abrasion damage simulation (sliding block test) (ISO 13427:2014)
EN ISO 13428:2005 Geosynthetics - Determination of the protection efficiency of a geosynthetic against impact damage (ISO 13428:2005)
EN 13249:2014+A1:2015 Geotextiles and geotextile-related products - Characteristics required for use in the construction of roads and other trafficked areas (excluding railways and asphalt inclusion)
EN 13250:2014+A1:2015 Geotextiles and geotextile-related products - Characteristics required for use in the construction of railways
EN 13251:2014+A1:2015 Geotextiles and geotextile-related products - Characteristics required for use in earthworks, foundations and retaining structures
EN 13252:2014+A1:2015 Geotextiles and geotextile-related products - Characteristics required for use in drainage systems
EN 13253:2014+A1:2015 Geotextiles and geotextile-related products - Characteristics required for use in erosion control works (coastal protection, bank revetments)
EN 13254:2014+A1:2015 Geotextiles and geotextile-related products - Characteristics required for use in the construction of reservoirs and dams
EN 13255:2014+A1:2015 Geotextiles and geotextile-related products - Characteristics required for use in the construction of canals
EN 13256:2014+A1:2015 Geotextiles and geotextile-related products - Characteristics required for use in the construction of tunnels and underground structures
EN 13257:2014+A1:2015 Geotextiles and geotextile-related products - Characteristics required for use in solid waste disposals
EN 13265:2014+A1:2015 Geotextiles and geotextile-related products - Characteristics required for use in liquid waste containment projects
EN 13361:2013 Geosynthetic barriers - Characteristics required for use in the construction of reservoirs and dams
EN 13362:2013 Geosynthetic barriers - Characteristics required for use in the construction of canals
EN ISO 13431:1999 Geotextiles and geotextile-related products - Determination of tensile creep and creep rupture behaviour (ISO 13431:1999)
EN ISO 13433:2006 Geosynthetics - Dynamic perforation test (cone drop test) (ISO 13433:2006)
EN ISO 13437:1998 Geotextiles and geotextile-related products - Method for installing and extracting samples in soil, and testing specimens in laboratory (ISO 13437:1998)
EN ISO 13438:2004 Geotextiles and geotextile-related products - Screening test method for determining the resistance to oxidation (ISO 13438:2004)
EN 13491:2013 Geosynthetic barriers - Characteristics required for use as a fluid barrier in the construction of tunnels and associated underground structures
EN 13492:2013 Geosynthetic barriers - Characteristics required for use in the construction of liquid waste disposal sites, transfer stations or secondary containment
EN 13493:2013 Geosynthetic barriers - Characteristics required for use in the construction of solid waste storage and disposal sites
EN 13562:2000 Geotextiles and geotextile-related products - Determination of resistance to penetration by water (hydrostatic pressure test)
EN 13719:2016 Geosynthetics - Determination of the long term protection efficiency of geosynthetics in contact with geosynthetic barriers
EN 13738:2004 Geotextiles and geotextile-related products - Determination of pullout resistance in soil
EN 14030:2001 Geotextiles and geotextile-related products - Screening test method for determining the resistance to acid and alkaline liquids (ISO/TR 12960:1998, modified)
EN 14030:2001/A1:2003 Geotextiles and geotextile-related products - Screening test method for determining the resistance to acid and alkaline liquids (ISO/TR 12960:1998, modified)
EN 14150:2006 Geosynthetic barriers - Determination of permeability to liquids
EN 14151:2010 Geosynthetics - Determination of burst strength
EN 14196:2016 Geosynthetics - Test methods for measuring mass per unit area of clay geosynthetic barriers
EN 14414:2004 Geosynthetics - Screening test method for determining chemical resistance for landfill applications
EN 14415:2004 Geosynthetic barriers - Test method for determining the resistance to leaching
CEN/TS 14416:2014 Geosynthetic barriers - Test method for determining the resistance to roots
CEN/TS 14417:2014 Geosynthetic barriers - Test method for the determination of the influence of wetting-drying cycles on the permeability of clay geosynthetic barriers
CEN/TS 14418:2014 Geosynthetic Barriers - Test method for the determination of the influence of freezing-thawing cycles on the permeability of clay geosynthetic barriers
EN 14574:2015 Geosynthetics - Determination of the pyramid puncture resistance of supported geosynthetics
EN 14575:2005 Geosynthetic barriers - Screening test method for determining the resistance to oxidation
EN 14576:2005 Geosynthetics - Test method for determining the resistance of polymeric geosynthetic barriers to environmental stress *****ing
CEN/TR 15019:2005 Geotextiles and geotextile-related products - On-site quality control
EN 15381:2008 Geotextiles and geotextile-related products - Characteristics required for use in pavements and asphalt overlays
EN 15382:2013 Geosynthetic barriers - Characteristics required for use in transportation infrastructure
EN 16416:2013 Geosynthetic clay barriers - Determination of water flux index - Flexible wall permeameter method at constant head
EN ISO 25619-1:2008 Geosynthetics - Determination of compression behaviour - Part 1: Compressive creep properties (ISO 25619-1:2008)
EN ISO 25619-2:2015 Geosynthetics - Determination of compression behaviour - Part 2: Determination of short-term compression behaviour (ISO 25619-2:2015)
missing standards:
links:
or
