David Herres
English | 2015 | ISBN: 0071844759 | 336 pages | PDF | 10 MB
A practical, money-saving guide to home electrical wiring. Handle residential wiring projects correctly, safely, and according to the National Electrical Code (NEC). Filled with clear photos and helpful diagrams, The Homeowner’s DIY Guide to Electrical Wiring shows you how to quickly and easily navigate the portions of the NEC that pertain to residential installations.
This hands-on resource covers basic electronics and explains how electrical service progresses through your home. It describes how to install and test electrical systems and lighting, repair appliances and TVs, and upgrade to the latest innovations such as home networking, home automation, and alternate power systems. You’ll learn the procedures used by professional electricians to create the kind of quality work that will pass inspection and add value to your home.
The Homeowner’s DIY Guide to Electrical Wiring shows how to:
Protect against fire and shock hazards
Track electrical service from the point of connection to the entrance panel
Follow NEC requirements for residential projects
Work with test equipment and installation tools
Use the best techniques for quality electrical work
Design and install indoor and outdoor lighting
Maintain and repair electrically powered appliances
Fix CRT, plasma, and LCD TVs
Design a data and communications network and install coax, USB, and Ethernet cabling
Install a home automation system
Install backup and alternate power systems
Work with smart meters
