full list:
EN ISO 1456:2009 Metallic and other inorganic coatings - Electrodeposited coatings of nickel, nickel plus chromium, copper plus nickel and of copper plus nickel plus chromium (ISO 1456:2009)
EN ISO 1460:1994 Metallic coatings - Hot dip galvanized coatings on ferrous materials - Gravimetric determination of the mass per unit area (ISO 1460:1992)
EN ISO 1461:2009 Hot dip galvanized coatings on fabricated iron and steel articles - Specifications and test methods (ISO 1461:2009)
EN ISO 1463:2004 Metallic and oxide coatings - Measurement of coating thickness - Microscopical method (ISO 1463:2003)
EN ISO 2064:2000 Metallic and other inorganic coatings - Definitions and conventions concerning the measurement of thickness (ISO 2064:1996)
EN ISO 2080:2009 Metallic and other inorganic coatings - Surface treatment, metallic and other inorganic coatings - Vocabulary (ISO 2080:2008)
EN ISO 2081:2008 Metallic and other inorganic coatings - Electroplated coatings of zinc with supplementary treatments on iron or steel (ISO 2081:2008)
EN ISO 2082:2008 Metallic and other inorganic coatings - Electroplated coatings of cadmium with supplementary treatments on iron or steel (ISO 2082:2008)
EN ISO 2177:2004 Metallic coatings - Measurement of coating thickness - Coulometric method by anodic dissolution (ISO 2177:2003)
EN ISO 2178:1995 Non-magnetic coatings on magnetic substrates - Measurement of coating thickness - Magnetic method (ISO 2178:1982)
EN ISO 2360:2003 Non-conductive coatings on non-magnetic electrically conductive basis materials - Measurement of coating thickness - Amplitude-sensitive eddy current method (ISO 2360:2003)
EN ISO 2361:1995 Electrodeposited nickel coatings on magnetic and non-magnetic substrates - Measurement of coating thickness - Magnetic method (ISO 2361:1982)
EN ISO 2746:2015 Vitreous and porcelain enamels - High voltage test (ISO 2746:2015)
EN ISO 2819:1994 Metallic coatings on metallic substrates - Electrodeposited and chemically deposited coatings - Review of methods available for testing adhesion (ISO 2819:1980)
EN ISO 3497:2000 Metallic coatings - Measurement of coating thickness - X-ray spectrometric methods (ISO 3497:2000)
EN ISO 3543:2000 Metallic and non-metallic coatings - Measurement of thickness - Beta backscatter method (ISO 3543:2000)
EN ISO 3543:2000/AC:2006 Metallic and non-metallic coatings - Measurement of thickness - Beta backscatter method (ISO 3543:2000)
EN ISO 3613:2010 Metallic and other inorganic coatings - Chromate conversion coatings on zinc, cadmium, aluminium-zinc alloys and zinc-aluminium alloys - Test methods (ISO 3613:2010)
EN ISO 3868:1994 Metallic and other non-organic coatings - Measurement of coating thicknesses - Fizeau multiple-beam interferometry method (ISO 3868:1976)
EN ISO 3882:2003 Metallic and other inorganic coatings - Review of methods of measurement of thickness (ISO 3882:2003)
EN ISO 3892:2001 Conversion coatings on metallic materials - Determination of coating mass per unit area - Gravimetric methods (ISO 3892:2000)
EN ISO 4516:2002 Metallic and other inorganic coatings - Vickers and Knoop microhardness tests (ISO 4516:2002)
EN ISO 4518:1995 Metallic coatings - Measurement of coating thickness - Profilometric method (ISO 4518:1980)
EN ISO 4521:2008 Metallic and other inorganic coatings - Electrodeposited silver and silver alloy coatings for engineering purposes - Specification and test methods (ISO 4521:2008)
EN ISO 4524-3:1995 Metallic coatings - Test methods for electrodeposited gold and gold alloy coatings - Part 3: Electrographic tests for porosity (ISO 4524-3:1985)
EN ISO 4524-6:1994 Metallic coatings - Test methods for electrodeposited gold aid gold alloy coatings - Part 6: Determination of the presence of residual salts (ISO 4524-6:1988)
EN ISO 4526:2004 Metallic coatings - Electroplated coatings of nickel for engineering purposes (ISO 4526:2004)
EN ISO 4527:2003 Metallic coatings - Autocatalytic (electroless) nickel-phosphorus alloy coatings - Specification and test methods (ISO 4527:2003)
EN ISO 4528:2015 Vitreous and porcelain enamel finishes - Guide to selection of test methods for vitreous and porcelain enamelled areas of articles (ISO 4528:2015)
EN ISO 4534:2010 Vitreous and porcelain enamels - Determination of fluidity behaviour - Fusion flow test (ISO 4534:2010)
EN ISO 4536:1995 Metallic and non-organic coatings on metallic substrates - Saline droplets corrosion test (SD test) (ISO 4536:1985)
EN ISO 4538:1995 Metallic coatings - Thioacetamide corrosion test (TAA test) (ISO 4538:1978)
EN ISO 4541:1994 Metallic and other non-organic coatings - Corrodkote corrosion test (CORR test) (ISO 4541:1978)
EN ISO 4543:1994 Metallic and other non-organic coatings - General rules for corrosion tests applicable for storage conditions (ISO 4543:1981)
EN ISO 6158:2011 Metallic and other inorganic coatings - Electrodeposited coatings of chromium for engineering purposes (ISO 6158:2011)
EN ISO 6509-1:2014 Corrosion of metals and alloys - Determination of dezincification resistance of copper alloys with zinc - Part 1: Test method (ISO 6509-1:2014)
EN ISO 6988:1994 Metallic and other non-organic coatings - Sulfur dioxide test with general condensation of moisture (ISO 6988:1985)
EN ISO 7384:1995 Corrosion test in artificial atmosphere - General requirements (ISO 7384:1986)
EN ISO 7441:2015 Corrosion of metals and alloys - Determination of bimetallic corrosion in atmospheric exposure corrosion tests (ISO 7441:2015)
EN ISO 7539-1:2012 Corrosion of metals and alloys - Stress corrosion testing - Part 1: General guidance on testing procedures (ISO 7539-1:2012)
EN ISO 7539-2:1995 Corrosion of metals and alloys - Stress corrosion testing - Part 2: Preparation and use of bent-beam specimen (ISO 7539-2:1989)
EN ISO 7539-3:1995 Corrosion of metals and alloys - Stress corrosion testing - Part 3: Preparation and use of U-bend specimens (ISO 7539-3:1989)
EN ISO 7539-4:1995 Corrosion of metals and alloys - Stress corrosion testing - Part 4: Preparation and use of uniaxially loaded tension specimens (ISO 7539-4:1989)
EN ISO 7539-5:1995 Corrosion of metals and alloys - Stress corrosion testing - Part 5: Preparation and use of C-ring specimens (ISO 7539-5:1989)
EN ISO 7539-6:2011 Corrosion of metals and alloys - Stress corrosion testing - Part 6: Preparation and use of pre*****ed specimens for tests under constant load or constant displacement (ISO 7539-6:2011)
EN ISO 7539-7:2005 Corrosion of metals and alloys - Stress corrosion testing - Part 7: Method for slow strain rate testing (ISO 7539-7:2005)
EN ISO 7539-8:2008 Corrosion of metals and alloys - Stress corrosion testing - Part 8: Preparation and use of specimens to evaluate weldments (ISO 7539-8:2000)
EN ISO 7539-9:2008 Corrosion of metals and alloys - Stress corrosion testing - Part 9: Preparation and use of pre-*****ed specimens for tests under rising load or rising displacement (ISO 7539-9:2003)
EN ISO 7539-10:2014 Corrosion of metals and alloys - Stress corrosion testing - Part 10: Reverse U-bend method (ISO 7539-10:2013)
EN ISO 7539-11:2014 Corrosion of metals and alloys - Stress corrosion testing - Part 11: Guidelines for testing the resistance of metals and alloys to hydrogen embrittlement and hydrogen-assisted *****ing (ISO 7539-11:2013)
EN ISO 8044:2015 Corrosion of metals and alloys - Basic terms and definitions (ISO 8044:2015)
EN ISO 8289:2001 Vitreous and porcelain enamels - Low voltage test for detecting and locating defects (ISO 8289:2000)
EN ISO 8401:1994 Metallic coatings - Review of methods of measurement of ductility (ISO 8401:1986)
EN ISO 8407:2014 Corrosion of metals and alloys - Removal of corrosion products from corrosion test specimens (ISO 8407:2009)
EN ISO 8565:2011 Metals and alloys - Atmospheric corrosion testing - General requirements (ISO 8565:2011)
EN ISO 9220:1994 Metallic coatings - Measurement of coating thickness - Scanning electron microscope method (ISO 9220:1988)
EN ISO 9223:2012 Corrosion of metals and alloys - Corrosivity of atmospheres - Classification, determination and estimation (ISO 9223:2012)
EN ISO 9224:2012 Corrosion of metals and alloys - Corrosivity of atmospheres - Guiding values for the corrosivity categories (ISO 9224:2012)
EN ISO 9225:2012 Corrosion of metals and alloys - Corrosivity of atmospheres - Measurement of environmental parameters affecting corrosivity of atmospheres (ISO 9225:2012)
EN ISO 9226:2012 Corrosion of metals and alloys - Corrosivity of atmospheres - Determination of corrosion rate of standard specimens for the evaluation of corrosivity (ISO 9226:2012)
EN ISO 9227:2012 Corrosion tests in artificial atmospheres - Salt spray tests (ISO 9227:2012)
EN ISO 9400:1995 Nickel-based alloys - Determination of resistance to intergranular corrosion (ISO 9400:1990)
EN ISO 9717:2013 Metallic and other inorganic coatings - Phosphate conversion coating of metals (ISO 9717:2010)
EN ISO 10062:2008 Corrosion tests in artificial atmosphere at very low concentrations of polluting gas(es) (ISO 10062:2006)
EN ISO 10111:2001 Metallic and other inorganic coatings - Measurement of mass per unit area - Review of gravimetric and chemical analysis methods (ISO 10111:2000)
EN ISO 10270:2008 Corrosion of metals and alloys - Aqueous corrosion testing of zirconium alloys for use in nuclear power reactors (ISO 10270:1995, including Cor 1:1997)
EN ISO 10289:2001 Methods for corrosion testing of metallic and other inorganic coatings on metallic substrates - Rating of test specimens and manufactured articles subjected to corrosion tests (ISO 10289:1999)
EN ISO 10308:2006 Metallic coatings - Review of porosity tests (ISO 10308:2006)
EN ISO 11130:2010 Corrosion of metals and alloys - Alternate immersion test in salt solution (ISO 11130:2010)
EN ISO 11303:2008 Corrosion of metals and alloys - Guidelines for selection of protection methods against atmospheric corrosion (ISO 11303:2002)
EN ISO 11306:1998 Corrosion of metals and alloys - Guidelines for exposing and evaluating metals and alloys in surface sea water (ISO 11306:1998)
EN ISO 11463:2008 Corrosion of metals and alloys - Evaluation of pitting corrosion (ISO 11463:1995)
EN ISO 11474:2014 Corrosion of metals and alloys - Corrosion tests in artificial atmosphere - Accelerated outdoor test by intermittent spraying of a salt solution (Scab test) (ISO 11474:1998)
EN ISO 11782-1:2008 Corrosion of metals and alloys - Corrosion fatigue testing - Part 1: Cycles to failure testing (ISO 11782-1:1998)
EN ISO 11782-2:2008 Corrosion of metals and alloys - Corrosion fatigue testing - Part 2: ***** propagation testing using pre*****ed specimens (ISO 11782-2:1998)
EN ISO 11844-1:2008 Corrosion of metals and alloys - Classification of low corrosivity of indoor atmospheres - Part 1: Determination and estimation of indoor corrosivity (ISO 11844-1:2006)
EN ISO 11844-2:2008 Corrosion of metals and alloys - Classification of low corrosivity of indoor atmospheres - Part 2: Determination of corrosion attack in indoor atmospheres (ISO 11844-2:2005)
EN ISO 11844-3:2008 Corrosion of metals and alloys - Classification of low corrosivity of indoor atmospheres - Part 3: Measurement of environmental parameters affecting indoor corrosivity (ISO 11844-3:2006)
EN ISO 11846:2008 Corrosion of metals and alloys - Determination of resistance to intergranular corrosion of solution heat-treatable aluminium alloys (ISO 11846:1995)
EN 12487:2007 Corrosion protection of metals - Rinsed and non-rinsed chromate conversion coatings on aluminium and aluminium alloys
EN 12487:2007/AC:2008 Corrosion protection of metals - Rinsed and non-rinsed chromate conversion coatings on aluminium and aluminium alloys
EN 12501-1:2003 Protection of metallic materials against corrosion - Corrosion likelihood in soil - Part 1: General
EN 12501-2:2003 Protection of metallic materials against corrosion - Corrosion likelihood in soil - Part 2: Low alloyed and non alloyed ferrous materials
EN 12502-1:2004 Protection of metallic materials against corrosion - Guidance on the assessment of corrosion likelihood in water distribution and storage systems - Part 1: General
EN 12502-2:2004 Protection of metallic materials against corrosion - Guidance on the assessment of corrosion likelihood in water distribution and storage systems - Part 2: Influencing factors for copper and copper alloys
EN 12502-3:2004 Protection of metallic materials against corrosion - Guidance on the assessment of corrosion likelihood in water distribution and storage systems - Part 3: Influencing factors for hot dip galvanised ferrous materials
EN 12502-4:2004 Protection of metallic materials against corrosion - Guidance on the assessment of corrosion likelihood in water distribution and storage systems - Part 4: Influencing factors for stainless steels
EN 12502-5:2004 Protection of metallic materials against corrosion - Guidance on the assessment of corrosion likelihood in water distribution and storage systems - Part 5: Influencing factors for cast iron, unalloyed and low alloyed steels
EN ISO 12683:2004 Mechanically deposited coatings of zinc - Specification and test methods (ISO 12683:2004)
EN ISO 12687:1998 Metallic coatings - Porosity tests - Humid sulfur (flowers of sulfur) test (ISO 12687:1996)
EN ISO 12732:2008 Corrosion of metals and alloys - Electrochemical potentiokinetic reactivation measurement using the double loop method (based on Cihal's method) (ISO 12732:2006)
EN 13144:2003 Metallic and other inorganic coatings - Method for quantitative measurement of adhesion by tensile test
EN ISO 13805:2009 Vitreous and porcelain enamels for aluminium - Determination of the adhesion of enamels on aluminium under the action of electrolytic solution (spall test) (ISO 13805:1999)
EN ISO 13807:2009 Vitreous and porcelain enamels - Determination of ***** formation temperature in the thermal shock testing of enamels for the chemical industry (ISO 13807:1999, including Cor 1:2000)
EN 13811:2003 Sherardizing - Zinc diffusion coatings on ferrous products - Specification
EN 13858:2006 Corrosion protection of metals - Non-electrolytically applied zinc flake coatings on iron or steel components
EN 14571:2005 Metallic coatings on nonmetallic basis materials - Measurement of coating thickness - Microresistivity method
EN ISO 14713-1:2009 Zinc coatings - Guidelines and recommendations for the protection against corrosion of iron and steel in structures - Part 1: General principles of design and corrosion resistance (ISO 14713-1:2009)
EN ISO 14713-2:2009 Zinc coatings - Guidelines and recommendations for the protection against corrosion of iron and steel in structures - Part 2: Hot dip galvanizing (ISO 14713-2:2009)
EN ISO 14713-3:2009 Zinc coatings - Guidelines and recommendations for the protection against corrosion of iron and steel in structures - Part 3: Sherardizing (ISO 14713-3:2009)
EN ISO 14713-3:2009/AC:2010 Zinc coatings - Guidelines and recommendations for the protection against corrosion of iron and steel in structures - Part 3: Sherardizing (ISO 14713-3:2009)
EN 14868:2005 Protection of metallic materials against corrosion - Guidance on the assessment of corrosion likelihood in closed water circulation systems
EN 15042-1:2006 Thickness measurement of coatings and characterization of surfaces with surface waves - Part 1: Guide to the determination of elastic constants, density and thickness of films by laser induced surface acoustic waves
EN 15042-2:2006 Thickness measurement of coatings and characterization of surfaces with surface waves - Part 2: Guide to the thickness measurement of coatings by photothermic method
EN ISO 15324:2008 Corrosion of metals and alloys - Evaluation of stress corrosion *****ing by the drop evaporation test (ISO 15324:2000)
EN ISO 15329:2008 Corrosion of metals and alloys - Anodic test for evaluation of intergranular corrosion susceptibility of heat-treatable aluminium alloys (ISO 15329:2006)
EN 15646:2009 Electrodeposited coatings - Electroplated coatings of aluminium and aluminium alloys with supplementary treatment - Requirements and test methods
EN ISO 15695:2001 Vitreous and porcelain enamels - Determination of scratch resistance of enamel finishes (ISO 15695:2000, including Technical Corrigendum 1:2000)
EN ISO 15720:2001 Metallic coatings - Porosity tests - Porosity in gold or palladium coatings on metal substrates by gel-bulk electrography (ISO 15720:2001)
EN ISO 15721:2001 Metallic coatings - Porosity tests - Porosity in gold or palladium coatings by sulfurous acid/sulfur dioxide vapour (ISO 15721:2001)
EN 15771:2010 Vitreous and porcelain enamels - Determination of surface scratch hardness according to the Mohs scale
EN 15826:2009 Vitreous and porcelain enamels - Terminology
EN ISO 16151:2008 Corrosion of metals and alloys - Accelerated cyclic tests with exposure to acidified salt spray, ''dry'' and ''wet'' conditions (ISO 16151:2005)
EN ISO 16348:2003 Metallic and other inorganic coatings - Definitions and conventions concerning appearance (ISO 16348:2003)
EN ISO 16701:2015 Corrosion of metals and alloys - Corrosion in artificial atmosphere - Accelerated corrosion test involving exposure under controlled conditions of humidity cycling and intermittent spraying of a salt solution (ISO 16701:2015)
EN ISO 16784-1:2008 Corrosion of metals and alloys - Corrosion and fouling in industrial cooling water systems - Part 1: Guidelines for conducting pilot-scale evaluation of corrosion and fouling control additives for open recirculating cooling water systems (ISO 16784-1:2006
EN ISO 16784-2:2008 Corrosion of metals and alloys - Corrosion and fouling in industrial cooling water systems - Part 2: Evaluation of the performance of cooling water treatment programmes using a pilot-scale test rig (ISO 16784-2:2006)
EN ISO 17081:2014 Method of measurement of hydrogen permeation and determination of hydrogen uptake and transport in metals by an electrochemical technique (ISO 17081:2014)
EN ISO 17475:2008 Corrosion of metals and alloys - Electrochemical test methods - Guidelines for conducting potentiostatic and potentiodynamic polarization measurements (ISO 17475:2005/Cor 1:2006)
EN ISO 17864:2008 Corrosion of metals and alloys - Determination of the critical pitting temperature under potientiostatic control (ISO 17864:2005)
EN ISO 18332:2008 Metallic and other inorganic coatings - Definitions and conventions concerning porosity (ISO 18332:2007)
EN ISO 21968:2005 Non-magnetic metallic coatings on metallic and non-metallic basis materials - Measurement of coating thickness - Phase-sensitive eddy-current method (ISO 21968:2005)
EN ISO 26945:2011 Metallic and other inorganic coatings - Electrodeposited coatings of tin-cobalt alloy (ISO 26945:2011)
EN ISO 27830:2013 Metallic and other inorganic coatings - Guidelines for specifying metallic and inorganic coatings (ISO 27830:2008)
EN ISO 27874:2008 Metallic and other inorganic coatings - Electrodeposited gold and gold alloy coatings for electrical, electronic and engineering purposes - Specification and test methods (ISO 27874:2008)
EN ISO 28706-1:2011 Vitreous and porcelain enamels - Determination of resistance to chemical corrosion - Part 1: Determination of resistance to chemical corrosion by acids at room temperature (ISO 28706-1:2008)
EN ISO 28706-2:2011 Vitreous and porcelain enamels - Determination of resistance to chemical corrosion - Part 2: Determination of resistance to chemical corrosion by boiling acids, boiling neutral liquids and/or their vapours (ISO 28706-2:2008)
EN ISO 28706-3:2011 Vitreous and porcelain enamels - Determination of resistance to chemical corrosion - Part 3: Determination of resistance to chemical corrosion by alkaline liquids using a hexagonal vessel (ISO 28706-3:2008)
EN ISO 28706-4:2016 Vitreous and porcelain enamels - Determination of resistance to chemical corrosion - Part 4: Determination of resistance to chemical corrosion by alkaline liquids using a cylindrical vessel (ISO 28706-4:2016)
EN ISO 28706-5:2011 Vitreous and porcelain enamels - Determination of resistance to chemical corrosion - Part 5: Determination of resistance to chemical corrosion in closed systems (ISO 28706-5:2010)
EN ISO 28721-1:2011 Vitreous and porcelain enamels - Glass-lined apparatus for process plants - Part 1: Quality requirements for apparatus, components, appliances and accessories (ISO 28721-1:2008)
EN ISO 28721-2:2015 Vitreous and porcelain enamels - Glass-lined apparatus for process plants - Part 2: Designation and specification of resistance to chemical attack and thermal shock (ISO 28721-2:2015)
EN ISO 28721-3:2011 Vitreous and porcelain enamels - Glass-lined apparatus for process plants - Part 3: Thermal shock resistance (ISO 28721-3:2008)
EN ISO 28721-4:2015 Vitreous and porcelain enamels - Glass-lined apparatus for process plants - Part 4: Quality requirements for glass-lined flanged steel pipes and flanged steel fittings (ISO 28721-4:2015)
EN ISO 28722:2011 Vitreous and porcelain enamels - Characteristics of enamel coatings applied to steel panels intended for architecture (ISO 28722:2008)
EN ISO 28723:2011 Vitreous and porcelain enamels - Determination of the edge covering on enamelled steel plate to be used in heat exchangers (ISO 28723:2008)
EN ISO 28762:2010 Vitreous and porcelain enamels - Enamel coatings applied to steel for writing surfaces - Specification (ISO 28762:2010)
EN ISO 28763:2011 Vitreous and porcelain enamels - Regenerative, enamelled and packed panels for air-gas and gas-gas heat exchangers - Specifications (ISO 28763:2008)
EN ISO 28764:2015 Vitreous and porcelain enamels - Production of specimens for testing enamels on sheet steel, sheet aluminium and cast iron (ISO 28764:2015)
EN ISO 28765:2011 Vitreous and porcelain enamels - Design of bolted steel tanks for the storage or treatment of water or municipal or industrial effluents and sludges (ISO 28765:2008)
missing:
EN ISO 8044:2015 Corrosion of metals and alloys - Basic terms and definitions (ISO 8044:2015) - missing valid edition
EN 12487:2007/AC:2008 Corrosion protection of metals - Rinsed and non-rinsed chromate conversion coatings on aluminium and aluminium alloys - missing AC 2008
EN ISO 28706-4:2016 Vitreous and porcelain enamels - Determination of resistance to chemical corrosion - Part 4: Determination of resistance to chemical corrosion by alkaline liquids using a cylindrical vessel (ISO 28706-4:2016) - missing valid edition
EN ISO 28721-2:2015 Vitreous and porcelain enamels - Glass-lined apparatus for process plants - Part 2: Designation and specification of resistance to chemical attack and thermal shock (ISO 28721-2:2015) - missing valid edition
EN ISO 28721-4:2015 Vitreous and porcelain enamels - Glass-lined apparatus for process plants - Part 4: Quality requirements for glass-lined flanged steel pipes and flanged steel fittings (ISO 28721-4:2015) - missing valid edition
EN ISO 28764:2015 Vitreous and porcelain enamels - Production of specimens for testing enamels on sheet steel, sheet aluminium and cast iron (ISO 28764:2015) - missing valid edition
or
