full list:
EN 490:2011 Concrete roofing tiles and fittings for roof covering and wall cladding - Product specifications
EN 491:2011 Concrete roofing tiles and fittings for roof covering and wall cladding - Test methods
EN 492:2012 Fibre-cement slates and fittings - Product specification and test methods
EN 494:2012+A1:2015 Fibre-cement profiled sheets and fittings - Product specification and test methods
EN 501:1994 Roofing products from metal sheet - Specification for fully supported roofing products of zinc sheet
EN 502:2013 Roofing products from metal sheet - Specification for fully supported roofing products of stainless steel sheet
EN 504:1999 Roofing products from metal sheet - Specification for fully supported roofing products of copper sheet
EN 505:2013 Roofing products from metal sheet - Specification for fully supported roofing products of steel sheet
EN 506:2008 Roofing products of metal sheet - Specification for self-supporting products of copper or zinc sheet
EN 507:1999 Roofing products from metal sheet - Specification for fully supported roofing products of aluminium sheet
EN 508-1:2014 Roofing and cladding products from metal sheet - Specification for self-supporting of steel, aluminium or stainless steel sheet - Part 1: Steel
EN 508-2:2008 Roofing products from metal sheet - Specification for self-supporting products of steel, aluminium or stainless steel sheet - Part 2: Aluminium
EN 508-3:2008 Roofing products from metal sheet - Specification for self-supporting products of steel, aluminium or stainless steel sheet - Part 3: Stainless steel
EN 516:2006 Prefabricated accessories for roofing - Installations for roof access - Walkways, treads and steps
EN 517:2006 Prefabricated accessories for roofing - Roof safety hooks
EN 534:2006+A1:2010 Corrugated bitumen sheets - Product specification and test methods
EN 538:1994 Clay roofing tiles for discontinuous laying - Flexural strength test
EN 539-1:2005 Clay roofing tiles for discontinuous laying - Determination of physical characteristics - Part 1: Impermeability test
EN 539-2:2013 Clay roofing tiles for discontinuous laying - Determination of physical characteristics - Part 2: Test for frost resistance
EN 544:2011 Bitumen shingles with mineral and/or synthetic reinforcements - Product specification and test methods
EN 607:2004 Eaves gutters and fittings made of PVC-U - Definitions, requirements and testing
EN 612:2005 Eaves gutters with bead stiffened fronts and rainwater pipes with seamed joints made of metal sheet
CR 833:1992 General requirements for a discontinuously laid roofing covering
EN 1013:2012+A1:2014 Light transmitting single skin profiled plastics sheets for internal and external roofs, walls and ceilings - Requirements and test methods
EN 1024:2012 Clay roofing tiles for discontinuous laying - Determination of geometric characteristics
EN 1304:2013 Clay roofing tiles and fittings - Product definitions and specifications
EN 1462:2004 Brackets for eaves gutters - Requirements and testing
EN 1873:2014 Prefabricated accessories for roofing - Individual rooflights of plastics - Product specification and test methods
EN 12326-1:2014 Slate and stone for discontinuous roofing and external cladding - Part 1: Specifications for slate and carbonate slate
EN 12326-2:2011 Slate and stone for discontinuous roofing and external cladding - Part 2: Methods of test for slate and carbonate slate
EN 12467:2012 Fibre-cement flat sheets - Product specification and test methods
EN 12951:2004 Prefabricated accessories for roofing - Permanently fixed roof ladders - Product specification and test methods
EN 14437:2004 Determination of the uplift resistance of installed clay or concrete tiles for roofing - Roof system test method
EN 14509:2013 Self-supporting double skin metal faced insulating panels - Factory made products - Specifications
EN 14782:2006 Self-supporting metal sheet for roofing, external cladding and internal lining - Product specification and requirements
EN 14783:2013 Fully supported metal sheet and strip for roofing, external cladding and internal lining - Product specification and requirements
EN 14963:2006 Roof coverings - Continuous rooflights of plastics with or without upstands - Classification, requirements and test methods
EN 14964:2006 Rigid underlays for discontinuous roofing - Definitions and characteristics
EN 15057:2006 Fibre cement profiled sheets - Impact resistance test method
CEN/TS 15087:2005 Determination of the uplift resistance of installed clay and concrete interlocking tiles for roofing - Test method for mechanical fasteners
EN 16153:2013+A1:2015 Light transmitting flat multiwall polycarbonate (PC) sheets for internal and external use in roofs, walls and ceilings - Requirements and test methods
EN 16240:2013 Light transmitting flat solid polycarbonate (PC) sheets for internal and external use in roofs, walls and ceilings - Requirements and test methods
what we missing is:
EN 494:2012+A1:2015 Fibre-cement profiled sheets and fittings - Product specification and test methods - missing A1
CR 833:1992 General requirements for a discontinuously laid roofing covering - missing
EN 1013:2012+A1:2014 Light transmitting single skin profiled plastics sheets for internal and external roofs, walls and ceilings - Requirements and test methods - missing A1
EN 16153:2013+A1:2015 Light transmitting flat multiwall polycarbonate (PC) sheets for internal and external use in roofs, walls and ceilings - Requirements and test methods - missing A1
or
