I have come across a problem with submersible pump working.
There is pressure gauge installed on the discharge line just after the expander. and it is not showing very less pressure and very far from desired pressure from the pump. New pressure gauge is also tried but the result is the same.
the flow measured is comparable/matching (though not exactly) with design flow.
Will there be any problem with pump installation or installation of pressure gauge.
