Results 1 to 6 of 6
Thread: ISO 7240 Request
    ISO 7240 Request
    Dear colleagues,
    Does anybody have ISO 7240 "Fire detection and alarm systems" series for sharing?
    ISO 7240 consists of the following parts, under the general title Fire detection and alarm systems:
    — Part 1: General and definitions
    — Part 2: Control and indicating equipment
    — Part 3: Audible alarm devices
    — Part 4: Power supply equipment
    — Part 5: Point-type heat detectors
    — Part 6: Carbon monoxide fire detectors using electro-chemical cells
    — Part 7: Point-type smoke detectors using scattered light, transmitted light or ionization
    — Part 8: Carbon monoxide fire detectors using an electro-chemical cell in combination with a heat sensor
    — Part 9: Test fires for fire detectors [Technical Specification]
    — Part 10: Point-type flame detectors
    — Part 11: Manual call points
    — Part 12: Line type smoke detectors using a transmitted optical beam
    — Part 13: Compatibility assessment of system components
    — Part 14: Design, installation, commissioning and service of fire detection and fire alarm systems in and around buildings
    — Part 15: Point type fire detectors using scattered light, transmitted light or ionization sensors in combination with a heat sensor
    — Part 16: Sound system control and indicating equipment
    — Part 17: Short-circuit-isolators
    — Part 18: Input/output devices
    — Part 19: Design, installation, commissioning and service of sound systems for emergency purposes
    — Part 20: Aspirating smoke detectors
    — Part 21: Routing equipment
    — Part 22: Smoke-detection equipment for ducts
    — Part 23: Visual alarm devices
    — Part 24: Sound system loudspeakers
    — Part 25: Components using radio transmission paths
    — Part 27: Point-type fire detectors using a scattered-light, transmitted-light or ionization smoke sensor, an electrochemical-cell carbon-monoxide sensor and a heat sensor
    — Part 28: Fire protection control equipment
    Thanks in advance
  3. Re: ISO 7240 Request
    I would like to find these as well.
  6. Re: ISO 7240 Request
    Thank you very much DORIO. This will be very helpful.
    In my researches I found a couple of newer revisions. You can download them here if you want:
    Very good! Thanks a lot.
  9. Re: ISO 7240 Request
    Could you share again?
  1. Request: AWS D1.1
    By riccardoamato in forum Mechanical Engineering
    Last Post: 11-20-2013, 04:18 PM
  2. Request: API 12C
    By Marty Thompson in forum Oil And Gas Production
    Last Post: 06-12-2013, 05:39 AM
  3. API 550 Request
    By carboglass in forum General Engineering
    Last Post: 03-03-2013, 12:56 PM
  4. Request the API RP 686
    By Noppakhun in forum Mechanical Engineering
    Last Post: 04-10-2011, 04:35 PM
  5. [Request] NFPA T3.5.1:2002 (R2010) request
    By gospel85 in forum Electrical & Power Engineering
    Last Post: 03-18-2011, 03:52 AM
