Thread: Software for corrosion prediction and corrosion rate evaluation for gas wells
  1. Software for corrosion prediction and corrosion rate evaluation for gas wells
    Hi, guys! I'm not so good in my English because I'm Russian but I will try to explain you what I want)
    In our company we need to understand how much chrome tubing we must use to avoid corrosion in our gas-condensate wells. Now we put down 1500-1800 meters of chrome pipe into the upper interval of the well and the lower part (2500-2200 meters) of the tubing is from carbon. I want to use some software for corrosion prediction and corrosion rate evaluation. I found Electronic Corrosion Engineer soft is fit-for-purpose but I don't have license. Can you help me with it? Or maybe you can suggest other soft?
    Re: Software for corrosion prediction and corrosion rate evaluation for gas wells
    hello, you can go here :
  1. NACE corrosion rate survey
    By lucianonar in forum Oil And Gas Process
    Last Post: 09-30-2011, 03:48 PM
  2. Galvanic corrosion By Harvey P. ****, ASTM Committee G-1 on Corrosion of Metals
    By mohammed21 in forum Materials Science &Corrosion
    Last Post: 06-23-2011, 09:35 AM
  3. Replies: 1
    Last Post: 03-18-2011, 06:47 AM
  4. Corrosion rate
    By maizo in forum Materials Science &Corrosion
    Last Post: 02-24-2010, 10:22 PM
