Page 1 of 2 1 2 LastLast
Results 1 to 12 of 21
Thread: CEN Standards Collection 35/370: CEN TC 32 - Aluminium And Aluminium Alloys
    only 3 missing
    EN 485-1:2008+A1:2009 Aluminium and aluminium alloys - Sheet, strip and plate - Part 1: Technical conditions for inspection and delivery
    EN 485-2:2013 Aluminium and aluminium alloys - Sheet, strip and plate - Part 2: Mechanical properties
    EN 485-3:2003 Aluminium and aluminium alloys - Sheet, strip and plate - Part 3: Tolerances on dimensions and form for hot-rolled products
    EN 485-4:1993 Aluminium and aluminium alloys - Sheet, strip and plate - Part 4: Tolerances on shape and dimensions for cold-rolled products
    EN 486:2009 Aluminium and aluminium alloys - Extrusion ingots - Specifications
    EN 487:2009 Aluminium and aluminium alloys - Rolling ingots - Specifications
    EN 515:1993 Aluminium and aluminium alloys - Wrought products - Temper designations
    EN 541:2006 Aluminium and aluminium alloys - Rolled products for cans, closures and lids - Specifications
    EN 546-1:2006 Aluminium and aluminium alloys - Foil - Part 1: Technical conditions for inspection and delivery
    EN 546-2:2006 Aluminium and aluminium alloys - Foil - Part 2: Mechanical properties
    EN 546-3:2006 Aluminium and aluminium alloys - Foil - Part 3: Tolerances on dimensions
    EN 546-4:2006 Aluminium and aluminium alloys - Foil - Part 4: Special property requirements
    EN 570:2007 Aluminium and aluminium alloys - Impact extrusion slugs obtained from wrought products - Specification
    EN 573-1:2004 Aluminium and aluminium alloys - Chemical composition and form of wrought products - Part 1: Numerical designation system
    EN 573-2:1994 Aluminium and aluminium alloys - Chemical composition and form of wrought products - Part 2: Chemical symbol based designation system
    EN 573-3:2013 Aluminium and aluminium alloys - Chemical composition and form of wrought products - Part 3: Chemical composition and form of products
    EN 573-5:2007 Aluminium and aluminium alloys - Chemical composition and form of wrought products - Part 5: Codification of standardized wrought products
    EN 575:1995 Aluminium and aluminium alloys - Master alloys produced by melting - Specifications
    EN 576:2003 Aluminium and aluminium alloys - Unalloyed aluminium ingots for remelting - Specifications
    EN 577:1995 Aluminium and aluminium alloys - Liquid metal - Specifications
    EN 586-1:1997 Aluminium and aluminium alloys - Forgings - Part 1: Technical conditions for inspection and delivery
    EN 586-2:1994 Aluminium and aluminium alloys - Forgings - Part 2: Mechanical properties and additional property requirements
    EN 586-3:2001 Aluminium and aluminium alloys - Forgings - Part 3: Tolerances on dimensions and form
    EN 601:2004 Aluminium and aluminium alloys - Castings - Chemical composition of castings for use in contact with foodstuff
    EN 602:2004 Aluminium and aluminium alloys - Wrought products - Chemical composition of semi-finished products used for the fabrication of articles for use in contact with foodstuff
    EN 603-1:1996 Aluminium and aluminium alloys - Wrought forging stock - Part 1: Technical conditions for inspection and delivery
    EN 603-2:1996 Aluminium and aluminium alloys - Wrought forging stock - Part 2: Mechanical properties
    EN 603-3:2000 Aluminium and aluminium alloys - Wrought forging stock - Part 3: Tolerances on dimensions and form
    EN 604-1:1997 Aluminium and aluminium alloys - Cast forging stock - Part 1: Technical conditions for inspection and delivery
    EN 604-2:1997 Aluminium and aluminium alloys - Cast forging stock - Part 2: Tolerances on dimensions and form
    EN 683-1:2006 Aluminium and aluminium alloys - Finstock - Part 1: Technical conditions for inspection and delivery
    EN 683-2:2006 Aluminium and aluminium alloys - Finstock - Part 2: Mechanical properties
    EN 683-3:2006 Aluminium and aluminium alloys - Finstock - Part 3: Tolerances on dimensions and form
    EN 754-1:2008 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 1: Technical conditions for inspection and delivery
    EN 754-2:2013 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 2: Mechanical properties
    EN 754-3:2008 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 3: Round bars, tolerances on dimensions and form
    EN 754-4:2008 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 4: Square bars, tolerances on dimensions and form
    EN 754-5:2008 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 5: Rectangular bars, tolerances on dimensions and form
    EN 754-6:2008 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 6: Hexagonal bars, tolerances on dimensions and form
    EN 754-7:2008 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 7: Seamless tubes, tolerances on dimensions and form
    EN 754-8:2008 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 8: Porthole tubes, tolerances on dimensions and form
    EN 755-1:2008 Aluminium and aluminium alloys- Extruded rod/bar, tube and profiles - Part 1: Technical conditions for inspection and delivery
    EN 755-2:2013 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 2: Mechanical properties
    EN 755-3:2008 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 3: Round bars, tolerances on dimensions and form
    EN 755-4:2008 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 4: Square bars, tolerances on dimensions and form
    EN 755-5:2008 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 5: Rectangular bars, tolerances on dimensions and form
    EN 755-6:2008 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 6: Hexagonal bars, tolerances on dimensions and form
    EN 755-7:2008 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 7: Seamless tubes, tolerances on dimensions and form
    EN 755-8:2008 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 8: Porthole tubes, tolerances on dimensions and form
    EN 755-9:2008 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 9: Profiles, tolerances on dimensions and form
    EN 851:2014 Aluminium and aluminium alloys - Circle and circle stock for the production of culinary utensils - Specifications
    EN 941:2014 Aluminium and aluminium alloys - Circle and circle stock for the production of general applications - Specifications - missing VE
    EN 1301-1:2008 Aluminium and aluminium alloys - Drawn wire - Part 1: Technical conditions for inspection and delivery
    EN 1301-2:2008 Aluminium and aluminium alloys - Drawn wire - Part 2: Mechanical properties
    EN 1301-3:2008 Aluminium and aluminium alloys - Drawn wire - Part 3: Tolerances on dimensions
    EN 1386:2007 Aluminium and aluminium alloys - Tread plate - Specifications
    EN 1396:2015 Aluminium and aluminium alloys - Coil coated sheet and strip for general applications - Specifications
    EN 1559-4:2015 Founding - Technical conditions of delivery - Part 4: Additional requirements for aluminium alloy castings
    EN 1592-1:1997 Aluminium and aluminium alloys - HF seam welded tubes - Part 1: Technical conditions for inspection and delivery
    EN 1592-2:1997 Aluminium and aluminium alloys - HF seam welded tubes - Part 2: Mechanical properties
    EN 1592-3:1997 Aluminium and aluminium alloys - HF seam welded tubes - Part 3: Tolerances on dimensions and form for circular tubes
    EN 1592-4:1997 Aluminium and aluminium alloys - HF seam welded tubes - Part 4: Tolerances on dimensions and form for square, rectangular and shaped tubes
    EN 1669:1996 Aluminium and aluminium alloys - Test methods - Earing test for sheet and strip
    EN 1676:2010 Aluminium and aluminium alloys - Alloyed ingots for remelting - Specifications
    EN 1706:2010 Aluminium and aluminium alloys - Castings - Chemical composition and mechanical properties
    EN 1715-1:2008 Aluminium and aluminium alloys - Drawing stock - Part 1: General requirements and technical conditions for inspection and delivery
    EN 1715-2:2008 Aluminium and aluminium alloys - Drawing stock - Part 2: Specific requirements for electrical applications
    EN 1715-3:2008 Aluminium and aluminium alloys - Drawing stock - Part 3: Specific requirements for mechanical uses (excluding welding)
    EN 1715-4:2008 Aluminium and aluminium alloys - Drawing stock - Part 4: Specific requirements for welding applications
    EN 1780-1:2002 Aluminium and aluminium alloys - Designation of alloyed aluminium ingots for remelting, master alloys and castings - Part 1: Numerical designation system
    EN 1780-2:2002 Aluminium and aluminium alloys - Designation of alloyed aluminium ingots for remelting, master alloys and castings - Part 2: Chemical symbol based designation system
    EN 1780-3:2002 Aluminium and aluminium alloys - Designation of alloyed aluminium ingots for remelting, master alloys and castings - Part 3: Writing rules for chemical composition
    EN ISO 2085:2010 Anodizing of aluminium and its alloys - Check for continuity of thin anodic oxidation coatings - Copper sulfate test (ISO 2085:2010)
    EN ISO 2106:2011 Anodizing of aluminium and its alloys - Determination of mass per unit area (surface density) of anodic oxidation coatings - Gravimetric method (ISO 2106:2011)
    EN ISO 2128:2010 Anodizing of aluminium and its alloys - Determination of thickness of anodic oxidation coatings - Non-destructive measurement by split-beam microscope (ISO 2128:2010)
    EN ISO 2143:2010 Anodizing of aluminium and its alloys - Estimation of loss of absorptive power of anodic oxidation coatings after sealing - Dye-spot test with prior acid treatment (ISO 2143:2010)
    EN ISO 2376:2010 Anodizing of aluminium and its alloys - Determination of electric breakdown potential (ISO 2376:2010)
    EN ISO 2931:2010 Anodizing of aluminium and its alloys - Assessment of quality of sealed anodic oxidation coatings by measurement of admittance (ISO 2931:2010)
    EN ISO 3210:2010 Anodizing of aluminium and its alloys - Assessment of quality of sealed anodic oxidation coatings by measurement of the loss of mass after immersion in phosphoric acid/chromic acid solution (ISO 3210:2010)
    EN ISO 3211:2010 Anodizing of aluminium and its alloys - Assessment of resistance of anodic oxidation coatings to *****ing by deformation (ISO 3211:2010)
    EN ISO 6719:2010 Anodizing of aluminium and its alloys - Measurement of reflectance characteristics of aluminium surfaces using integrating-sphere instruments (ISO 6719:2010)
    EN ISO 6581:2010 Anodizing of aluminium and its alloys - Determination of the comparative fastness to ultraviolet light and heat of coloured anodic oxidation coatings (ISO 6581:2010)
    EN ISO 7599:2010 Anodizing of aluminium and its alloys - General specifications for anodic oxidation coatings on aluminium (ISO 7599:2010)
    EN ISO 7668:2010 Anodizing of aluminium and its alloys - Measurement of specular reflectance and specular gloss of anodic oxidation coatings at angles of 20 degrees, 45 degrees, 60 degrees or 85 degrees (ISO 7668:2010)
    EN ISO 7759:2010 Anodizing of aluminium and its alloys - Measurement of reflectance characteristics of aluminium surfaces using a goniophotometer or an abridged goniophotometer (ISO/FDIS 7759:2010)
    EN ISO 8251:2011 Anodizing of aluminium and its alloys - Measurement of abrasion resistance of anodic oxidation coatings (ISO 8251:2011)
    EN ISO 8993:2010 Anodizing of aluminium and its alloys - Rating system for the evaluation of pitting corrosion - Chart method (ISO 8993:2010)
    EN ISO 8994:2011 Anodizing of aluminium and its alloys - Rating system for the evaluation of pitting corrosion - Grid method (ISO 8994:2011)
    EN ISO 10215:2010 Anodizing of aluminium and its alloys - Visual determination of image clarity of anodic oxidation coatings - Chart scale method (ISO 10215:2010)
    EN 12020-1:2008 Aluminium and aluminium alloys - Extruded precision profiles in alloys EN AW-6060 and EN AW-6063 - Part 1: Technical conditions for inspection and delivery
    EN 12020-2:2008 Aluminium and aluminium alloys - Extruded precision profiles in alloys EN AW-6060 and EN AW-6063 - Part 2: Tolerances on dimensions and form
    EN 12258-1:2012 Aluminium and aluminium alloys - Terms and definitions - Part 1: General terms
    EN 12258-2:2004 Aluminium and aluminium alloys - Terms and definitions - Part 2: Chemical analysis
    EN 12258-3:2003 Aluminium and aluminium alloys - Terms and definitions - Part 3: Scrap
    EN 12258-4:2004 Aluminium and aluminium alloys - Terms and definitions - Part 4: Residues of the aluminium industry
    EN 12392:2000 Aluminium and aluminium alloys - Wrought products - Special requirements for products intended for the production of pressure equipment
    EN 12482-1:1998 Aluminium and aluminium alloys - Reroll stock for general applications - Part 1: Specifications for hot rolled reroll stock
    EN 12482-2:1998 Aluminium and aluminium alloys - Reroll stock for general applications - Part 2: Specifications for cold rolled reroll stock
    EN 13195:2013 Aluminium and aluminium alloys - Specifications for wrought and cast products for marine applications (shipbuilding, marine and offshore)
    EN 13920-1:2003 Aluminium and aluminium alloys - Scrap - Part 1: General requirements, sampling and tests
    EN 13920-2:2003 Aluminium and aluminium alloys - Scrap - Part 2: Unalloyed aluminium scrap
    EN 13920-3:2003 Aluminium and aluminium alloys - Scrap - Part 3: Wire and cable scrap
    EN 13920-4:2003 Aluminium and aluminium alloys - Scrap - Part 4: Scrap consisting of one single wrought alloy
    EN 13920-5:2003 Aluminium and aluminium alloys - Scrap - Part 5: Scrap consisting of two or more wrought alloys of the same series
    EN 13920-6:2003 Aluminium and aluminium alloys - Scrap - Part 6: Scrap consisting of two or more wrought alloys
    EN 13920-7:2003 Aluminium and aluminium alloys - Scrap - Part 7: Scrap consisting of castings
    EN 13920-8:2003 Aluminium and aluminium alloys - Scrap - Part 8: Scrap consisting of non-ferrous materials from shredding processes destined to aluminium separation processes
    EN 13920-9:2003 Aluminium and aluminium alloys - Scrap - Part 9: Scrap from aluminium separation processes of non-ferrous shredded materials
    EN 13920-10:2003 Aluminium and aluminium alloys - Scrap - Part 10: Scrap consisting of used aluminium beverage cans
    EN 13920-11:2003 Aluminium and aluminium alloys - Scrap - Part 11: Scrap consisting of aluminium-copper radiators
    EN 13920-12:2003 Aluminium and aluminium alloys - Scrap - Part 12: Turnings consisting of one single alloy
    EN 13920-13:2003 Aluminium and aluminium alloys - Scrap - Part 13: Mixed turnings consisting of two or more alloys
    EN 13920-14:2003 Aluminium and aluminium alloys - Scrap - Part 14: Scrap from post-consumer aluminium packagings
    EN 13920-15:2003 Aluminium and aluminium alloys - Scrap - Part 15: Decoated aluminium scrap from post-consumer aluminium packagings
    EN 13920-16:2003 Aluminium and aluminium alloys - Scrap - Part 16: Scrap consisting of skimmings, drosses, spills and metallics
    EN 13957:2008 Aluminium and aluminium alloys - Extruded round, coiled tube for general applications - Specification
    EN 13958:2008 Aluminium and aluminium alloys - Cold drawn, round, coiled tube for general applications - Specification
    EN 13981-1:2003 Aluminium and aluminium alloys - Products for structural railway applications - Technical conditions for inspection and delivery - Part 1: Extruded products
    EN 13981-2:2004 Aluminium and aluminium alloys - Products for structural railway applications - Technical conditions for inspection and delivery - Part 2: Plates and sheets
    EN 13981-3:2006 Aluminium and aluminium alloys - Products for structural railway applications - Technical conditions for inspection and delivery - Part 3: Castings
    EN 13981-4:2006 Aluminium and aluminium alloys - Products for structural railway applications - Technical conditions for inspection and delivery - Part 4: Forgings
    EN 14121:2009 Aluminium and aluminium alloys - Sheet, strip and plate for electrotechnical applications
    EN 14242:2004 Aluminium and aluminium alloys - Chemical analysis - Inductively coupled plasma optical emission spectral analysis
    EN 14286:2008 Aluminium and aluminium alloys - Weldable rolled products for tanks for the storage and transportation of dangerous goods
    EN 14287:2004 Aluminium and aluminium alloys - Specific requirements on the chemical composition of products intended to be used for the manufacture of packaging and packaging components
    EN 14361:2004 Aluminium and aluminium alloys - Chemical analysis - Sampling from metal melts
    EN 14392:2007 Aluminium and aluminium alloys - Requirements for anodised products for use in contact with foodstuff
    EN 14726:2005 Aluminium and aluminium alloys - Chemical analysis - Guideline for spark optical emission spectrometric analysis
    EN 15088:2005 Aluminium and aluminium alloys - Structural products for construction works - Technical conditions for inspection and delivery
    EN 15530:2008 Aluminium and aluminium alloys - Environmental aspects of aluminium products - General guidelines for their inclusion in standards
    CEN/TR 16748: 2014 Aluminium and aluminium alloys - Mechanical potential of Al-Si alloys for high pressure, low pressure and gravity die casting - missing
    CEN/TR 16749: 2014 Aluminium and aluminium alloys - Classification of Defects and Imperfections in High Pressure, Low Pressure and Gravity Die Cast Products - missing
    or
    Re: CEN standards collection 35/100: CEN TC 32 - Aluminium And Aluminium Alloys
    added just few better qualioty starndards, and some misising...
    now we missing here:
    EN 16773:2016 Aluminium and aluminium alloys - Guideline for the production of foil-stock in the field of semi rigid foodstuff containers - missing
    or
  5. Re: CEN Standards Collection 35/300: CEN TC 32 - Aluminium And Aluminium Alloys
    could any one update the links
    thank you a lot
    Quote Originally Posted by xx_man270 View Post
    thank you a lot
    Dear Sir
    The "mediafire links" is ok in the post #1 and # 2 and these are equal to the "hugefiles links "
    thank you a lot
    Dear Sir
    fresh linkz:
    added new standard:
    EN 754-1:2016 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 1: Technical conditions for inspection and delivery
    added missing standards:
    EN 12392:2016 Aluminium and aluminium alloys - Wrought products and cast products - Special requirements for products intended for the production of pressure equipment
    one new missing standard here:
    EN 755-2:2016 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 2: Mechanical properties
    or
    Re: CEN Standards Collection 35/340: CEN TC 32 - Aluminium And Aluminium Alloys
    only bigger list of new missing standards:
    EN 754-8:2016 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 8: Porthole tubes, tolerances on dimensions and form
    EN 755-1:2016 Aluminium and aluminium alloys- Extruded rod/bar, tube and profiles - Part 1: Technical conditions for inspection and delivery
    EN 755-7:2016 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 7: Seamless tubes, tolerances on dimensions and form
    EN 755-8:2016 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 8: Porthole tubes, tolerances on dimensions and form
    EN 755-9:2016 Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 9: Profiles, tolerances on dimensions and form
    EN 12932:2016 Aluminium and aluminium alloys - Wrought products and cast products - Special requirements for products intended for the production of pressure equipment
    links:
    Aug 2015
    Dubai, UAE
    Blog Entries
    4
    Only 1 from above list ...!
    Attached Files Attached Files
    Thanks & Regards:
    Amjad Malik
    thank you my friend
  14. #11
    update:
    EN 754-2:2013 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 2: Mechanical properties - EN version
    EN 1676:2010 Aluminium and aluminium alloys - Alloyed ingots for remelting - Specifications - EN version
    EN 1706:2010 Aluminium and aluminium alloys - Castings - Chemical composition and mechanical properties - EN version
    EN ISO 2085:2010 Anodizing of aluminium and its alloys - Check for continuity of thin anodic oxidation coatings - Copper sulfate test (ISO 2085:2010) - EN version
    EN ISO 2106:2011 Anodizing of aluminium and its alloys - Determination of mass per unit area (surface density) of anodic oxidation coatings - Gravimetric method (ISO 2106:2011) - EN version
    EN ISO 2128:2010 Anodizing of aluminium and its alloys - Determination of thickness of anodic oxidation coatings - Non-destructive measurement by split-beam microscope (ISO 2128:2010) - EN version
    EN ISO 2143:2010 Anodizing of aluminium and its alloys - Estimation of loss of absorptive power of anodic oxidation coatings after sealing - Dye-spot test with prior acid treatment (ISO 2143:2010) - EN version
    EN ISO 2931:2010 Anodizing of aluminium and its alloys - Assessment of quality of sealed anodic oxidation coatings by measurement of admittance (ISO 2931:2010) - EN version
    EN ISO 3210:2010 Anodizing of aluminium and its alloys - Assessment of quality of sealed anodic oxidation coatings by measurement of the loss of mass after immersion in phosphoric acid/chromic acid solution (ISO 3210:2010) - EN version
    EN ISO 3211:2010 Anodizing of aluminium and its alloys - Assessment of resistance of anodic oxidation coatings to *****ing by deformation (ISO 3211:2010) - EN version
    EN ISO 6719:2010 Anodizing of aluminium and its alloys - Measurement of reflectance characteristics of aluminium surfaces using integrating-sphere instruments (ISO 6719:2010) - EN version
    EN ISO 6581:2010 Anodizing of aluminium and its alloys - Determination of the comparative fastness to ultraviolet light and heat of coloured anodic oxidation coatings (ISO 6581:2010) - EN version
    EN ISO 7599:2010 Anodizing of aluminium and its alloys - General specifications for anodic oxidation coatings on aluminium (ISO 7599:2010) - EN version
    EN ISO 7668:2010 Anodizing of aluminium and its alloys - Measurement of specular reflectance and specular gloss of anodic oxidation coatings at angles of 20 degrees, 45 degrees, 60 degrees or 85 degrees (ISO 7668:2010) - EN version
    EN ISO 7759:2010 Anodizing of aluminium and its alloys - Measurement of reflectance characteristics of aluminium surfaces using a goniophotometer or an abridged goniophotometer (ISO/FDIS 7759:2010) - EN version
    EN ISO 8251:2011 Anodizing of aluminium and its alloys - Measurement of abrasion resistance of anodic oxidation coatings (ISO 8251:2011) - EN version
    EN ISO 8994:2011 Anodizing of aluminium and its alloys - Rating system for the evaluation of pitting corrosion - Grid method (ISO 8994:2011) - EN version
    EN 13195:2013 Aluminium and aluminium alloys - Specifications for wrought and cast products for marine applications (shipbuilding, marine and offshore) - EN version
    missing list:
    EN 485-1:2016 Aluminium and aluminium alloys - Sheet, strip and plate - Part 1: Technical conditions for inspection and delivery
    EN 485-2:2016 Aluminium and aluminium alloys - Sheet, strip and plate - Part 2: Mechanical properties
    EN 754-7:2016 Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 7: Seamless tubes, tolerances on dimensions and form
    links:
    or
  16. #12
    Re: CEN Standards Collection 35/350: CEN TC 32 - Aluminium And Aluminium Alloys
    update:
    added some missing standards thanks to Amjad Malik:
    so, the missing two are now:
    updated links:
    or
  1. Replies: 11
    Last Post: 11-17-2017, 05:23 PM
  2. Materials Literature Collection 107/200 - Aluminium Alloys
    Last Post: 11-27-2016, 06:35 AM
  3. Book Request:Aluminium welding:Theory and practice by aluminium association.
    By inconel in forum Materials Science &Corrosion
    Last Post: 10-09-2012, 01:06 PM
  4. Welding Aluminium And Its Alloys
    By nour in forum Materials Science &Corrosion
    Last Post: 03-13-2012, 08:18 PM
  5. The Welding Of Aluminium And It's Alloys
    Last Post: 09-18-2010, 01:00 AM
