Dears,
any ideas how to import RMS Attribute to petrel in order to guide a facies model.
Dears,
you can load it as surface attribute (if you have it exported from another software)
but the main issue is to correlate the RMS values with facies or any other reservoir characteristics ,
RMS change with many factors such as PHI, N/G, reservoir thickness, Sw ?? , Vcl , ... etc. in addition to some seismic characteristics which has no relation with the reservoir it self !!!
generally RMS considered qualitative indication for facies variation .
you should find a good correlation between RMS and a reasonable reservoir value as I mentioned before.
good luck
