Hi, everyone
I need some help in how to create a water flooding model in Eclipse, somebody can share a data file in order to see how it os building and how to estimate the wate injection rate for the field
thanks in advance for any help
Hi, everyone
Attached some simple tutorials to create a simple model from scratch in Petrel-RE. In addition, you can estimate/recommend optimum injection rates based on simple calculations such as:
1. Material Balance: compute injection rate required to keep a VRR (voidage replacement ratio) equal to 1 (or slightly higher than 1 if injection fluid losses are expected to occur).
2. Industry rule of thumb: compute injection rate equivalent to 0.1 pore volumes per year.
Both approaches are applicable at a pattern or field level. Finally compare all outputs.
Could you please, explain how can we make VRR constant and equal 1 in Eclipse?
Is there specific keywords to do that?
How to calculate well allocation factor using frontsim?
