Results 1 to 7 of 7
Thread: Use ACTNUM in Petrel RE
    Please be advise how can use ACTNUM in PetrelRE to build simulation model?
    Thank you in advance
    Re: Use ACTNUM in Petrel RE
    Bayan,
    ACTNUM keyword simply deactivates cells when equal to 0 and actives cells when equal to 1. It's that simple. You can use it to deactive a shale break in the stratigraphy, thus creating a vertical flow barrier for example.
    Thank you for the comments.my inquire how can use ACTNUM in Petrel RE by using calculator if it is just write ACTNUM=0 for all model then Write ACTNUM=1 for only the reservoir zone.
    Thank you
    Thank you
    Now I understand your question. What I have done in the past is to create a completely new property using the calculator to deactivate those cells I don't want to include in the model, and name this new property for example NULL. As in ACTNUM, use 0 for deactivation and 1 to keep cells active. To apply this changes to the model (i.e. to implement NULL) you can use this new property as a Pore Volume multiplier, a porosity multiplier or a NTG multiplier. Any cell pore volume equal to zero will be deactivated, this zero values will be the result of multiplying NULL times the cell pore volume, porosity or NTG.
    Hope this helps.
    Thank you so much for your help
    Hi all, I am using Petrel, but i don't known how create ACTNUM in Petrel? Please help me, create it and edit it in Petrel. Thanks so much.
  1. Replies: 35
    Last Post: 03-11-2019, 08:08 PM
  2. Exchange Petrel Seismic to Sim with Petrel RE Course
    By Albertmeine in forum Reservoir
    Last Post: 12-05-2013, 05:52 PM
