14 are missing
EN ISO 4566:1995 Small craft with inboard engine - Propeller shaft ends and bosses with 1 : 10 taper (ISO 4566:1992)
EN ISO 6185-1:2001 Inflatable boats - Part 1: Boats with a maximum motor power rating of 4,5 kW (ISO 6185-1:2001)
EN ISO 6185-2:2001 Inflatable boats - Part 2: Boats with a maximum motor power rating of 4,5 kW to 15 kW inclusive (ISO 6185-2:2001)
EN ISO 6185-3:2014 Inflatable boats - Part 3: Boats with a hull length less than 8 m with a motor rating of 15 kW and greater (ISO 6185-3:2014)
EN ISO 6185-4:2011 Inflatable boats - Part 4: Boats with a hull length of between 8 m and 24 m with a motor power rating of 15 kW and greater (ISO 6185-4:2011, Corrected version 2014-08-01)
EN ISO 7840:2013 Small craft - Fire-resistant fuel hoses (ISO 7840:2013)
EN ISO 8099:2000 Small craft - Toilet waste retention systems (ISO 8099:2000)
EN ISO 8469:2013 Small craft - Non-fire-resistant fuel hoses (ISO 8469:2013)
EN ISO 8665:2006 Small craft - Marine propulsion reciprocating internal combustion engines - Power measurements and declarations (ISO 8665:2006)
EN ISO 8666:2002 Small craft - Principal data (ISO 8666:2002)
EN ISO 8847:2004 Small craft - Steering gear - Cable and pulley systems (ISO 8847:2004)
EN ISO 8847:2004/AC:2005 Small craft - Steering gear - Cable and pulley systems (ISO 8847:2004)
EN ISO 8849:2003 Small craft - Electrically operated direct-current bilge-pumps (ISO 8849:2003)
EN ISO 9093-1:1997 Small craft - Seacocks and through-hull fittings - Part 1: Metallic (ISO 9093-1:1994)
EN ISO 9093-2:2002 Small craft - Seacocks and through-hull fittings - Part 2: Non-metallic (ISO 9093-2:2002)
EN ISO 9094:2015 Small craft - Fire protection (ISO 9094:2015)
EN ISO 9097:1994 Small craft - Electric fans (ISO 9097:1991)
EN ISO 9097:1994/A1:2000 Small craft - Electric fans (ISO 9097:1991)
EN ISO 10087:2006 Small craft - Craft identification - Coding system (ISO 10087:2006)
EN ISO 10088:2013 Small craft - Permanently installed fuel systems (ISO 10088:2013)
EN ISO 10133:2012 Small craft - Electrical systems - Extra-low-voltage d.c. installations (ISO 10133:2012)
EN ISO 10239:2014 Small craft - Liquefied petroleum gas (LPG) systems (ISO 10239:2014)
EN ISO 10240:2004 Small craft - Owner's manual (ISO 10240:2004)
EN ISO 10240:2004/A1:2015 Small craft - Owner's manual (ISO 10240:2004/Amd 1:2015)
EN ISO 10592:1995 Small craft - Hydraulic steering systems (ISO 10592:1994)
EN ISO 10592:1995/A1:2000 Small craft - Hydraulic steering systems (ISO 10592:1994)
EN ISO 11105:1997 Small craft - Ventilation of petrol engine and/or petrol tank compartments (ISO 11105:1997)
EN ISO 11192:2005 Small craft - Graphical symbols (ISO 11192:2005)
EN ISO 11547:1995 Small craft - Start-in-gear protection (ISO 11547:1994)
EN ISO 11547:1995/A1:2000 Small craft - Start-in-gear protection (ISO 11547:1994)
EN ISO 11591:2011 Small craft, engine-driven - Field of vision from helm position (ISO 11591:2011)
EN ISO 11592:2001 Small craft less than 8 m length of hull - Determination of maximum propulsion power rating (ISO 11592:2001)
EN ISO 11812:2001 Small craft - Watertight cockpits and quick-draining cockpits (ISO 11812:2001)
EN ISO 12215-1:2000 Small craft - Hull construction and scantlings - Part 1: Materials: Thermosetting resins, glass-fibre reinforcement, reference laminate (ISO 12215-1:2000)
EN ISO 12215-2:2002 Small craft - Hull construction and scantlings - Part 2: Materials: Core materials for sandwich construction, embedded materials (ISO 12215-2:2002)
EN ISO 12215-3:2002 Small craft - Hull construction and scantlings - Part 3: Materials: Steel, aluminium alloys, wood, other materials (ISO 12215-3:2002)
EN ISO 12215-4:2002 Small craft - Hull construction and scantlings - Part 4: Workshop and manufacturing (ISO 12215-4:2002)
EN ISO 12215-5:2008 Small craft - Hull construction and scantlings - Part 5: Design pressures for monohulls, design stresses, scantlings determination (ISO 12215-5:2008)
EN ISO 12215-5:2008/A1:2014 Small craft - Hull construction and scantlings - Part 5: Design pressures for monohulls, design stresses, scantlings determination - Amendment 1 (ISO 12215-5:2008/Amd 1:2014)
EN ISO 12215-6:2008 Small craft - Hull construction and scantlings - Part 6: Structural arrangements and details (ISO 12215-6:2008)
EN ISO 12215-8:2009 Small craft - Hull construction and scantlings - Part 8: Rudders (ISO 12215-8:2009)
EN ISO 12215-8:2009/AC:2010 Small craft - Hull construction and scantlings - Part 8: Rudders - Technical Corrigendum 1 (ISO 12215-8:2009/Cor 1:2010)
EN ISO 12215-9:2012 Small craft - Hull construction and scantlings - Part 9: Sailing craft appendages (ISO 12215-9:2012)
EN ISO 12216:2002 Small craft - Windows, portlights, hatches, deadlights and doors - Strength and watertightness requirements (ISO 12216:2002)
EN ISO 12217-1:2015 Small craft - Stability and buoyancy assessment and categorization - Part 1: Non-sailing boats of hull length greater than or equal to 6 m (ISO 12217-1:2015)
EN ISO 12217-2:2015 Small craft - Stability and buoyancy assessment and categorization - Part 2: Sailing boats of hull length greater than or equal to 6 m (ISO 12217-2:2015)
EN ISO 12217-3:2015 Small craft - Stability and buoyancy assessment and categorization - Part 3: Boats of hull length less than 6 m (ISO 12217-3:2015)
EN ISO 13297:2014 Small craft - Electrical systems - Alternating current installations (ISO 13297:2014)
EN ISO 13590:2003 Small craft - Personal watercraft - Construction and system installation requirements (ISO 13590:2003)
EN ISO 13590:2003/AC:2004 Small craft - Personal watercraft - Construction and system installation requirements (ISO 13590:2003)
EN ISO 13929:2001 Small craft - Steering gear - Geared link systems (ISO 13929:2001)
EN ISO 14509-1:2008 Small craft - Airborne sound emitted by powered recreational craft - Part 1: Pass-by measurement procedures (ISO 14509-1:2008)
EN ISO 14509-2:2006 Small craft - Airborne sound emitted by powered recreational craft - Part 2: Sound assessment using reference craft (ISO 14509-2:2006)
EN ISO 14509-3:2009 Small craft - Airborne sound emitted by powered recreational craft - Part 3: Sound assessment using calculation and measurement procedures (ISO 14509-3:2009)
EN ISO 14895:2003 Small craft - Liquid-fuelled galley stoves (ISO 14895:2000)
EN ISO 14945:2004 Small craft - Builder's plate (ISO 14945:2004)
EN ISO 14945:2004/AC:2005 Small craft - Builder's plate (ISO 14945:2004)
EN ISO 14946:2001 Small craft - Maximum load capacity (ISO 14946:2001)
EN ISO 14946:2001/AC:2005 Small craft - Maximum load capacity (ISO 14946:2001)
EN ISO 15083:2003 Small craft - Bilge-pumping systems (ISO 15083:2003)
EN ISO 15084:2003 Small craft - Anchoring, mooring and towing - Strong points (ISO 15084:2003)
EN ISO 15085:2003 Small craft - Man-overboard prevention and recovery (ISO 15085:2003)
EN ISO 15085:2003/A1:2009 Small craft - Man-overboard prevention and recovery - Amendment 1 (ISO 15085:2003/Amd 1:2009)
EN ISO 15584:2001 Small craft - Inboard petrol engines - Engine-mounted fuel and electrical components (ISO 15584:2001)
EN ISO 15652:2005 Small craft - Remote steering systems for inboard mini jet boats (ISO 15652:2003)
EN ISO 16147:2002 Small craft - Inboard diesel engines - Engine-mounted fuel and electrical components (ISO 16147:2002)
EN ISO 16147:2002/A1:2013 Small craft - Inboard diesel engines - Engine-mounted fuel and electrical components - Amendment 1 (ISO 16147:2002/Amd 1:2013)
EN ISO 16180:2013 Small craft - Navigation lights - Installation, placement and visibility (ISO 16180:2013)
EN ISO 18854:2015 Small craft - Reciprocating internal combustion engines exhaust emission measurement - Test-bed measurement of gaseous and particulate exhaust emissions (ISO 18854:2015)
EN ISO 19009:2015 Small craft - Electric navigation lights - Performance of LED lights (ISO 19009:2015)
EN ISO 21487:2012 Small craft - Permanently installed petrol and diesel fuel tanks (ISO 21487:2012)
EN ISO 21487:2012/A1:2014 Small craft - Permanently installed petrol and diesel fuel tanks - Amendment 1 (ISO 21487:2012/Amd 1:2014)
EN ISO 21487:2012/A2:2015 Small craft - Permanently installed petrol and diesel fuel tanks - Amendment 2 (ISO 21487:2012/Amd 2:2015)
EN ISO 25197:2012 Small craft - Electrical/electronic control systems for steering, shift and throttle (ISO 25197:2012)
EN ISO 25197:2012/A1:2014 Small craft - Electrical/electronic control systems for steering, shift and throttle - Amendment 1 (ISO 25197:2012/Amd 1:2014)
EN 28846:1993 Small craft - Electrical devices - Protection against ignition of surrounding flammable gases (ISO 8846:1990)
EN 28846:1993/A1:2000 Small craft - Electrical devices - Protection against ignition of surrounding flammable gases (ISO 8846:1990)
EN 28848:1993 Small craft - Remote steering systems (ISO 8848:1990)
EN 28848:1993/A1:2000 Small craft - Remote steering systems (ISO 8848:1990)
EN 29775:1993 Small craft - Remote steering systems for single outboard motors of 15 kW to 40 kW power (ISO 9775:1990)
EN 29775:1993/A1:2000 Small craft - Remote steering systems for single outboard motors of 15 kW to 40 kW power (ISO 9775:1990)
or
