" Case Study in Upgrading Capability of a Crude Oil Pipeline for Maximum Transportation Capacity"Abstract
Since November 1984 The 406.4 mm x 166 km has run from Meleiha field at Egypt's Western Desert to El-Hamra terminal on the coast of the Mediterranean Sea (Figure 1). Its original capacity was 100,000 barrels oil per day (BOPD) using two pumping stations. Planned pumped flow rate increased to 177,000 BOPD when maximum allowable working pressure (MAWP) reduced from 1463 psi to 950 psi. This paper shows how to increase flow rates without reaching MAWP, two methods are recommended: 1) loop the existing pipeline using a 406.4 mm x 56 km pipe. 2) Use a drag reducing agent (DRA) to reduce hydraulic friction losses and total dynamic pressure (TDP) thereby pumping more with reduced initial pumping pressure at Meleiha. Mathematical models are designed to simulate pumping operation through the whole system, with TDP predicted for three pipeline cases: 1) Normal case without both looping and DRA. 2) Oil pumping without DRA and with looping. 3) Oil pumping with both looping and DRA.
Introduction
This paper discusses the upgrading of the existing pipeline of Meleiha / El-Hamra, that could increase transportation capacity of this pipeline up to 177,000 BOPD (Figure 1). Crude oil is 42 API° (as per the Engineering Tool Box), its sp.gr. (60 °F / 60 °F) is 0.8156, from which pressure gradient is 1.1595 psi/m (used to express pressure in psi or bar as terms of oil pressure head in meter). Kinematic viscosity is 2.5 c.st. at 40°C. Upgrading stages passed the following two phases:
