hello,
anyone have this standard?
NFPA T3.5.1:2002 (R2010)
thanks![]()
hello,
thanks![]()
nodoby have that standard?...
Hi gospel85:
I suggest you to post your request in the Safety and Environment Forum. Maybe you will get luckier.
I looked at the NFPA 2002 codes and could not find a document named T3.5.1. I have not seen before than kind of numbering for an approved NFPA code or standard. I also checked in[link Point to another website Only the registered members can access]
By the way, what is the title of the document?
gospel85,
There is no such nfpa code as you had specified " NFPA T3.5.1:2002 (R2010)". I suggest that you check your requirement so that we may able to assist . . . may be this is reference table from one of the NFPA codes that you had specified.
anybody with NACE 34101 Refinery Injection and Process Mixing Points
