HI GUYS,
COULD SOMEBODY UPLOAD THE FOLLOWING ASME STANDARD. I NEED IT BADLY
1. ASME CSD-1 Controls and Safety Devices for Automatically Fired Boilers
This Standard covers requirements for controls and safety devices used on automatically operated boilers directly fired with gas, oil, gas-oil, or electricity (under 12,500,000 Btu/hr).
2. ASME PTC 34 - Waste Combustors with Energy Recovery
This Code provides procedures for conducting tests of municipal waste combustors with energy recovery to determine thermal capacity, thermal efficiency and HHV of the waste fuel
3. ASME PTC 30.1- Air-Cooled Steam Condensers
This Code provides test methods for conducting and reporting thermal performance characteristics of mechanical draft air-cooled steam condensers (ACC) operating under vacuum conditions.
4. ASME PTC 20.1- Speed And Load-Governing Systems For Steam Turbine Generator Units
This code establishes test procedures for determining performance characteristics of speed and load governing systems for Steam Turbine Generator Units.
5 ASME PTC 20.2- Overspeed Trip Systems Of Steam Turbine-Generator Units
This Code provides guiding principles and specifications for determining overall system performance of overspeed trip systems for steam turbine-generator units.
6 ASME PTC 19.14- Linear Measurements
This Standard covers linear measurements and associated instrumentation.
7 ASME B31.12 - Hydrogen Piping and Pipelines
This Code applies to design, construction, operation & maintenance for piping, pipelines & distribution systems in hydrogen service, including power plants, transportation, & distribution stations.
8. ASME PTC 70 - Ramp Rates
This code provides the procedures, direction, and guidance for determination of the maximum repeatable load change ramp rate, startup load change rate or shutdown load change rate of a power plant.
NEW OR OLD REVISION ARE WELCOME
THANK YOU AND REGARDS,
