Results 1 to 7 of 7
Thread: Jacket Closure to shell weld strength calculation
  1. Jacket Closure to shell weld strength calculation
    Some body help me find how calculate Jacket closure to shell weld strength calculation?
    Re: Jacket Closure to shell weld strength calculation
    Can you show a drawing ?
    But weld no need to calculate since you have equivalent properties
  6. Re: Jacket Closure to shell weld strength calculation
    Quote Originally Posted by mitsai_3 View Post
    Thanks Mitsai for your response. Below are the drawing, we should calculate weld strength between tube to jacket closure and shell to jacket closure. type the joint is not butt weld but fillet weld.
    What code you use.
    For instance for structures in eurocode with fillet weld you use max value for the throat is 0,7xlowest thickness.
    If you want to use less then you have to go check eurocode formula to see if stress is suported
    What code you use.
  1. Weld Metal calculation
    By inconel in forum Materials Science &Corrosion
    Last Post: 08-21-2014, 01:05 PM
  2. Replies: 0
    Last Post: 06-24-2014, 03:39 AM
  3. WELD METAL CALCULATION - Advance X'mas&New Year Bonanza !!!
    Last Post: 12-03-2012, 07:43 PM
  4. API 650 Shell calculation
    By caca in forum Mechanical Engineering
    Last Post: 11-25-2011, 06:29 PM
  5. Thread calculation for closure for a pressure vessel
    By JEB in forum Mechanical Engineering
    Last Post: 11-13-2009, 03:04 AM
