Thread: Advances in Carbon Dioxide Compression and Pipeline Transportation Processes
    2015 | 148 Pages | PDF | 8 MB
    Providing a comprehensive analysis of CO2 compression, transportation processes and safety issues for post combustion CO2 capture applications for a 900 MW pulverized hard coal-fired power plant, this book assesses techniques for boosting the pressure of CO2 to pipeline pressure values with a minimal amount of energy. Four different types of compressors are examined in detail: a conventional multistage centrifugal compressor, integrally geared centrifugal compressor, supersonic shock wave compressor, and pump machines. The study demonstrates that the total compression power is closely related to the thermodynamic process and is not determined by compressor efficiency alone. Another problem addressed is that of CO2 pipeline transport from the compressor outlet site to a disposal site under heat transfer conditions. The book also features an analysis of simulations and models that are used to determine the maximum safe pipeline distance to subsequent booster stations as a function of inlet pressure, ambient temperature, thickness of the thermal insulation and ground-level heat flux conditions. This book focuses on compression as well as transportation processes with particular emphasis on the safety risks related to the transport of CO2. The most important problem in terms of environmental protection is ensuring precise and reliable hazard identification. As hazards can only be managed effectively if they are properly identified, problems involving the discharge and atmospheric dispersion of CO2 are also discussed.
    Re: Advances in Carbon Dioxide Compression and Pipeline Transportation Processes
    I like this book* could you re-load again or sent to me by mechen002991@gmail.com. Thank at advance.
    Dear All* You can download from the following link:
    Warm regards*
    Mano Spenta email: manospenta@gmail.com
    Thanks for my dear friend.
  1. Replies: 3
    Last Post: 11-01-2013, 11:54 PM
  2. Carbon Dioxide Delivery
    By phenom.sam in forum General Engineering
    Last Post: 03-27-2012, 01:41 PM
  3. Article: Carbon dioxide injection to algal cultivation pond
    By shyam_seshadri in forum Home Articles
    Last Post: 11-09-2011, 10:51 AM
  4. Carbon dioxide injection to algal cultivation pond
    By shyam_seshadri in forum General Engineering
    Last Post: 11-08-2011, 09:15 AM
  5. Carbon Dioxide Fire Suppression Systems
    By insaf in forum Safety And Environment
    Last Post: 04-12-2008, 01:23 AM
