HMIP Technical Guidance Note D1: "Guidelines on Discharge Stack Heights for Polluting Emissions", published by The Stationery Office, ISBN 0-11-752794-7
Dorio, please put the name of the item you need or supply in the title of your posting, not just the word "request". That's annoying because you can't see quickly what it is about.
Thanks for your corporation.
----n.a.
HMIP 1993 ‘Guidelines on Discharge Stack Heights for Polluting Emission. Technical Guidance Note D1 (Dispersion)’ ISBN 0 11 752794 7. This document is now out-of-print, but is available from the British Library. It provides a simple but versatile method for calculating the minimum permissible chimney height to safeguard against short-term air quality impacts, for any pollutant species. It allows for building downwash effects but not terrain effects.
The D1 method uses the 98th percentile envelope of meteorological conditions. Therefore, the D1 method could under-estimate the chimney height required for compliance against the current short-term air quality objective for NO2 (which approximates to a 99.8th percentile) or the 15-minute mean SO2 objective (which approximates to a 99.9th percentile).
Care should be taken in using the D1 method, in terms of defining the local background (Bc) and the current air quality guideline value (Gd). The default values set out in the HMIP document (dated 1993) are out-of-date. For Gd, the current statutory short-term Air Quality Strategy objectives should be used instead of values provided in Table 1 of the D1 Guidance. For Bc, local measured or estimated relevant percentile of the short-term background concentrations should be used instead of values provided in Table 2 of the D1 Guidance. Typically, these can be calculated from hourly/daily monitoring data from AURN monitoring stations or other local monitoring station.
The attached file is someones completed application which might have the form that you need...
A chimney height calculator is on this page (windows)
several other chimney calc files are on Scribd, look at the similar files at the bottom of this file
