Thread: Help-Scada System-Well Test-Production
    Gents,
    I am a well testing engineer. I would like to require your help about something in Well Testing.
    In fact, I have sensors from AKS Technologies (
    What I want to do, is to create a software with an interface of the well testing layout (safety valve, choke manifold, separator, tanks...) and the data of the sensors (Pressure, Temperature, Flow meters, Differential Pressure) is in cases in this interface. It is like a scada system (DCS for Production companies). Also, the acquisition will be by the using a dataport which convert the data acquired by wireless to the PC by a RS232-USB cable.
    I appreciate any little help from your side.
    Thank you,
    B.R
    Re: Help-Scada System-Well Test-Production
    Hi Said,
    good day,
    what you mean of "create software" is?
    so many way to "create software", the fastest one, you can using standard HMI software e.g wonderware, citect, etc
    which is already have library to support interfacing protocol from your instrument device e.g modbus, profibus, OPC.
    when you mean "create software" is from scratch, you can build your software by Visual Basic, Java, python etc.
    but this is the hard way, you should build code to get interfacing with your instrument device.
    budget and adrenalin is take decision on this
    Best regards,
    CVJ
  1. petroleum production system, Second edition
    By selfcolor in forum Oil And Gas Production
    Last Post: 09-16-2014, 08:58 AM
  2. Replies: 1
    Last Post: 04-24-2012, 11:02 PM
  3. Production test please help
    By rodoperez in forum Oil And Gas Production
    Last Post: 01-20-2011, 07:33 AM
  4. Well Test Analysis - Petroleum Exploration and Production
    By ameer in forum Safety And Environment
    Last Post: 09-02-2010, 06:33 AM
  5. drawing this production system
    By husseina78 in forum Oil And Gas Production
    Last Post: 06-29-2007, 01:31 PM
