I believe you should analyse steel composition, If alloy % are low such as Cr Ni may be why you found corrosion.
Also if there is a heat/chemical treatment and after someone machined/welded to solve a dimensional problem found I may cause to propert. lost.
Some problems have been related to china made steels who have the % of alloy and rest correct but then some strange % components have been found who give problems when machining or welding.
