I have a PSCAD 4.6 free version (15 nodes). Could it be cured using a ******** and enabled a professional feature of it? Thanks
One feature of it is you have to log-in first on myupdater in order to run the free version. I think this uses a certifiicate licensing
Wow
Sent from Mars using Tapatalk
Of course!
Ow..I was about to send to you the installation file together with the setup.exe file. Can you share it? I will try to run the TRV case to test its functionality.
Not taking advantage. Might be open for exchange of PSCAD projects (e.g. GIS Disconnect Switch switching, lightning study, transient recover voltage, line energization). I'm intending to test it because the software cured with ******** still displays incorrect results from graphs.
So, why not send your file?
Why in hurry? easy.
Im not in a hurry. I dont need it anyways.
