Results 1 to 6 of 6
Thread: CEN Standards Collection 177/370: CEN TC 229-Precast Concrete Products
    complete
    EN 1168:2005+A3:2011 Precast concrete products - Hollow core slabs
    EN 1169:1999 Precast concrete products - General rules for factory production control of glass-fibre reinforced cement
    EN 1170-1:1997 Precast concrete products - Test method for glass-fibre reinforced cement - Part 1: Measuring the consistency of the matrix "Slump test" method
    EN 1170-2:1997 Precast concrete products - Test method for glass-fibre reinforced cement - Part 2: Measuring the fibre content in fresh GRC, "Wash out test"
    EN 1170-3:1997 Precast concrete products - Test method for glass-fibre reinforced cement - Part 3: Measuring the fibre content of sprayed GRC
    EN 1170-4:1997 Precast concrete products - Test method for glass-fibre reinforced cement - Part 4: Measuring bending strength, "Simplified bending test" method
    EN 1170-5:1997 Precast concrete products - Test method for glass-fibre reinforced cement - Part 5: Measuring bending strength, "Complete bending test" method
    EN 1170-6:1997 Precast concrete products - Test method for glass-fibre reinforced cement - Part 6: Determination of the absorption of water by immersion and determination of the dry density
    EN 1170-7:1997 Precast concrete products - Test method for glass-fibre reinforced cement - Part 7: Measurement of extremes of dimensional variations due to moisture content
    EN 1170-8:2008 Test method for glass-fibre reinforced cement - Part 8: Cyclic weathering type test
    EN 12737:2004+A1:2007 Precast concrete products - Floor slats for livestock
    EN 12794:2005+A1:2007 Precast concrete products - Foundation piles
    EN 12794:2005+A1:2007/AC:2008 Precast concrete products - Foundation piles
    EN 12839:2012 Precast concrete products - Elements for fences
    EN 12843:2004 Precast concrete products - Masts and poles
    EN 13198:2003 Precast concrete products - Street furniture and garden products
    EN 13224:2011 Precast concrete products - Ribbed floor elements
    EN 13225:2013 Precast concrete products - Linear structural elements
    EN 13369:2013 Common rules for precast concrete products
    EN 13693:2004+A1:2009 Precast concrete products - Special roof elements
    EN 13747:2005+A2:2010 Precast concrete products - Floor plates for floor systems
    EN 13748-1:2004 Terrazzo tiles - Part 1: Terrazzo tiles for internal use
    EN 13748-1:2004/AC:2005 Terrazzo tiles - Part 1: Terrazzo tiles for internal use
    EN 13748-1:2004/A1:2005 Terrazzo tiles - Part 1: Terrazzo tiles for internal use
    EN 13748-2:2004 Terrazzo tiles - Part 2: Terrazzo tiles for external use
    EN 13978-1:2005 Precast concrete products - Precast concrete garages - Part 1: Requirements for reinforced garages monolithic or consisting of single sections with room dimensions
    EN 14474:2004 Precast concrete products - Concrete with wood-chips as aggregate - Requirements and test methods
    EN 14649:2005 Precast concrete products - Test method for strength retention of glass fibres in cement and concrete (SIC TEST)
    EN 14650:2005 Precast concrete products - General rules for factory production control of metallic fibered concrete
    EN 14651:2005+A1:2007 Test method for metallic fibre concrete - Measuring the flexural tensile strength (limit of proportionality (LOP), residual)
    EN 14721:2005+A1:2007 Test method for metallic fibre concrete - Measuring the fibre content in fresh and hardened concrete
    EN 14843:2007 Precast concrete products - Stairs
    EN 14844:2006+A2:2011 Precast concrete products - Box culverts
    CEN/TR 14862:2004 Precast concrete products - Full-scale testing requirements in standards on precast concrete products
    EN 14991:2007 Precast concrete products - Foundation elements
    EN 14992:2007+A1:2012 Precast concrete products - Wall elements
    EN 15037-1:2008 Precast concrete products - Beam-and-block floor systems - Part 1: Beams
    EN 15037-2:2009+A1:2011 Precast concrete products - Beam-and-block floor systems - Part 2: Concrete blocks
    EN 15037-3:2009+A1:2011 Precast concrete products - Beam-and-block floor systems - Part 3: Clay blocks
    EN 15037-4:2010+A1:2013 Precast concrete products - Beam-and-block floor systems - Part 4: Expanded polystyrene blocks
    EN 15037-5:2013 Precast concrete products - Beam-and-block floor systems - Part 5: Lightweight blocks for simple formwork
    EN 15050:2007+A1:2012 Precast concrete products - Bridge elements
    EN 15191:2009 Precast concrete products - Classification of glassfibre reinforced concrete performance
    EN 15258:2008 Precast concrete products - Retaining wall elements
    EN 15422:2008 Precast concrete products - Specification of glassfibres for reinforcement of mortars and concretes
    EN 15435:2008 Precast concrete products - Normal weight and lightweight concrete shuttering blocks - Product properties and performance
    EN 15498:2008 Precast concrete products - Wood-chip concrete shuttering blocks - Product properties and performance
    EN 15564:2008 Precast concrete products - Resin bound concrete - Requirements and test methods
    CEN/TR 15728:2008 Design and Use of Inserts for Lifting and Handling of Precast Concrete - Elements
    CEN/TR 15739:2008 Precast concrete products - Concrete finishes - Identification
    Re: CEN Standards Collection 177/300: CEN TC 229-Precast Concrete Products
    update:
    CEN/TR 15728:2016 Design and Use of Inserts for Lifting and Handling of Precast Concrete - Elements - added new version of standard
    sector still complete
    new links:
    or
    Re: CEN Standards Collection 177/340: CEN TC 229-Precast Concrete Products
    fresh links:
    or
    update:
    EN 12794:2005+A1:2007/AC:2008 Precast concrete products - Foundation piles - EN version
    still complete
    links:
    or
    Re: CEN Standards Collection 177/370: CEN TC 229-Precast Concrete Products
    nothing changed....
    better quality:
  1. Replies: 12
    Last Post: 04-09-2019, 12:07 PM
  2. ACI (American Concrete Institute) Collection Standards
    By raz in forum Civil & Structural Engineering
    Last Post: 10-26-2018, 03:46 AM
  3. Replies: 12
    Last Post: 11-17-2017, 07:20 PM
  4. Replies: 6
    Last Post: 06-04-2017, 04:57 AM
  5. CEN Standards Collection 199/370: CEN SS C01-Food Products
