Results 1 to 10 of 10
Thread: CEN Standards Collection 217/370: CEN TC 124-Timber Structures
    full list:
    EN 336:2013 Structural timber - Sizes, permitted deviations
    EN 338:2009 Structural timber - Strength classes
    EN 380:1993 Timber structures - Test methods - General principles for static load testing
    EN 383:2007 Timber Structures - Test methods - Determination of embedment strength and foundation values for dowel type fasteners
    EN 384:2010 Structural timber - Determination of characteristic values of mechanical properties and density
    EN 408:2010+A1:2012 Timber structures - Structural timber and glued laminated timber - Determination of some physical and mechanical properties
    EN 409:2009 Timber structures - Test methods - Determination of the yield moment of dowel type fasteners
    EN 594:2011 Timber structures - Test methods - Racking strength and stiffness of timber frame wall panels
    EN 595:1995 Timber structures - Test methods - Test of trusses for the determination of strength and deformation behaviour
    EN 596:1995 Timber structures - Test methods - Soft body impact test of timber framed walls
    EN 789:2004 Timber structures - Test methods - Determination of mechanical properties of wood based panels
    EN 912:2011 Timber fasteners - Specifications for connectors for timbers
    EN 1075:2014 Timber structures - Test methods - Joints made with punched metal plate fasteners
    EN 1195:1997 Timber structures - Test methods - Performance of structural floor decking
    EN 1380:2009 Timber structures - Test methods - Load bearing nails, screws, dowels and bolts
    EN 1381:2016 Timber structures - Test methods - Load bearing stapled joints
    EN 1382:2016 Timber Structures - Test methods - Withdrawal capacity of timber fasteners
    EN 1383:2016 Timber structures - Test methods - Pull through resistance of timber fasteners
    EN 1912:2012 Structural Timber - Strength classes - Assignment of visual grades and species
    EN 1912:2012/AC:2013 Structural Timber - Strength classes - Assignment of visual grades and species
    EN ISO 8970:2010 Timber structures - Testing of joints made with mechanical fasteners - Requirements for wood density (ISO 8970:2010)
    EN 12512:2001 Timber structures - Test methods - Cyclic testing of joints made with mechanical fasteners
    EN 12512:2001/A1:2005 Timber structures - Test methods - Cyclic testing of joints made with mechanical fasteners
    EN 13271:2001 Timber fasteners - Characteristic load-carrying capacities and slip-moduli for connector joints
    EN 13271:2001/AC:2003 Timber fasteners - Characteristic load-carrying capacities and slip-moduli for connector joints
    EN 14080:2013 Timber structures - Glued laminated timber and glued solid timber - Requirements
    EN 14081-1:2016 Timber structures - Strength graded structural timber with rectangular cross section - Part 1: General requirements
    EN 14081-2:2010+A1:2012 Timber structures - Strength graded structural timber with rectangular cross section - Part 2: Machine grading; additional requirements for initial type testing
    EN 14081-3:2012 Timber structures - Strength graded structural timber with rectangular cross section - Part 3: Machine grading; additional requirements for factory production control
    EN 14229:2010 Structural timber - Wood poles for overhead lines
    EN 14250:2010 Timber structures - Product requirements for prefabricated structural members assembled with punched metal plate fasteners
    EN 14251:2003 Structural round timber - Test methods
    EN 14358:2006 Timber structures - Calculation of characteristic 5-percentile values and acceptance criteria for a sample
    EN 14374:2004 Timber structures - Structural laminated veneer lumber - Requirements
    EN 14545:2008 Timber structures - Connectors - Requirements
    EN 14592:2008+A1:2012 Timber structures - Dowel-type fasteners - Requirements
    EN 15228:2009 Structural timber - Structural timber preservative treated against biological attack
    EN 15497:2014 Structural finger jointed solid timber - Performance requirements and minimum production requirements
    EN 15736:2009 Timber Structures - Test methods - Withdrawal capacity of punched metal plate fasteners in handling and erection of prefabricated trusses
    EN 15737:2009 Timber Structures - Test methods - Torsional resistance of driving in screws
    EN 16351:2015 Timber structures - Cross laminated timber - Requirements
    EN 26891:1991 Timber structures - Joints made with mechanical fasteners - General principles for the determination of strength and deformation characteristics (ISO 6891:1983)
    missing:
    Re: CEN Standards Collection 217/300: CEN TC 124-Timber Structures
    no updates, just more missing standard:
    EN 338:2016 Structural timber - Strength classes
    EN 16737:2016 Structural timber - Visual strength grading of tropical hardwood
    fresh links:
    or
    Aug 2015
    Dubai, UAE
    Blog Entries
    4
    Here u go for these...
    Attached Files Attached Files
    Thanks & Regards:
    Amjad Malik
    thank you my friend for the standards
    Re: CEN Standards Collection 217/340: CEN TC 124-Timber Structures
    ok, now we missing following ones:
    EN 14358:2016 Timber structures - Calculation and verification of characteristic values
    EN 16784:2016 Timber structures - Test methods - Determination of the long term behaviour of coated and uncoated dowel-type fasteners
    fresh links:
    or
    Re: CEN Standards Collection 217/350: CEN TC 124-Timber Structures
    update:
    EN 336:2013 Structural timber - Sizes, permitted deviations - EN version
    EN 338:2016 Structural timber - Strength classes - added missing standard thanx to Amjad Malik
    EN 1912:2012 Structural Timber - Strength classes - Assignment of visual grades and species - EN version
    EN 14080:2013 Timber structures - Glued laminated timber and glued solid timber - Requirements - EN version
    EN 14081-1:2016 Timber structures - Strength graded structural timber with rectangular cross section - Part 1: General requirements - added missing standard thanx to Amjad Malik
    EN 14358:2016 Timber structures - Calculation and verification of characteristic values - added missing standard thanx to Amjad Malik
    missing list:
    EN 384:2016 Structural timber - Determination of characteristic values of mechanical properties and density
    updated links:
    or
    update:
    EN 16737:2016 Structural timber - Visual strength grading of tropical hardwood - added missing standard
    EN 16784:2016 Timber structures - Test methods - Determination of the long term behaviour of coated and uncoated dowel-type fasteners - added missing standard
    the only 1 missing is:
    new links:
    or
    Re: CEN Standards Collection 217/370: CEN TC 124-Timber Structures
    update:
    EN 384:2016 Structural timber - Determination of characteristic values of mechanical properties and density - added missing standard
    sector complete
    no changes
    update:
    BQ or EN:
    still complete
  1. Replies: 9
    Last Post: 11-27-2017, 02:11 AM
  2. CEN Standars Collection 67/370: CEN SS B02 - Structures
    Last Post: 11-25-2017, 03:50 AM
  3. Replies: 11
    Last Post: 11-17-2017, 05:23 PM
  4. CEN Standards Collection 223/370: CEN TC 175-Round And Sawn Timber
    Last Post: 06-21-2017, 06:57 PM
  5. Replies: 0
    Last Post: 12-31-2016, 04:12 AM
