Thread: Estimating dew point pressure for a gas condensate lead
  1. Question Estimating dew point pressure for a gas condensate lead
    Hi!
    Is there any idea about the Initial/Dew point deltaP range for a gas condensate lead?
    Assuming that many condensate fields has an oil rim, then a conservative case could be Pdewpoint is very close to Pi.
    But for an optimistic case, how low dew point can be assumed?
    Re: Estimating dew point pressure for a gas condensate lead
    in this case Pd is equal the pressure at GOC.... but at the top, the dew point pressure could/should be lower, due to the compositional gradient ...
  5. Question Re: Estimating dew point pressure for a gas condensate lead
    Quote Originally Posted by REGI_MAX View Post
    I would also assume that in most of the cases, gas condensate fields, may have an oil rim, and in this case, as you said Pd slightly vary because compositional gradient, but even at the top of the reservoir dew point remain close to initial pressure. That mean shortly after production is started condensate will start dropping into the reservoir.
    This is clear.
    But what are the chances for a gas condensate field to have very low dew point compare with initial pressure?
    (let.s say half from initial pressure)
  1. condensate reservoir dew point pressure
    By shantia762 in forum Reservoir
    Last Post: 06-11-2016, 11:00 AM
  2. Replies: 0
    Last Post: 11-04-2011, 10:41 PM
  3. Replies: 4
    Last Post: 08-24-2011, 06:51 PM
  4. Replies: 14
    Last Post: 06-30-2011, 01:56 PM
  5. Replies: 4
    Last Post: 08-23-2010, 05:34 PM
