7 are missing:
EN ISO 196:1995 Wrought copper and copper alloys - Detection of residual stress - Mercury(I) nitrate test (ISO 196:1978)
EN 723:2009 Copper and copper alloys - Combustion method for determination of the carbon content on the inner surface of copper tubes or fittings
EN 1057:2006+A1:2010 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications
EN 1172:2011 Copper and copper alloys - Sheet and strip for building purposes
EN 1173:2008 Copper and copper alloys - Material condition designation
EN 1254-1:1998 Copper and copper alloys - Plumbing fittings - Part 1: Fittings with ends for capillary soldering or capillary brazing to copper tubes
EN 1254-2:1998 Copper and copper alloys - Plumbing fittings - Part 2: Fittings with compression ends for use with copper tubes
EN 1254-3:1998 Copper and copper alloys - Plumbing fittings - Part 3: Fittings with compression ends for use with plastics pipes
EN 1254-4:1998 Copper and copper alloys - Plumbing fittings - Part 4: Fittings combining other end connections with capillary or compression ends
EN 1254-4:1998/AC:1999 Copper and copper alloys - Plumbing fittings - Part 4: Fittings combining other end connections with capillary or compression ends
EN 1254-5:1998 Copper and copper alloys - Plumbing fittings - Part 5: Fittings with short ends for capillary brazing to copper tubes
EN 1254-6:2012 Copper and copper alloys - Plumbing fittings - Part 6: Fittings with push-fit ends
EN 1254-8:2012 Copper and copper alloys - Plumbing fittings - Part 8: Fittings with press ends for use with plastics and multilayer pipes
EN 1412:1995 Copper and copper alloys - European numbering system
EN 1652:1997 Copper and copper alloys - Plate, sheet, strip and circles for general purposes
EN 1652:1997/AC:2003 Copper and copper alloys - Plate, sheet, strip and circles for general purposes
EN 1653:1997 Copper and copper alloys - Plate, sheet and circles for boilers, pressure vessels and hot water storage units
EN 1653:1997/A1:2000 Copper and copper alloys - Plate, sheet and circles for boilers, pressure vessels and hot water storage units
EN 1654:1997 Copper and copper alloys - Strip for springs and connectors
EN 1654:1997/AC:2003 Copper and copper alloys - Strip for springs and connectors
EN 1655:1997 Copper and copper alloys - Declarations of conformity
EN 1758:1997 Copper and copper alloys - Strip for lead frames
EN 1971-1:2011 Copper and copper alloys - Eddy current test for measuring defects on seamless round copper and copper alloy tubes - Part 1: Test with an encircling test coil on the outer surface
EN 1971-2:2011 Copper and copper alloys - Eddy current test for measuring defects on seamless round copper and copper alloy tubes - Part 2: Test with an internal probe on the inner surface
EN 1976:2012 Copper and copper alloys - Cast unwrought copper products
EN 1977:2013 Copper and copper alloys - Copper drawing stock (wire rod)
EN 1978:1998 Copper and copper alloys - Copper cathodes
EN 1981:2003 Copper and copper alloys - Master alloys
EN 1982:2008 Copper and copper alloys - Ingots and castings
EN ISO 2624:1995 Copper and copper alloys - Estimation of average grain size (ISO 2624:1990)
EN ISO 2626:1995 Copper - Hydrogen embrittlement test (ISO 2626:1973)
EN 12163:2011 Copper and copper alloys - Rod for general purposes
EN 12164:2011 Copper and copper alloys - Rod for free machining purposes
EN 12165:2011 Copper and copper alloys - Wrought and unwrought forging stock
EN 12166:2011 Copper and copper alloys - Wire for general purposes
EN 12167:2011 Copper and copper alloys - Profiles and bars for general purposes
EN 12168:2011 Copper and copper alloys - Hollow rod for free machining purposes
EN 12384:1999 Copper and copper alloys - Determination of spring bending limit on strip
EN 12420:2014 Copper and copper alloys - Forgings - missing VE
EN 12449:2012 Copper and copper alloys - Seamless, round tubes for general purposes
EN 12450:2012 Copper and copper alloys - Seamless, round copper capillary tubes
EN 12451:2012 Copper and copper alloys - Seamless, round tubes for heat exchangers
EN 12452:2012 Copper and copper alloys - Rolled, finned, seamless tubes for heat exchangers
EN 12735-1:2010 Copper and copper alloys - Seamless, round copper tubes for air conditioning and refrigeration - Part 1: Tubes for piping systems
EN 12735-2:2010 Copper and copper alloys - Seamless, round copper tubes for air conditioning and refrigeration - Part 2: Tubes for equipment
CR 12776:1997 Copper and copper alloys - Provisions and procedures for the allocation of material numbers and registration of materials
EN 12861:1999 Copper and copper alloys - Scrap
EN 12893:2000 Copper and copper alloys - Determination of spiral elongation number
EN 13147:2001 Copper and copper alloys - Determination of residual stresses in the border area of slit strip
EN 13148:2010 Copper and copper alloys - Hot-dip tinned strip
EN 13348:2008 Copper and copper alloys - Seamless, round copper tubes for medical gases or vacuum
EN 13349:2002 Copper and copper alloys - Pre-insulated copper tubes with solid covering
CEN/TS 13388:2015 Copper and copper alloys - Compendium of compositions and products - missing VE
EN 13599:2014 Copper and copper alloys - Copper plate, sheet and strip for electrical purposes
EN 13600:2013 Copper and copper alloys - Seamless copper tubes for electrical purposes
EN 13601:2013 Copper and copper alloys - Copper rod, bar and wire for general electrical purposes
EN 13602:2013 Copper and copper alloys - Drawn, round copper wire for the manufacture of electrical conductors
EN 13603:2013 Copper and copper alloys - Test methods for assessing protective tin coatings on drawn round copper wire for electrical purposes
EN 13604:2013 Copper and copper alloys - Semiconductor devices, electronic and vacuum products made from high conductivity copper
EN 13605:2013 Copper and copper alloys - Copper profiles and profiled wire for electrical purposes
EN 14436:2004 Copper and copper alloys - Electrolytically tinned strip
EN 14935:2006 Copper and copper alloys - Determination of impurities in pure copper - ET AAS method
EN 14936-1:2006 Copper and copper alloys - Determination of aluminium content - Part 1: Titrimetric method
EN 14936-2:2006 Copper and copper alloys - Determination of aluminium content - Part 2: FAAS method
EN 14937-1:2006 Copper and copper alloys - Determination of antimony content - Part 1: Spectrophotometric method
EN 14937-2:2006 Copper and copper alloys - Determination of antimony content - Part 2: FAAS method
EN 14938-2:2010 Copper and copper alloys - Determination of bismuth content - Part 2: Flame atomic absorption spectrometric method (FAAS)
EN 14939:2006 Copper and copper alloys - Determination of beryllium content - FAAS method
CEN/TS 14940-1:2009 Copper and copper alloys - Determination of chromium content - Part 1: Titrimetric method - missing
EN 14940-2:2006 Copper and copper alloys - Determination of chromium content - Part 2: FAAS method
EN 14941:2006 Copper and copper alloys - Determination of cobalt content - FAAS method
EN 14942-2:2006 Copper and copper alloys - Determination of arsenic content - Part 2: FAAS method
EN 14977:2006 Copper and copper alloys - Detection of tensile stress - 5 % ammonia test
CEN/TS 15022-2:2009 Copper and copper alloys - Determination of tin content - Part 2: Spectrophotometric method
EN 15022-3:2006 Copper and copper alloys - Determination of tin content - Part 3: Low tin content - Flame atomic absorption spectrometry method (FAAS)
EN 15022-4:2011 Copper and copper alloys - Determination of tin content - Part 4: Medium tin content - Flame atomic absorption spectrometric method (FAAS)
EN 15023-3:2010 Copper and copper alloys - Determination of nickel content - Part 3: Flame atomic absorption spectrometric method (FAAS)
EN 15024-2:2006 Copper and copper alloys - Determination of zinc content - Part 2: Flame atomic absorption spectrometry method (FAAS)
EN 15025:2010 Copper and copper alloys - Determination of magnesium content - Flame atomic absorption spectrometric method (FAAS)
EN 15063-1:2014 Copper and copper alloys - Determination of main constituents and impurities by wavelength dispersive X-ray fluorescence spectrometry (XRF) - Part 1: Guidelines to the routine method - missing VE
EN 15063-2:2006 Copper and copper alloys - Determination of main constituents and impurities by wavelength dispersive X-ray fluorescence spectrometry (XRF) - Part 2: Routine method
EN 15079:2015 Copper and copper alloys - Analysis by spark source optical emission spectrometry (S-OES) - missing VE
EN 15605:2010 Copper and copper alloys - Inductively coupled plasma optical emission spectrometry
EN 15616:2012 Copper and copper alloys - Determination of cadmium content - Flame atomic absorption spectrometric method (FAAS)
EN 15622:2010 Copper and copper alloys - Determination of lead content - Flame atomic absorption spectrometric method (FAAS)
CEN/TS 15656:2015 Copper and copper alloys - Determination of phosphorus content - Spectrophotometric method - missing
CEN/TS 15703-1:2009 Copper and copper alloys - Determination of manganese content - Part 1: Spectrophotometric method - missing
EN 15703-2: 2014 Copper and copper alloys - Determination of manganese content - Part 2: Flame atomic absorption spectrometric method (FAAS) - missing VE
EN 15690-2:2009 Copper and copper alloys - Determination of iron content - Part 2: Flame atomic absorption spectrometric method (FAAS)
EN 15915:2010 Copper and copper alloys - Determination of silver content - Flame atomic absorption spectrometric method (FAAS)
CEN/TS 15916-1:2011 Copper and copper alloys - Determination of tellurium content - Part 1: Low tellurium content - Flame atomic absorption spectrometric method (FAAS)
EN 15916-2:2010 Copper and copper alloys - Determination of tellurium content - Part 2: Medium tellurium content - Flame atomic absorption spectrometric method (FAAS)
EN 16090:2011 Copper and copper alloys - Estimation of average grain size by ultrasound
EN 16117-1:2011 Copper and copper alloys - Determination of copper content - Part 1: Electrolytic determination of copper in materials with copper content less than 99,85 %
EN 16117-2:2012 Copper and copper alloys - Determination of copper content - Part 2: Electrolytic determination of copper in materials with copper content higher than 99,80 %
or
