  1. Article: Submersible Pump not showing desired pressure
    You can view the page at
    See More: Article: Submersible Pump not showing desired pressure
    Re: Article: Submersible Pump not showing desired pressure
    You first check the location of pumping bowls (impeller). If they are located deep inside a well, you have to deduct this head from the specified head to arrive at the discharge pressure at the top. If the design head is 40m and depth of the well is 20m, the discharge pressure will be 2.0 Kg/cm2g.
    ssk
  1. Submersible Pump not showing desired pressure
    By hiren3010 in forum Mechanical Engineering
    Last Post: 03-20-2014, 04:13 PM
  2. sewage submersible pump
    By bmshah in forum Mechanical Engineering
    Last Post: 09-04-2013, 09:06 AM
  3. Article: pump discharge pressure and orifice
    By Washoo in forum Home Articles
    Last Post: 07-10-2012, 04:41 AM
  4. Replies: 0
    Last Post: 09-01-2011, 02:49 PM
  5. Electric Submersible Pump (ESP) parameters
    By ali in forum Oil And Gas Production
    Last Post: 08-29-2011, 12:16 PM
